Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: .:Shorbagy Team:.
Member: 189 Status: Offline Sonork: 100.1576413 Thanks: 29
| Hello , I have a SE K550i , i need to repair gdfs file , phone was white screed and security is currpted , ok i will post here log results : Code: 00:24:33 D-Ultimate Unlocker v3.07 by Cruiser Team 00:24:33 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 00:24:33 Initializing... ! 00:24:33 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 00:24:33 2. Choose the phone model ! 00:24:33 3. Select the desired options ! 00:24:33 4. Please connect the phone either via USB while holding 2-5… ! 00:24:33 - or via a serial cable and double-click on it in the device list 00:30:28 Selected phone: K550 00:30:28 Connecting via Generic EMP USB Flash Device (USB1)… 00:30:28 Device driver version: 1.0.0.8 00:30:28 Device driver date: 3-30-2006 00:30:28 Connecting to the baseband CPU... 00:30:28 Entering baseband CPU service mode... 00:30:28 Detected chipset: DB2020 00:30:28 Boot mode: ROM 00:30:28 Sending loader... 00:30:28 IMEI: 35489301329893 00:30:28 OTP CID: 51 00:30:29 Effective CID: 52 00:30:30 Please reconnect the phone (disconnect, connect while holding 2-5) E 00:30:42 Error: 0x4D5EFC5D E 00:30:42 Error: 0x8F9F6E1C E 00:30:42 Error: 0x4B4AFEF3 E 00:30:42 Error: 0x319AC5CC E 00:30:42 Error: 0x624C554E E 00:30:42 Error: 0x5577997D E 00:30:42 Error: 0x5C5AEBE3 E 00:30:42 Error: 0x3D35EAF1 E 00:30:42 Failed! ! 00:30:42 To report errors right-click this window and allready i've bought cridets . user + pass Thanks |
| | #3 (permalink) |
| I've updated usb flash to 2.xxxx But i got same error : Code: 19:10:20 D-Ultimate Unlocker v3.07 by Cruiser Team 19:10:20 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:10:20 Initializing... ! 19:10:20 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:10:20 2. Choose the phone model ! 19:10:20 3. Select the desired options ! 19:10:20 4. Please connect the phone either via USB while holding 2-5… ! 19:10:20 - or via a serial cable and double-click on it in the device list 19:11:36 Selected phone: K550 19:11:36 Connecting via Generic EMP USB Flash Device (USB1)… 19:11:36 Device driver version: 2.1.0.0 19:11:36 Device driver date: 3-20-2008 19:11:36 Connecting to the baseband CPU... 19:11:36 Entering baseband CPU service mode... 19:11:36 Detected chipset: DB2020 19:11:36 Boot mode: ROM 19:11:36 Sending loader... 19:11:37 IMEI: 35489301329893 19:11:37 OTP CID: 51 19:11:37 Effective CID: 52 19:11:39 Please reconnect the phone (disconnect, connect while holding 2-5) 19:11:50 Sending loader... 19:11:51 Communicating with server… E 19:11:56 User name not registered on the server E 19:11:56 Error: 0xD0EA59C1 E 19:11:56 Error: 0x41F19ADB E 19:11:56 Error: 0x07F5EFDA E 19:11:56 Login to server failed E 19:11:56 Error: 0x51A411A0 E 19:11:56 Error: 0x78E56923 E 19:11:56 Error: 0x5C5AEBE3 E 19:11:56 Error: 0x3D35EAF1 E 19:11:56 Failed! ! 19:11:56 To report errors right-click this window Thanks |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 25671 Status: Offline Thanks: 0
| E 19:11:56 Login to server failed This means only one problem, I hope you know which one. First try the "Get Credit Info" button, before you will start again with unlocking. |
| | #5 (permalink) |
| I've wrote my username wronge , i must to write user_........ OK thanks i will try now . Code: 12:05:10 D-Ultimate Unlocker v3.07 by Cruiser Team 12:05:10 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:05:10 Initializing... ! 12:05:10 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:05:10 2. Choose the phone model ! 12:05:10 3. Select the desired options ! 12:05:10 4. Please connect the phone either via USB while holding 2-5… ! 12:05:10 - or via a serial cable and double-click on it in the device list 12:07:02 Communicating with server… ! 12:07:06 News: Your credit consumption policy: Level 1 (Novice) 12:07:07 Remainig credit (supreme): 1.00 12:07:07 Done. |
| | #6 (permalink) |
| Now i want to repair GDFS , which file i have to choose it ? Could you advice me about produce ? I've tried with file i've backed up before with setool2 and here's report : Code: 12:23:10 D-Ultimate Unlocker v3.07 by Cruiser Team 12:23:10 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:23:10 Initializing... ! 12:23:10 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:23:10 2. Choose the phone model ! 12:23:10 3. Select the desired options ! 12:23:10 4. Please connect the phone either via USB while holding 2-5… ! 12:23:10 - or via a serial cable and double-click on it in the device list 12:23:30 Selected phone: K550 12:23:30 Connecting via Generic EMP USB Flash Device (USB1)… 12:23:30 Device driver version: 2.1.0.0 12:23:30 Device driver date: 3-20-2008 12:23:31 Connecting to the baseband CPU... 12:23:31 Entering baseband CPU service mode... 12:23:31 Detected chipset: DB2020 12:23:31 Boot mode: ROM 12:23:31 Sending loader... 