Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Denmark Age: 31
Member: 146369 Status: Offline Thanks: 9
| same problem after succesfull EROM repair... Hi yall I have a K550... After succesfull repair it still has the same fault, white screen... Here is log: Code: 20:10:06 D-Ultimate Unlocker v3.05 by Cruiser Team 20:10:06 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 20:10:06 Initializing... ! 20:10:06 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 20:10:06 2. Choose the phone model ! 20:10:06 3. Select the desired options ! 20:10:06 4. Please connect the phone either via USB while holding 2-5… ! 20:10:06 - or via a serial cable and double-click on it in the device list 20:12:22 Selected phone: K550 20:12:22 Connecting via Generic EMP USB Flash Device (USB1)… 20:12:22 Device driver version: 2.1.0.0 20:12:22 Device driver date: 3-20-2008 20:12:22 Connecting to the baseband CPU... 20:12:22 Entering baseband CPU service mode... 20:12:22 Detected chipset: DB2020 20:12:22 Boot mode: ROM 20:12:22 Sending loader... 20:12:22 IMEI: 35433302400667 20:12:22 OTP CID: 51 20:12:22 Effective CID: 53 20:12:24 Please reconnect the phone (disconnect, connect while holding 2-5) 20:12:48 Sending loader... 20:12:48 Communicating with server… ! 20:12:53 News: Your credit consumption policy: Level 1 (Novice) 20:12:54 Remainig credit (supreme): 1.67 20:12:57 Remainig credit (supreme): 1.34 20:13:00 Please reconnect the phone (disconnect, connect while holding 2-5) 20:13:10 Sending loader... 20:13:13 Code NCK for relock: 8767639292595557 20:13:13 Code NSCK for relock: 6093011040050251 20:13:13 Code SPCK for relock: 9159640459345640 20:13:13 Code CCK for relock: 4716362264776066 20:13:13 Code PCK for relock: 8272488981361894 20:13:13 Code ESLCK for relock: 8636383032751713 20:13:13 Code NCK for unlock: 3621576782678617 20:13:13 Code NSCK for unlock: 4810207060426782 20:13:13 Code SPCK for unlock: 2351448209195474 20:13:13 Code CCK for unlock: 0932000393757569 20:13:13 Code PCK for unlock: 2771349068978705 20:13:13 Code ESLCK for unlock: 1781099752554870 20:13:13 To enter a code, type < * * < on the phone with SIM-card inserted 20:13:13 Writing flash… 20:13:15 Turning off the phone... 20:13:17 Done. v0.915017/UNI CARD SERIAL: 00021632 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35433302400667 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\Ratata\Skrivebord\K550\R6BC002_1250669_GE NERIC_LI.ssw CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Documents and Settings\Ratata\Skrivebord\K550\r6bc002_fs_europe_ 4_li_red_cid53.ssw CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:3540 Will flash 177 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 586 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| nokia 6120c the same problem after flach !!! | seddik-gsm | Nokia Base Band 5 ( BB-5 ) | 6 | 05-18-2009 08:59 |
| K810 erom repair Problem..? | china_mobiles | SETool2 | 3 | 11-29-2008 10:38 |
| C116 problem after recovering with Repair Module | mcandre | Infinity-Box | 2 | 08-01-2008 21:13 |
| same problem after write rpl any solution? | F@RUK S | Nokia Base Band 5 ( BB-5 ) | 11 | 06-02-2008 15:10 |
| Nokia 7650 Same Problem After Flash | S.SHANTHIKUMAR | Griffin | 1 | 07-17-2005 20:21 |
