02-22-2010, 12:56 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: unlock-dz.org
Member: 135244 Status: Offline Sonork: 100.1603108 Thanks Meter: 16 | server problem Code: 12:51:41 D-Ultimate Unlocker v3.02 by Cruiser Team 12:51:41 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:51:41 Initializing... ! 12:51:41 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:51:41 2. Choose the phone model ! 12:51:41 3. Select the desired options ! 12:51:41 4. Please connect the phone either via USB while holding 2-5… ! 12:51:41 - or via a serial cable and double-click on it in the device list 12:51:46 Communicating with server… E 12:51:51 Error: 0xAA5841F7 E 12:51:51 Error: 0x07F5EFDA E 12:51:51 Unknown server problem [80] E 12:51:51 Login to server failed E 12:51:51 Failed! ! 12:51:51 To report errors right-click this window my user :user_781d0d9c thanks |
The Following 2 Users Say Thank You to HAMID-GSM For This Useful Post: |
02-22-2010, 16:34 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: yemen
Member: 346934 Status: Offline Sonork: 100.1575675 Thanks Meter: 59 | Code: 07:32:12 D-Ultimate Unlocker v5.04 by Cruiser Team 07:32:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 07:32:12 Initializing... ! 07:32:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 07:32:12 2. Choose the phone model ! 07:32:12 3. Select the desired options ! 07:32:12 4. Please connect the phone either via USB while holding 2-5… ! 07:32:13 - or via a serial cable and double-click on it in the device list 07:32:19 Communicating with server… E 07:33:09 Error: 0x8A9A7090 E 07:33:09 Error: 0x9A714570 E 07:33:09 Error: 0x1DF4483D E 07:33:09 Error: 0x659FFCB8 E 07:33:09 Error: 0x8F522B71 E 07:33:09 Login to server failed E 07:33:09 Failed! ! 07:33:09 To report errors right-click this window user_769da009 plz help me |
The Following 2 Users Say Thank You to ufs-4 For This Useful Post: |
02-23-2010, 14:48 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | Check settings, IP address 60.54.216.58, port 9001 If you will still have problems ask your reseller for support? If he won't help you, buy from other reseller next time. |
The Following 2 Users Say Thank You to Mainboard For This Useful Post: |
04-25-2010, 12:42 | #8 (permalink) | |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | Quote:
I think it is server problem I can't even goto http://www.cruiserlog.net/ it always say This webpage is not available. | |
The Following User Says Thank You to alayne For This Useful Post: |
05-07-2010, 20:20 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: 2697b03f Age: 43
Member: 568700 Status: Offline Thanks Meter: 52 | Quote:
05-08-2010, 08:01 | #10 (permalink) |
Freak Poster Join Date: Dec 2009 Location: EU
Member: 1178861 Status: Offline Sonork: 100.1590268 Thanks Meter: 60 | Server is down once again. Code: 09:00:12 D-Ultimate Unlocker v5.04 by Cruiser Team 09:00:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 09:00:12 Initializing... ! 09:00:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 09:00:12 2. Choose the phone model ! 09:00:12 3. Select the desired options ! 09:00:12 4. Please connect the phone either via USB while holding 2-5… ! 09:00:12 - or via a serial cable and double-click on it in the device list 09:00:13 Communicating with server… E 09:00:15 Error: 0x1F41CF97 E 09:00:15 Error: 0x659FFCB8 E 09:00:15 Error: 0x8F522B71 E 09:00:15 Cannot connect to the server E 09:00:15 Check server host name and port in the settings E 09:00:15 Failed! ! 09:00:15 To report errors right-click this window |
05-08-2010, 08:22 | #11 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Alaska
Member: 672931 Status: Offline Thanks Meter: 28 | Code: 14:14:22 D-Ultimate Unlocker v5.04 by Cruiser Team 14:14:22 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 14:14:22 Initializing... ! 14:14:22 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 14:14:22 2. Choose the phone model ! 14:14:22 3. Select the desired options ! 14:14:22 4. Please connect the phone either via USB while holding 2-5… ! 14:14:22 - or via a serial cable and double-click on it in the device list 14:14:34 Selected phone: W200 14:14:34 Connecting via Generic FTDI Cable (COM4)… 14:14:34 Device driver version: 2.6.0.0 14:14:34 Device driver date: 10-22-2009 14:14:35 Connecting to the baseband CPU... 14:15:01 Entering baseband CPU service mode... 14:15:01 Detected chipset: DB2012 14:15:02 Boot mode: ROM 14:15:02 Sending loader... 14:15:03 IMEI: 3537960233xxxx 14:15:03 OTP CID: 51 14:15:03 Effective CID: 53 14:15:03 Restarting phone … 14:15:05 Sending loader... 14:15:06 Communicating with server… E 14:15:07 Error: 0x1F41CF97 E 14:15:07 Error: 0x659FFCB8 E 14:15:07 Error: 0x523901CA E 14:15:07 Error: 0x5C5AEBE3 E 14:15:07 Error: 0x3D35EAF1 E 14:15:07 Cannot connect to the server E 14:15:08 Check server host name and port in the settings E 14:15:08 Failed! ! 14:15:08 To report errors right-click this window Check settings, IP address 60.54.216.58, port 9001 >> True still error... i think server problem |
05-09-2010, 18:09 | #12 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | I'm still having the same error, since friday: Quote:
05-10-2010, 10:43 | #13 (permalink) |
Member: 1178861 Status: Offline Sonork: 100.1590268 Thanks Meter: 60 | It's working here: Code: 11:42:47 D-Ultimate Unlocker v5.04 by Cruiser Team 11:42:47 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:42:47 Initializing... ! 11:42:47 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:42:47 2. Choose the phone model ! 11:42:47 3. Select the desired options ! 11:42:47 4. Please connect the phone either via USB while holding 2-5… ! 11:42:47 - or via a serial cable and double-click on it in the device list 11:42:48 Communicating with server… ! 11:42:56 News: New pricing policies started. ! 11:42:57 News: Users with 1 or more credits and cruiser dongle have all operations for free. ! 11:42:57 News: Full pricing can be found on http://www.ultimate-unlocker.com/web/uu/buy#70 ! 11:42:59 News: Your consumption level is: Level 3 (Skilled) 11:43:01 Remainig credit (supreme): 0.14 11:43:01 Done. |
07-16-2010, 09:20 | #14 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem....server problem.... |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
N79 unlock sucses nothing server problem i use 3rd server | AYAZ42 | Universalbox | 2 | 06-29-2009 13:42 |
Problem to Unlock SE P1i with D unlocker -Unknown server problem [129] | ahsotelo | D-Unlock Suite | 1 | 04-24-2009 13:45 |
Problem between 2 Redbox2 , Server problem | todoportable | Redbox | 0 | 05-29-2005 12:02 |