12:23:31 IMEI: 35489301329893 12:23:31 OTP CID: 51 12:23:31 Effective CID: 52 12:23:33 Please reconnect the phone (disconnect, connect while holding 2-5) 12:24:02 Sending loader... 12:24:02 Communicating with server… ! 12:24:06 News: Your credit consumption policy: Level 1 (Novice) 12:24:07 Remainig credit (supreme): 1.00 12:24:10 Remainig credit (supreme): 0.67 12:24:13 Please reconnect the phone (disconnect, connect while holding 2-5) 12:24:24 Sending loader... E 12:24:26 Error: 0x07F5EFDA E 12:24:26 Error: 0xFE6D44E2 E 12:24:26 Error: 0xE9B26D61 E 12:24:26 Error: 0x8118A648 E 12:24:26 Error: 0x59AF7680 E 12:24:26 Failed! ! 12:24:26 To report errors right-click this window And please help me how i can repair gdfs ? Thanks |
| | #7 (permalink) |
| You must use gdfs files from www.cruisersuite.com |
| | #8 (permalink) |
| Thank you ! But i have no account their because i have no Cruiser Box , but i have registered sucessfully . So now i cannot get gdfs restore file can you share a file here please ? thanks for good help from you . |
| | #10 (permalink) |
| Hello , I have wrote gdfs file from cruiser support . But still phone in white screen !!?? and i have upgraded cid to 52 and i flashed it full flash , but phone when arrive to Cust is stop and cannot accept this file , Please help me . Thank you . and here 're report : Code: 19:13:56 D-Ultimate Unlocker v3.07 by Cruiser Team 19:13:56 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:13:56 Initializing... ! 19:13:56 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:13:56 2. Choose the phone model ! 19:13:56 3. Select the desired options ! 19:13:56 4. Please connect the phone either via USB while holding 2-5… ! 19:13:56 - or via a serial cable and double-click on it in the device list 19:14:29 Selected phone: K550 19:14:29 Connecting via Generic EMP USB Flash Device (USB1)… 19:14:29 Device driver version: 2.1.0.0 19:14:29 Device driver date: 3-20-2008 19:14:30 Connecting to the baseband CPU... 19:14:30 Entering baseband CPU service mode... 19:14:30 Detected chipset: DB2020 19:14:30 Boot mode: ROM 19:14:30 Sending loader... 19:14:30 IMEI: 35489301329893 19:14:30 OTP CID: 51 19:14:30 Effective CID: 49 19:14:32 Please reconnect the phone (disconnect, connect while holding 2-5) 19:14:45 Sending loader... 19:14:52 Initializing GDFS access... 19:14:52 Writing GDFS… 19:14:58 Code NCK for relock: 9569030109365524 19:14:58 Code NSCK for relock: 7514357567615916 19:14:58 Code SPCK for relock: 4030137975039164 19:14:58 Code CCK for relock: 9739996087108820 19:14:58 Code PCK for relock: 6656042516506196 19:14:58 Code ESLCK for relock: 5386421685677069 19:14:58 Code NCK for unlock: 1828741351926188 19:14:58 Code NSCK for unlock: 8134713203700693 19:14:58 Code SPCK for unlock: 1739954678099663 19:14:58 Code CCK for unlock: 1324578299148889 19:14:58 Code PCK for unlock: 9677592289614222 19:14:58 Code ESLCK for unlock: 6520874479007586 19:14:58 To enter a code, type < * * < on the phone with SIM-card inserted 19:14:58 Writing flash… 19:14:59 Turning off the phone... 19:15:01 Done. |
| The Following User Says Thank You to .:Shorbagy Team:. For This Useful Post: |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004
Member: 69608 Status: Offline Thanks: 79
| 1.make operation GDFS reconstruction...(ultimate unlocker) 2.choose GDFS file K550.gdfs-->tick repair erom/semc boot--> 3.set sertificate to Brown CID 49....after this succes. here I'm using other tool(setool)go to tab empty field&repair-->add errom(DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw) then flash...after done-->back to tab sonyericson then do identify-->you will see the version of phone software,example(R6BC002_1250670_CHINA_LI).then flash phone with same firmware&setting set to signed mode+complete phone... tested today 3phones with white light...and error like this: 2009-06-10 23:38:05 loader startup: executed 2009-06-10 23:38:18 loader GDFS startup: executed 2009-06-10 23:41:18 wrong response, break. 2009-06-10 23:41:18 loader fs startup failed, that is fatal 2009-06-10 23:41:18 Elapsed: 314 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Repair GDFS V1.01 | MaikonPhone | SETool2 | 19 | 02-18-2012 11:34 |
| Which version Repair GDFS FREEEEE | vistasamir | SETool2 | 6 | 03-29-2010 22:14 |
| How to repair gdfs problem P990i using UB? | kungpaoski | Universalbox | 3 | 10-27-2009 10:17 |
| k810 repaire gdfs problem | ahmed14 | DreamBox | 1 | 03-30-2009 23:58 |
| repair GDFS PROBLEM K800i please help | zakiyyboss | SETool2 | 8 | 03-26-2009 00:37 |
