Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > D-Unlock Suite
Old 03-14-2009, 09:13   #1 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
Phone not repaired but credit lost..
  13:42:10  D-Ultimate Unlocker v3.07 by Cruiser Team
  13:42:10  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:42:10  Initializing...
! 13:42:10  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:42:10  2. Choose the phone model
! 13:42:10  3. Select the desired options
! 13:42:10  4. Please connect the phone either via USB while holding 2-5…
! 13:42:10  - or via a serial cable and double-click on it in the device list
  13:42:34  Selected phone: K550
  13:42:34  Connecting via Generic EMP USB Flash Device (USB1)…
  13:42:34  Device driver version: 2.2.0.0
  13:42:34  Device driver date: 9-18-2008
  13:42:34  Connecting to the baseband CPU...
  13:42:34  Entering baseband CPU service mode...
  13:42:34  Detected chipset: DB2020
  13:42:34  Boot mode: ROM
  13:42:34  Sending loader...
  13:42:35  IMEI: 35934601952775
  13:42:35  OTP CID: 51
  13:42:35  Effective CID: 52
  13:42:37  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:42:46  Sending loader...
  13:42:47  Communicating with server…
! 13:42:53  News: Your credit consumption policy: Level 1 (Novice)
  13:42:54  Remainig credit (supreme): 0.34
  13:42:57  Remainig credit (supreme): 0.01
  13:43:01  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:43:10  Sending loader...
E 13:43:46  Error: 0x6C729765
E 13:43:46  Error: 0x8CDFAB78
E 13:43:46  Error: 0xC8AE715C
E 13:43:46  Error: 0xBF4FB442
E 13:43:46  Error: 0xA91D2AC8
E 13:43:46  Error: 0x11CE1466
E 13:43:46  Error: 0x59AF7680
E 13:43:46  Failed!
! 13:43:46  To report errors right-click this window
Old 03-14-2009, 09:20   #2 (permalink)
zaki_barika's Avatar
Member: 135661
Thanks Meter: 92
E 13:43:46  Failed!
but you have now DB2020 recovred "brown 49"
1-write good gdfs
2- upgrade erom to red 52
3- flash your phone with main+fs and cost....
Old 03-14-2009, 09:53   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
When i try with setool im getting loader not respond error..any solution
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35934601952775 CERT:N/A
FLASH CID:49 COLOR:BROWN
Loader not responding !
Elapsed: 39 secs.
Old 03-14-2009, 11:25   #4 (permalink)
Member: 135661
Thanks Meter: 92
Open COM port OK
Speed:921600
Elapsed: 39 secs.
in setool soft go in Empty fill tab select your phone and add gdfs from folder "gdfs_in_ssw_format"
write gdfs
then buck to SonyEricsson tab and from eroms folder ths file "DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw"
write erom
write main and fs and your phone will be ok
good luck
Old 03-15-2009, 06:32   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
done..but same .........................
Old 03-19-2009, 13:14   #6 (permalink)
Member: 288754
Thanks Meter: 63
write gdfs
write erom
good luck
hi bro
i have same problem but mine i can't upgrade erom phone before was cid52 red now is cid 49 brown so when i press recovery button i get :file ldr not upgrade phone not answer .so what solution to fix that ?
w395 unlock but credit lost why? aliajk SETool2 4 09-24-2009 14:57
Page generated in 0.20505 seconds with 10 queries
