Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > D-Unlock Suite
Old 02-04-2010, 07:43   #1 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
Unhappy sir pls cheak my problem
i have after windows my d-ultimate its problem cheak my log sir pls!!
  12:42:13  D-Ultimate Unlocker v5.04 by Cruiser Team
  12:42:13  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  12:42:13  Initializing...
! 12:42:13  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 12:42:13  2. Choose the phone model
! 12:42:13  3. Select the desired options
! 12:42:13  4. Please connect the phone either via USB while holding 2-5…
! 12:42:13  - or via a serial cable and double-click on it in the device list
  12:42:25  Selected phone: T715
  12:42:25  Connecting via Generic EMP USB Flash Device (USB1)…
  12:42:25  Device driver version: 2.2.0.0
  12:42:25  Device driver date: 9-18-2008
  12:42:25  Connecting to the baseband CPU...
  12:42:26  Entering baseband CPU service mode...
  12:42:26  Detected chipset: DB3210 P2A
  12:42:26  Boot mode: ROM
  12:42:27  IMEI: 35662803077704
  12:42:27  OTP CID: 53
  12:42:27  Product type: Retail
  12:42:27  Effective color: Red
  12:42:27  Sending loader...
  12:42:32  Communicating with server…
E 12:42:33  Error: 0xD0EA59C1
E 12:42:33  Error: 0x659FFCB8
E 12:42:33  Error: 0x02CB342E
E 12:42:33  Error: 0x99C5BD51
E 12:42:33  Error: 0x3D35EAF1
E 12:42:33  Error: 0x07F5EFDA
E 12:42:33  Error: 0xF984FBBB
E 12:42:33  Error data: 0xF984FBBB - 00000004:E3030000
E 12:42:33  Wrong password
E 12:42:33  Login to server failed
E 12:42:33  Failed!
! 12:42:33  To report errors right-click this window
bestreghard
imran qma
Old 02-04-2010, 07:52   #2 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 806
Please go to www.cruiserlog.net and press forgot pass
U ll get new pass then use this..
Old 02-04-2010, 07:56   #3 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
but bro my s1 unlocker working fine and password is rite
Old 02-04-2010, 15:05   #4 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
then write same account details also in "Settings" of D-ultimate unlocker and click on Save changes button
Old 02-04-2010, 16:49   #5 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
sir i am allready trye but same reselut
Old 02-04-2010, 19:02   #6 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
contact your logs reseller, he will help you, he can check your account status, analyze your error log etc.
Old 02-04-2010, 19:28   #7 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 806
From now reseller can not change anything. pls visit here again -www.cruiserlog.net and u can fix ur problem itself.
Users can now reset their passwords by themselves (1/13/10 4:33 PM)
All end-users are now able to reset their forgot passwords via this site. Simply refer them to visit  http://www.cruiserlog.net/, then to click "Forgot password".
then all ll b ok.
Old 02-07-2010, 12:38   #8 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
why are you not help me p/s and user my reseller is not ans me
Old 02-07-2010, 12:47   #9 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
this time my my both software s1 and d ultimate are same err server and host err here my log
  17:44:12  SE S1 Flasher & Unlocker v3.00 by Cruiser Team
  17:44:12  Initializing...
! 17:44:12  1. Choose the phone model
! 17:44:12  2. For flashing, select flash files and additional options
! 17:44:12  3. Double-click on the appropriate device (serial cable)
! 17:44:12  - or connect the phone via USB while holding its C button
! 17:44:24  Your card activation ID is: 874AE9FB443E83D066EAFA99BB522F38-07
  17:44:24  Communicating with server…
E 17:44:26  Error: 0x1F41CF97
E 17:44:26  Error: 0x659FFCB8
E 17:44:26  Error: 0x8F522B71
E 17:44:26  Cannot connect to the server
E 17:44:26  Check server host name and port in the settings
E 17:44:26  Failed!
! 17:44:26  To report errors right-click this window
Old 02-07-2010, 12:49   #10 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
here is d- ulitmate err
  17:49:02  D-Ultimate Unlocker v5.04 by Cruiser Team
  17:49:02  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  17:49:02  Initializing...
! 17:49:02  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:49:02  2. Choose the phone model
! 17:49:02  3. Select the desired options
! 17:49:02  4. Please connect the phone either via USB while holding 2-5…
! 17:49:02  - or via a serial cable and double-click on it in the device list
  17:49:06  Communicating with server…
E 17:49:07  Error: 0x1F41CF97
E 17:49:07  Error: 0x659FFCB8
E 17:49:07  Error: 0x8F522B71
E 17:49:07  Cannot connect to the server
E 17:49:07  Check server host name and port in the settings
E 17:49:07  Failed!
! 17:49:07  To report errors right-click this window
Old 02-07-2010, 12:50   #11 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
kind leyy help me team whats my problem cheak and replay me sir
Old 02-10-2010, 11:29   #12 (permalink)
Member: 670274
Thanks Meter: 164
Hi,
There are more reported errors related to the server:
this error:
E: Cannot connect to the server
E: Check server host name and port in the settings
means that the application cannot either connect to the server. The most common reasons for this are the following:
- you use incorrect server name/IP or port
- the server and/or port is firewalled somewhere on the way
- server is temporarily down
If you successfully connect to the server, then you can get:
E: Wrong password
E: Login to server failed
this means, you have connected to the server, but you provided wrong username/password combination. This error can be shown in other form - Card not registered on the server, User not registered on the server
In your case, you own a cruiser card but you tried to use D-Ultimate Unlocker, which is an application for users without any cruiser dongle. Use SE Ultimate Unlocker, and make sure you set all the settings correctly.
GLaDOS
The Following User Says Thank You to GLaDOS For This Useful Post:
Old 02-16-2010, 07:34   #13 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 116
Unhappy
Originally Posted by GLaDOS View Post
Hi,
this error:
E: Wrong password
GLaDOS
i dont now why are you not intersted my problem i have same 25 day still problem but not any one proper ans me and c/t is help me why ?
my d ultimate is problem and ses1 unlocker is working port are same ud password is ok but problem is dstill same why? what i am rong cheak my problem
Old 02-17-2010, 10:36   #14 (permalink)
Member: 670274
Thanks Meter: 164
Dear imran qma,
i have described your problem seriously. Please read it carefully.
The original problem is that you are trying to use D-Ultimate Unlocker. You will never be able to use D-Ultimate unlocker together with your Cruiser+ dongle, you should use SE Ultimate Unlocker.
The temporary problem "Cannot connect to server" was caused by server outage on 7th Feb.
Is it clear already?
Uploade File failed Pls Solv My Problem delower10 Board, Server and Login Problems/Support 6 05-15-2010 08:04
Pls solve my Problem sangwilson iPhone 2 / iPhone 3G / iPhone 3GS 9 01-10-2010 23:24
pls solved my problem hdeyda Cruiser Suite 4 03-24-2009 20:03
pls solve my problem cellncare BB5 RPL 0 08-22-2008 14:10
sir please solve my problem my work is stoped 4 days anildeepak Smart-Clip 1 03-27-2008 09:28
Page generated in 0.44699 seconds with 8 queries
