Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: TuNiSiA Age: 36
Member: 462224 Status: Offline Sonork: 100.1586374 Thanks: 500
| server connection hi, i have bought credit for d-ultimate unlocker, but i got always: Code: 08:23:40 D-Ultimate Unlocker v3.07 by Cruiser Team 08:23:40 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 08:23:40 Initializing... ! 08:23:40 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 08:23:40 2. Choose the phone model ! 08:23:40 3. Select the desired options ! 08:23:40 4. Please connect the phone either via USB while holding 2-5… ! 08:23:40 - or via a serial cable and double-click on it in the device list 08:23:50 Communicating with server… E 08:24:11 Error: 0x1F41CF97 E 08:24:11 Cannot connect to the server E 08:24:11 Failed! ! 08:24:11 To report errors right-click this window PS: i have tried disabling firewall & antivirus. thanks. |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 25671 Status: Offline Thanks: 0
| You are from Tunisia, your country is blocking internet partially. Search in Cruiser Suite section for guide from Filip how to connect to server in Tunisia. |
| The Following User Says Thank You to Mainboard For This Useful Post: |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007 Location: Dubai
Member: 514148 Status: Offline Thanks: 131
| i got a same problem with k800. but i did not find any sulotion. Code: 10:28:54 D-Ultimate Unlocker v3.07 by Cruiser Team 10:28:55 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 10:28:55 Initializing... ! 10:28:55 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 10:28:55 2. Choose the phone model ! 10:28:55 3. Select the desired options ! 10:28:55 4. Please connect the phone either via USB while holding 2-5… ! 10:28:55 - or via a serial cable and double-click on it in the device list 10:29:34 Selected phone: K800 10:29:34 Connecting via Generic EMP USB Flash Device (USB1)… 10:29:34 Device driver version: 1.0.0.8 10:29:34 Device driver date: 3-30-2006 10:29:35 Connecting to the baseband CPU... 10:29:35 Entering baseband CPU service mode... 10:29:35 Detected chipset: DB2020 10:29:35 Boot mode: ROM 10:29:35 Sending loader... 10:29:37 IMEI: 35170801843470 10:29:37 OTP CID: 49 10:29:37 Effective CID: 49 10:29:39 Please reconnect the phone (disconnect, connect while holding 2-5) E 10:29:53 Error: 0x4D5EFC5D E 10:29:53 Error: 0x8F9F6E1C E 10:29:53 Error: 0x4B4AFEF3 E 10:29:53 Error: 0x319AC5CC E 10:29:53 Error: 0x624C554E E 10:29:54 Error: 0x5577997D E 10:29:54 Error: 0x5C5AEBE3 E 10:29:54 Error: 0x3D35EAF1 E 10:29:54 Failed! ! 10:29:54 To report errors right-click this window |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 34
Member: 132856 Status: Offline Thanks: 110
| pls what is this Code: 23:57:27 D-Ultimate Unlocker v3.07 by Cruiser Team 23:57:27 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 23:57:28 Initializing... ! 23:57:28 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 23:57:28 2. Choose the phone model ! 23:57:28 3. Select the desired options ! 23:57:28 4. Please connect the phone either via USB while holding 2-5… ! 23:57:28 - or via a serial cable and double-click on it in the device list 23:57:31 Communicating with server… E 23:57:34 You are not authorized to use this application E 23:57:34 Error: 0xAA5841F7 E 23:57:35 Error: 0x07F5EFDA E 23:57:35 Login to server failed E 23:57:35 Failed! ! 23:57:35 To report errors right-click this window |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: Inside CPU Age: 32
Member: 23420 Status: Offline Thanks: 52
| whats wrong here ? Checking new D-Client version... Connecting to server... Connection closed. Connecting to server... Connection closed. Connecting to server... Connection closed. Communication with server failed. (5FB3854E) Communication with server failed. (35C1BB60) Communication with server failed. (35C1BB60) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| ub team help me repair bug connect to server connection refused | mobispot | Universalbox | 1 | 11-19-2009 13:47 |
| ub not connected to server connection refused | faizi_khalid | Universalbox | 21 | 06-23-2009 20:53 |
| Connecting to server ...Connection timed out | rajinder1978 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 05-25-2009 14:52 |
| can't connect to server, connection refused | formative | Universalbox | 11 | 12-29-2008 07:33 |
| can't connect to server...connection refused | rahulk99k | Universalbox | 4 | 12-29-2008 07:30 |
