Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > D-Unlock Suite
Old 02-20-2010, 10:52   #1 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
k790i after repair gdfs show k790a and no network coverage
any one help me after repair gdfs my k790i showw k790a and if i insert sim show me no network coverage any one help me plz here is logs
  17:31:55  D-Ultimate Unlocker v5.04 by Cruiser Team
  17:31:55  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  17:31:55  Initializing...
! 17:31:55  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:31:55  2. Choose the phone model
! 17:31:55  3. Select the desired options
! 17:31:55  4. Please connect the phone either via USB while holding 2-5…
! 17:31:55  - or via a serial cable and double-click on it in the device list
  17:32:13  Selected phone: W995
  17:32:13  Connecting via Generic EMP USB Flash Device (USB1)…
  17:32:13  Device driver version: 2.2.0.5
  17:32:13  Device driver date: 4-1-2009
  17:32:14  Connecting to the baseband CPU...
  17:32:14  Entering baseband CPU service mode...
  17:32:14  Detected chipset: DB3210 P2A
  17:32:14  Boot mode: ROM
  17:32:15  IMEI: 35402203996151
  17:32:15  OTP CID: 53
  17:32:15  Product type: Retail
  17:32:15  Effective color: Red
  17:32:15  Sending loader...
  17:32:20  Communicating with server…
! 17:32:24  News: Your consumption level is: Level 1 (Novice)
  17:32:25  Remainig credit (supreme): 1
  17:32:30  Restarting phone …
  17:32:35  Sending loader...
  17:32:45  Remainig credit (supreme): 0.6
  17:32:46  Restarting phone …
  17:32:51  Sending loader...
  17:32:54  Sending loader...
  17:32:55  Writing flash…
  17:32:56  Code NCK for relock: 7066456052047578
  17:32:56  Code NSCK for relock: 3661435764374084
  17:32:56  Code SPCK for relock: 9975689927585321
  17:32:56  Code CCK for relock: 7868664757793169
  17:32:56  Code PCK for relock: 6400034657150265
  17:32:56  Code ESLCK for relock: 0902145444366294
  17:32:57  Code NCK for unlock: 8478366599191618
  17:32:57  Code NSCK for unlock: 6764084065926460
  17:32:57  Code SPCK for unlock: 2935554606170898
  17:32:57  Code CCK for unlock: 5630566345524840
  17:32:57  Code PCK for unlock: 4863328994563112
  17:32:57  Code ESLCK for unlock: 4461700977777929
  17:32:57  To enter a code, type < * * < on the phone with SIM-card inserted
  17:32:57  Converting phone to red…
  17:32:57  Turning off the phone...
  17:32:57  Done.
Old 02-21-2010, 21:49   #2 (permalink)
blagus's Avatar
Member: 1178861
Sonork: 100.1590268
Thanks Meter: 60
1) Why is selected phone W995 if you're talking about K790?
2) Repair GDFS. Download K790 GDFS file from support area.
Old 02-22-2010, 01:12   #3 (permalink)
reimon23's Avatar
Member: 268175
Thanks Meter: 198
you selected wrong brand.
you must choose the same model.
Old 02-22-2010, 10:36   #4 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
sorry brothers wron selection here is complete logs and sorry for that
  13:44:38  D-Ultimate Unlocker v5.04 by Cruiser Team
  13:44:38  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:44:38  Initializing...
! 13:44:38  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:44:38  2. Choose the phone model
! 13:44:38  3. Select the desired options
! 13:44:38  4. Please connect the phone either via USB while holding 2-5…
! 13:44:38  - or via a serial cable and double-click on it in the device list
  13:45:12  Selected phone: K790
  13:45:12  Connecting via Generic EMP USB Flash Device (USB3)…
  13:45:12  Device driver version: 2.2.0.5
  13:45:12  Device driver date: 4-1-2009
  13:45:12  Connecting to the baseband CPU...
  13:45:12  Entering baseband CPU service mode...
  13:45:13  Detected chipset: DB2020
  13:45:13  Boot mode: ROM
  13:45:13  Sending loader...
  13:45:13  IMEI: 35220701285166
  13:45:13  OTP CID: 51
  13:45:13  Effective CID: 52
  13:45:15  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:45:27  Sending loader...
  13:45:27  Communicating with server…
! 13:45:33  News: Your consumption level is: Level 1 (Novice)
  13:45:33  Remainig credit (supreme): 1
  13:45:38  Remainig credit (supreme): 0.6
  13:45:42  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:45:55  Sending loader...
  13:46:07  Initializing GDFS access...
  13:46:07  Writing GDFS…
  13:46:17  Code NCK for relock: 1109076953460867
  13:46:17  Code NSCK for relock: 4752024672691290
  13:46:17  Code SPCK for relock: 0246184160638398
  13:46:17  Code CCK for relock: 2595029352394401
  13:46:17  Code PCK for relock: 3491283144794138
  13:46:17  Code ESLCK for relock: 3403695104095692
  13:46:17  Code NCK for unlock: 9882412216127409
  13:46:17  Code NSCK for unlock: 3175779848510509
  13:46:17  Code SPCK for unlock: 7724698225930178
  13:46:17  Code CCK for unlock: 6692290424431930
  13:46:17  Code PCK for unlock: 5877471537227817
  13:46:17  Code ESLCK for unlock: 7239570377225213
  13:46:17  To enter a code, type < * * < on the phone with SIM-card inserted
  13:46:17  Writing flash…
  13:46:19  Turning off the phone...
  13:46:21  Done.
Old 02-22-2010, 12:27   #5 (permalink)
Member: 670274
Thanks Meter: 165
dear /\/\A/\/| DON,
GDFS reconstruction is an expert repair operation, and it must be used in that way. If you read the manuals / info tabs / my forum posts, you will find out, that this operation destroys unique phone data (in your case seems radio calibration is different). So it seems that the GDFS backup file you choosed is not compatible with that particular phone. You must choose another GDFS file.
Please use GDFS reconstruction only if all other procedures fail to revive the phone, otherwise you can destroy good unique data, which you never can get back.
GLaDOS
The Following 2 Users Say Thank You to GLaDOS For This Useful Post:
k790i after repair gdfs show invalid sim need help /\/\A/\/| SETool2 6 02-21-2010 16:16
w580i after repair gdfs show blank display /\/\A/\/| D-Unlock Suite 0 12-21-2009 15:14
K810i After repair GDFS no network on DCS anthony cheah DreamBox 4 07-01-2008 13:28
nokia2280 no network coverage after ... saiful2001 UFS2 + UFS3-Tornadoflasher 1 08-30-2006 06:52
LG U8210 after flash imei is wrong and no network! zeozea LG 0 08-11-2006 11:01
Page generated in 0.16291 seconds with 10 queries
