10-06-2008, 16:41 | #18 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | looks like you are using wrong software. Ultimate Unlocker are for non card07 users. Looks like U are using card and therefore should use Cruiser Suite Ultimate Unlocker ( CS Ultimate Unlocker) |
10-16-2008, 20:08 | #19 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | what is this problem @ cruiser team 00:36:05 D-Ultimate Unlocker v2.01 by Cruiser Team 00:36:05 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 00:36:05 Initializing... ! 00:36:05 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 00:36:05 2. Choose the phone model ! 00:36:05 3. Select the desired options ! 00:36:05 4. Please connect the phone either via USB while holding 2-5… ! 00:36:05 - or via a serial cable and double-click on it in the device list 00:36:54 Selected phone: S500 00:36:54 Connecting via Generic EMP USB Flash Device (USB2)… 00:36:55 Device driver version: 2.1.0.0 00:36:55 Device driver date: 3-20-2008 00:36:55 Connecting to the baseband CPU... 00:36:55 Entering baseband CPU service mode... 00:36:55 Detected chipset: DB2020 00:36:55 Boot mode: ROM 00:36:55 Sending loader... 00:36:55 IMEI: 356xxxxxxxxxxx 00:36:55 OTP CID: 51 00:36:55 Effective CID: 52 00:36:55 Please reconnect the phone (disconnect, connect while holding 2-5) 00:37:00 Sending loader... 00:37:01 Communicating with server… E 00:37:03 User name not registered on the server E 00:37:04 Error: 0xD0EA59C1 E 00:37:04 Error: 0x41F19ADB E 00:37:04 Error: 0x07F5EFDA E 00:37:04 Error: 0x51A411A0 E 00:37:04 Error: 0x78E56923 E 00:37:04 Error: 0x5C5AEBE3 E 00:37:04 Error: 0x3D35EAF1 E 00:37:04 Login to server failed E 00:37:04 Failed! ! 00:37:04 Please disconnect battery and cable from the phone! ! 00:37:04 To report errors right-click this window |
10-17-2008, 04:42 | #21 (permalink) |
Member: 76257 Status: Offline Thanks Meter: 77 | cruiser team reply urgently that i can see brother but i got an email with account activation done from cruiser team but still login to server failed,anyways thanks for replying but i want cruiser team to answer this -regards-cpukiller |
10-17-2008, 14:30 | #22 (permalink) |
Junior Member Join Date: Mar 2005 Age: 55
Member: 127980 Status: Offline Thanks Meter: 3 | i have same problem , how to solved it any idea Code: 20:27:46 SE Ultimate Unlocker v2.01 by Cruiser Team 20:27:46 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 20:27:46 Initializing... ! 20:27:46 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 20:27:46 2. Choose the phone model ! 20:27:46 3. Select the desired options ! 20:27:46 4. Please connect the phone either via USB while holding 2-5… ! 20:27:46 - or via a serial cable and double-click on it in the device list 20:27:52 Selected phone: K610 20:27:52 Connecting via Generic FTDI Cable (COM3)… 20:27:52 Device driver version: 2.2.4.0 20:27:52 Device driver date: 6-27-2007 E 20:28:03 Error: 0x5E2C7C55 E 20:28:03 Error: 0xC3DD1DE5 E 20:28:03 Error: 0xFBBEF882 E 20:28:03 Error: 0x1DDC1593 E 20:28:03 Error: 0x319AC5CC E 20:28:03 Failed! ! 20:28:03 Please disconnect battery and cable from the phone! ! 20:28:03 To report errors right-click this window 19:13:25 SE Ultimate Unlocker v2.01 by Cruiser Team 19:13:25 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:13:25 Initializing... ! 19:13:25 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:13:25 2. Choose the phone model ! 19:13:25 3. Select the desired options ! 19:13:25 4. Please connect the phone either via USB while holding 2-5… ! 19:13:25 - or via a serial cable and double-click on it in the device list 19:13:32 Selected phone: K320 19:13:32 Connecting via Generic FTDI Cable (COM3)… 19:13:32 Device driver version: 2.2.4.0 19:13:32 Device driver date: 6-27-2007 E 19:13:43 Error: 0x5E2C7C55 E 19:13:43 Error: 0xC3DD1DE5 E 19:13:43 Error: 0xFBBEF882 E 19:13:43 Error: 0x1DDC1593 E 19:13:43 Error: 0x319AC5CC E 19:13:43 Failed! ! 19:13:43 Please disconnect battery and cable from the phone! ! 19:13:43 To report errors right-click this window [/code] |
10-17-2008, 14:50 | #23 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 35
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | cruiser took credit for noting Code: 18:43:06 D-Ultimate Unlocker v2.01 by Cruiser Team 18:43:06 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:43:06 Initializing... ! 18:43:06 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:43:06 2. Choose the phone model ! 18:43:06 3. Select the desired options ! 18:43:06 4. Please connect the phone either via USB while holding 2-5… ! 18:43:06 - or via a serial cable and double-click on it in the device list 18:43:18 Selected phone: K550 18:43:18 Connecting via Generic EMP USB Flash Device (USB1)… 18:43:18 Device driver version: 2.0.0.4 18:43:18 Device driver date: 9-12-2007 18:43:18 Connecting to the baseband CPU... 18:43:18 Entering baseband CPU service mode... 18:43:18 Detected chipset: DB2020 18:43:18 Boot mode: ROM 18:43:18 Sending loader... 18:43:19 IMEI: 35489301527943 18:43:19 OTP CID: 51 18:43:19 Effective CID: 52 18:43:19 Please reconnect the phone (disconnect, connect while holding 2-5) 18:43:28 Sending loader... 18:43:28 Communicating with server… ! 18:43:32 News: Your credit consumption policy: Level 1 (Novice) 18:43:33 Remainig credit (supreme): 0.75 18:43:38 Remainig credit (supreme): 0.50 E 18:43:38 Error: 0x07F5EFDA E 18:43:38 Error: 0xE1F532DC E 18:43:38 Error: 0xA577BDCD E 18:43:38 Error: 0xC448BD46 E 18:43:38 Error: 0x4EC89901 E 18:43:39 Error: 0x5C5AEBE3 E 18:43:39 Error: 0x3D35EAF1 E 18:43:39 Failed! ! 18:43:39 Please disconnect battery and cable from the phone! ! 18:43:39 To report errors right-click this window |
10-27-2008, 09:47 | #24 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Welcome Back J.A.F Age: 47
Member: 135200 Status: Offline Sonork: 100.1594691 Thanks Meter: 33 | Thanks u r genious. Quote:
I THINK CRUISER AND SETOOL BOTH BOX NEEDED. | |
How to repair gdfs wo tp with D-unlocker ? | jetli1 | D-Unlock Suite | 4 | 06-07-2009 20:56 |
about repairing gdfs by log with ultimate unlocker | monsterpassword | Cruiser Suite | 10 | 03-02-2009 11:17 |
problem erom w880 cid53 with ultimate unlocker | mafo82 | Cruiser Suite | 21 | 11-08-2008 11:37 |
ANy one try to Repair Erom/SEMC Boot with SE Ultimate Unlocker | ZoHaiB_(FoneGSM) | Cruiser Suite | 4 | 10-07-2008 11:46 |
w550i hang up when i am trying to repair erom need help :( | speedstarrr | Cruiser Suite | 0 | 09-18-2006 19:56 |
