23:59:41 D-Ultimate Unlocker v5.04 by Cruiser Team
23:59:42 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
23:59:42 Initializing...
! 23:59:42 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 23:59:42 2. Choose the phone model
! 23:59:42 3. Select the desired options
! 23:59:42 4. Please connect the phone either via USB while holding 2-5…
! 23:59:42 - or via a serial cable and double-click on it in the device list
00:00:16 Selected phone: W850
00:00:16 Connecting via Generic EMP USB Flash Device (USB2)…
00:00:16 Device driver version: 1.1.0.12
00:00:16 Device driver date: 9-25-2006
00:00:16 Connecting to the baseband CPU...
00:00:16 Entering baseband CPU service mode...
00:00:16 Detected chipset: DB2020
00:00:17 Boot mode: ROM
00:00:17 Sending loader...
00:00:17 IMEI: 35282601080476
00:00:17 OTP CID: 49
00:00:17 Effective CID: 49
00:00:19 Please reconnect the phone (disconnect, connect while holding 2-5)
00:00:30 Sending loader...
00:00:30 Communicating with server…
E 00:00:33 Error: 0xF984FBBB
E 00:00:34 Error data: 0xF984FBBB - 00000004:1F000000
E 00:00:34 Error: 0xAA5841F7
E 00:00:34 Error: 0x659FFCB8
E 00:00:34 Error: 0x523901CA
E 00:00:34 Error: 0x5C5AEBE3
E 00:00:34 Error: 0x3D35EAF1
E 00:00:34 Error: 0x07F5EFDA
E 00:00:34 Error: 0xF984FBBB
E 00:00:34 Error data: 0xF984FBBB - 00000004:E3030000
E 00:00:34 You are not authorized to use this application
E 00:00:34 Login to server failed
E 00:00:34 Failed!
! 00:00:34 To report errors right-click this window
