sir pls cheak my problem i have after windows my d-ultimate its problem cheak my log sir pls!!:confused: Code: 12:42:13 D-Ultimate Unlocker v5.04 by Cruiser Team imran qma |
Please go to www.cruiserlog.net and press forgot pass U ll get new pass then use this.. |
then write same account details also in "Settings" of D-ultimate unlocker and click on Save changes button |
sir i am allready trye but same reselut |
contact your logs reseller, he will help you, he can check your account status, analyze your error log etc. |
Code: Users can now reset their passwords by themselves (1/13/10 4:33 PM) |
why are you not help me p/s and user my reseller is not ans me |
this time my my both software s1 and d ultimate are same err server and host err here my log Code: 17:44:12 SE S1 Flasher & Unlocker v3.00 by Cruiser Team |
here is d- ulitmate err Code: 17:49:02 D-Ultimate Unlocker v5.04 by Cruiser Team |
kind leyy help me team whats my problem cheak and replay me sir |
Hi, There are more reported errors related to the server: this error: E: Cannot connect to the server E: Check server host name and port in the settings means that the application cannot either connect to the server. The most common reasons for this are the following: - you use incorrect server name/IP or port - the server and/or port is firewalled somewhere on the way - server is temporarily down If you successfully connect to the server, then you can get: E: Wrong password E: Login to server failed this means, you have connected to the server, but you provided wrong username/password combination. This error can be shown in other form - Card not registered on the server, User not registered on the server In your case, you own a cruiser card but you tried to use D-Ultimate Unlocker, which is an application for users without any cruiser dongle. Use SE Ultimate Unlocker, and make sure you set all the settings correctly. GLaDOS |
i dont now why are you not intersted my problem i have same 25 day still problem but not any one proper ans me and c/t is help me why ? my d ultimate is problem and ses1 unlocker is working port are same ud password is ok but problem is dstill same why? what i am rong cheak my problem |
i have described your problem seriously. Please read it carefully. The original problem is that you are trying to use D-Ultimate Unlocker. You will never be able to use D-Ultimate unlocker together with your Cruiser+ dongle, you should use SE Ultimate Unlocker. The temporary problem "Cannot connect to server" was caused by server outage on 7th Feb. Is it clear already? |
