Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: IRAN(land of heros) Age: 33
Member: 115172 Status: Offline Thanks: 113
| P990 Credit used but fails to repair Hi everybody; Look at the log below,i need to repair this phone's Security Zone.Dunlocker used credit but gives error while trying to repair it.I press 2+5 and inser USB cable but it suddenly turns on,the only way i could get it into boot mode is using @ key,could it be the reason? Code: 10:30:30 D-Ultimate Unlocker v5.04 by Cruiser Team
10:30:30 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
10:30:30 Initializing...
! 10:30:30 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 10:30:30 2. Choose the phone model
! 10:30:30 3. Select the desired options
! 10:30:30 4. Please connect the phone either via USB while holding 2-5…
! 10:30:30 - or via a serial cable and double-click on it in the device list
10:31:17 Selected phone: P990
10:31:17 Connecting via Sony Ericsson Port (COM48, COM49)…
10:31:17 Device driver version: 4.40.6.0
10:31:17 Device driver date: 12-26-2007
10:31:19 Connecting to the baseband CPU...
10:31:21 Entering baseband CPU service mode...
10:31:21 Detected chipset: DB2001
10:31:21 Boot mode: ROM
10:31:21 Sending loader...
10:31:22 Error: 0xBF980527
10:31:22 Error: 0x44D7B1D9
10:31:22 Error: 0x35A52603
10:31:22 Error: 0x45A1D7E8
10:31:22 Error: 0xD6E193F2
10:31:22 Failed!
10:31:22 To report errors right-click this window |
| | #5 (permalink) |
| Still i get the same damn error,does it matter if i press "C" or "@" or "2+5" ? Please help,i checked these phones hardware throughly,no phydical dmage,i guess it's server side problem,admins please help me. Code: 11:28:08 D-Ultimate Unlocker v5.04 by Cruiser Team 11:28:08 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:28:08 Initializing... ! 11:28:08 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:28:08 2. Choose the phone model ! 11:28:08 3. Select the desired options ! 11:28:08 4. Please connect the phone either via USB while holding 2-5… ! 11:28:08 - or via a serial cable and double-click on it in the device list 11:28:52 Selected phone: P990 11:28:52 Connecting via Sony Ericsson Port (COM92, COM93)… 11:28:52 Device driver version: 4.38.6.212 11:28:52 Device driver date: 5-31-2006 11:28:54 Connecting to the baseband CPU... 11:28:56 Entering baseband CPU service mode... 11:28:56 Detected chipset: DB2001 11:28:56 Boot mode: ROM 11:28:56 Sending loader... E 11:28:57 Error: 0x05190628 E 11:28:57 Error: 0xBF980527 E 11:28:57 Error: 0x44D7B1D9 E 11:28:57 Error: 0x35A52603 E 11:28:57 Error: 0x45A1D7E8 E 11:28:57 Error: 0xD6E193F2 E 11:28:57 Failed! ! 11:28:57 To report errors right-click this window |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: Croatia, Blaguša
Member: 1178861 Status: Offline Sonork: 100.1590268 Thanks: 22
| Well, it looks like you don't use USB cable, but you use some kind of serial cable. Use DCU-60/65 cable and hold C or @ button. |
| | #7 (permalink) |
| I used DCU60 but this time i tried with DCU65 and again the same happens: Code: 17:17:04 D-Ultimate Unlocker v5.04 by Cruiser Team 17:17:04 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:17:04 Initializing... ! 17:17:04 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:17:04 2. Choose the phone model ! 17:17:04 3. Select the desired options ! 17:17:04 4. Please connect the phone either via USB while holding 2-5… ! 17:17:04 - or via a serial cable and double-click on it in the device list 17:17:18 Selected phone: P990 17:17:18 Connecting via Sony Ericsson Port (COM92, COM93)… 17:17:18 Device driver version: 4.38.6.212 17:17:18 Device driver date: 5-31-2006 17:17:20 Connecting to the baseband CPU... 17:17:22 Entering baseband CPU service mode... 17:17:22 Detected chipset: DB2001 17:17:22 Boot mode: ROM 17:17:22 Sending loader... E 17:17:23 Error: 0xBF980527 E 17:17:23 Error: 0x44D7B1D9 E 17:17:23 Error: 0x35A52603 E 17:17:23 Error: 0x45A1D7E8 E 17:17:23 Error: 0xD6E193F2 E 17:17:23 Failed! ! 17:17:23 To report errors right-click this window |
| | #9 (permalink) |
| Could you explain me what is that "Sony Ericsson Port" on COM ports? If you use USB cable then it should say: Code: 19:25:35 Connecting via Generic EMP USB Flash Device (USB1)…
19:25:35 Device driver version: 2.2.0.5
19:25:35 Device driver date: 4-1-2009 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| lost credit loss but failed to reconstuction gdfs k320(cid detect 51) | sharky_tan | Cruiser Suite | 4 | 04-24-2010 10:24 |
| nokia 5800 credits used but phone not unlocked | shazy2005 | Universalbox | 1 | 03-16-2009 21:31 |
| 2 credits used but no code for 2 voda 527 fones ... | raju4u | Basic Micro-Box Software Support | 1 | 10-08-2008 21:51 |
| Credits used but phone eraselock not generated. | blazin22 | Seking Server | 2 | 09-17-2008 05:23 |
| i can acces ok in nokia flash repair v1_34, but failed to conect | pescailla | Griffin | 0 | 11-24-2007 17:51 |
