06-29-2009, 11:03 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 668524 Status: Offline Thanks Meter: 5 | S500 repair problem Code: 13:52:22 D-Ultimate Unlocker v3.07 by Cruiser Team 13:52:22 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:52:22 Initializing... ! 13:52:22 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:52:22 2. Choose the phone model ! 13:52:22 3. Select the desired options ! 13:52:22 4. Please connect the phone either via USB while holding 2-5… ! 13:52:22 - or via a serial cable and double-click on it in the device list 13:53:21 Selected phone: S500 13:53:21 Connecting via Generic EMP USB Flash Device (USB1)… 13:53:21 Device driver version: 2.1.0.0 13:53:21 Device driver date: 3-20-2008 13:53:22 Connecting to the baseband CPU... 13:53:22 Entering baseband CPU service mode... 13:53:22 Detected chipset: DB2020 13:53:22 Boot mode: ROM 13:53:22 Sending loader... 13:53:22 IMEI: 35344702838217 13:53:22 OTP CID: 51 13:53:22 Effective CID: 52 13:53:24 Please reconnect the phone (disconnect, connect while holding 2-5) 13:53:31 Sending loader... 13:53:31 Communicating with server… ! 13:53:35 News: Your credit consumption policy: Level 3 (Skilled) 13:53:35 Remainig credit (supreme): 3.40 13:53:38 Remainig credit (supreme): 3.20 E 13:54:13 Error: 0x07F5EFDA E 13:54:13 Error: 0x6C729765 E 13:54:13 Error: 0x8CDFAB78 E 13:54:13 Error: 0x3E161E3C E 13:54:13 Error: 0xA577BDCD E 13:54:13 Error: 0xC448BD46 E 13:54:13 Error: 0x4EC89901 E 13:54:13 Error: 0x5C5AEBE3 E 13:54:13 Error: 0x3D35EAF1 E 13:54:13 Failed! ! 13:54:13 To report errors right-click this window Now log is: Code: 14:01:16 D-Ultimate Unlocker v3.07 by Cruiser Team 14:01:16 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 14:01:16 Initializing... ! 14:01:16 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 14:01:16 2. Choose the phone model ! 14:01:16 3. Select the desired options ! 14:01:16 4. Please connect the phone either via USB while holding 2-5… ! 14:01:16 - or via a serial cable and double-click on it in the device list 14:07:21 Selected phone: S500 14:07:21 Connecting via Generic EMP USB Flash Device (USB1)… 14:07:21 Device driver version: 2.1.0.0 14:07:22 Device driver date: 3-20-2008 14:07:22 Connecting to the baseband CPU... E 14:07:22 Error: 0xA8A269DB E 14:07:22 Error: 0x4AD40835 E 14:07:22 Error: 0xCB397A2B E 14:07:22 Error: 0x03FA0F16 E 14:07:22 Error: 0x889C690F E 14:07:22 Cable disconnect detected E 14:07:22 Failed! ! 14:07:22 To report errors right-click this window |
07-01-2009, 10:11 | #6 (permalink) |
Member: 668524 Status: Offline Thanks Meter: 5 | I can't full flash phone and do gdfs reconstruction because first sector is dead I think. gdfs reconstruction log: Code: 13:09:31 D-Ultimate Unlocker v3.07 by Cruiser Team 13:09:31 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:09:31 Initializing... ! 13:09:31 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:09:31 2. Choose the phone model ! 13:09:31 3. Select the desired options ! 13:09:31 4. Please connect the phone either via USB while holding 2-5… ! 13:09:31 - or via a serial cable and double-click on it in the device list 13:10:07 Selected phone: S500 13:10:07 Connecting via Generic FTDI Cable (COM5)… 13:10:07 Device driver version: 1.0.2154.0 13:10:07 Device driver date: 4-16-2004 13:10:08 Connecting to the baseband CPU... 13:10:17 Entering baseband CPU service mode... 13:10:17 Detected chipset: DB2020 13:10:17 Boot mode: ROM 13:10:17 Sending loader... 13:10:18 IMEI: 35344702838217 13:10:18 OTP CID: 51 13:10:18 Restarting phone … 13:10:20 Sending loader... 13:10:21 Communicating with server… ! 13:10:28 News: Your credit consumption policy: Level 3 (Skilled) 13:10:28 Remainig credit (supreme): 3.20 13:10:30 Remainig credit (supreme): 3.20 E 13:11:00 Error: 0x07F5EFDA E 13:11:00 Error: 0x6C729765 E 13:11:01 Error: 0x8CDFAB78 E 13:11:01 Error: 0x3E161E3C E 13:11:01 Error: 0xA577BDCD E 13:11:01 Error: 0xC448BD46 E 13:11:01 Error: 0x4EC89901 E 13:11:01 Error: 0x5C5AEBE3 E 13:11:01 Error: 0x3D35EAF1 E 13:11:01 Failed! ! 13:11:01 To report errors right-click this window |
s500 repair gdfs error use name and pass | samo 111 | SETool2 | 3 | 09-12-2009 18:50 |
S500 gdfs repair problem | sandeephanda78 | Cruiser Suite | 3 | 05-16-2009 09:30 |
s500 repair problem | bipedal103 | Cruiser Suite | 3 | 01-23-2009 03:33 |
s500 Repair gdfs Success Via Tp | supportallgsm | DreamBox | 0 | 06-10-2008 18:20 |
S500 Repair Gdfs... | basilbaby | Sony Ericsson | 6 | 06-06-2008 00:00 |
