08-24-2009, 09:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | P990 fails to be repaired bu Ultimate unlocker I have a P990,while flashing it says UNKNOWN CID,tried repairing by U unlocker and get the following problem: Code: 12:31:19 D-Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team 12:31:19 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:31:19 Initializing... ! 12:31:19 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:31:19 2. Choose the phone model ! 12:31:19 3. Select the desired options ! 12:31:19 4. Please connect the phone either via USB while holding 2-5… ! 12:31:19 - or via a serial cable and double-click on it in the device list 12:34:12 Selected phone: P990 12:34:12 Connecting via Sony Ericsson Port (COM34, COM35)… 12:34:12 Device driver version: 4.40.6.0 12:34:12 Device driver date: 12-26-2007 12:34:14 Connecting to the baseband CPU... 12:34:16 Entering baseband CPU service mode... 12:34:16 Detected chipset: DB2001 12:34:16 Boot mode: ROM 12:34:16 Sending loader... 12:34:17 IMEI: 35959300363851 12:34:17 OTP CID: 49 12:34:17 Restarting phone … 12:34:20 Sending loader... 12:34:21 Communicating with server… ! 12:34:25 News: There is a newer version of Ultimate Unlocker (v4.01). ! 12:34:25 News: Your credit consumption policy: Level 1 (Novice) 12:34:26 Remainig credit (supreme): 1 12:34:29 Remainig credit (supreme): 0.67 12:34:30 Restarting phone … 12:34:33 Sending loader... E 12:34:35 Error: 0x07F5EFDA E 12:34:35 Error: 0x3173E984 E 12:34:35 Error: 0x4B055A8F E 12:34:35 Error: 0xA4CAA1B4 E 12:34:35 Error: 0xE2B69390 E 12:34:35 Error: 0xEACC0A85 E 12:34:35 Error: 0xB3FAC5D7 E 12:34:35 Error: 0xA91D2AC8 E 12:34:35 Error: 0x11CE1466 E 12:34:35 Error: 0x59AF7680 E 12:34:35 Failed! ! 12:34:35 To report errors right-click this window |
08-24-2009, 16:30 | #2 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | Below ia flash log for hte mentioned phone: Code: v0.915037/UNI CARD SERIAL: 0009.... Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100010000000000 writing "G:\Boxes\SEtool\Flash files\P990\P990i_GW1__R9GA001_R5A01_R6E28_R6E28_2.zip" Processing package G:\Boxes\SEtool\Flash files\P990\P990i_GW1__R9GA001_R5A01_R6E28_R6E28_2.zip detected MASTER on COM98, SLAVE on COM99 PDA EROM VERSION: CXC162060 R2D01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM98, SLAVE on COM99 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300363851 CERT:BROWN ldr_on_ldr prologue error (00) Break. Elapsed: 520 secs. |
5220; simlock data corrupted; is it possible to be repaired w/o ask2rpl? | ru_dee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 10-08-2009 11:12 |
W580 that shows:Model (from GDFS):K700 Successfully Repaired bySE Ultimate Unlocker | NawabN Sahoo | Cruiser Suite | 1 | 07-22-2009 01:25 |
Can this be repaired by ultimate? | -luigi- | Cruiser Suite | 1 | 01-16-2009 13:14 |
W910 repair with ultimate unlocker | roniri | Cruiser Suite | 4 | 09-28-2008 21:57 |
Smart Clip damaged and not allowed to be repaired. | Dengel | Smart-Clip | 11 | 09-07-2007 03:20 |
