Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jul 2009
Member: 1072358 Status: Offline Thanks: 0
| I used D-Unlocker with my new SE W995 to try to unlock it. I used the only "show the codes" way. D-Unlocker show me all the codes,but when i tried to start the phone to try the codes the phone simple did not start. I can connect the phone to D-Unlocker or anyone else tool that can access phone when it is not on. But the phone just does not start anymore. ![]() |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 25671 Status: Offline Thanks: 0
| post full log from your unlock process. logs are saved in My documents folder. also remove battery from phone and put it back, check if battery is fully charged. |
| | #3 (permalink) |
| First attempt: 11:41:05 D-Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team 11:41:05 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:41:05 Initialisation en cours… ! 11:41:05 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:41:05 2. Choisir le model du telephone ! 11:41:05 3. Select the desired options ! 11:41:05 4. Please connect the phone either via USB while holding 2-5… ! 11:41:05 - or via a serial cable and double-click on it in the device list 11:41:30 Selected phone: W995 11:41:30 Se connecte via Generic EMP USB Flash Device (USB2)… 11:41:30 Device driver version: 2.2.0.5 11:41:30 Device driver date: 4-1-2009 11:41:30 Connexion a la Baseband CPU en cours… 11:41:30 Baseband CPU service mode entrant… 11:41:31 Chipset detecte: DB3210 P2A 11:41:31 Boot mode: ROM 11:41:31 IMEI: xxxxxxxxxxxxxxxxx 11:41:31 OTP CID: 53 11:41:31 Type de produit: Detail 11:41:31 Couleur Effective: Rouge 11:41:31 Envoi du loader en cours… 11:41:36 Communicating with server… ! 11:41:39 News: Your credit consumption policy: Level 1 (Novice) 11:41:39 Remainig credit (supreme): 1 11:41:41 Remainig credit (supreme): 0.55 11:41:42 Restarting phone … E 11:42:43 Error: 0x07F5EFDA E 11:42:43 Error: 0xA8A269DB E 11:42:43 Error: 0xE7AA3974 E 11:42:43 Error: 0xDDB61C08 E 11:42:43 Error: 0xFB12E1E5 E 11:42:43 Error: 0x5EBDED89 E 11:42:43 Error: 0x3CA1C96F E 11:42:43 Error: 0x14C12528 E 11:42:43 Error: 0x49BC9496 E 11:42:43 Error: 0x59AF7680 E 11:42:43 Cable deconnecte detecte E 11:42:43 Echec! ! 11:42:43 Pour rapporter l'erreur cliquer droit sur cette fenetre Second attempt: 11:42:58 D-Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team 11:42:58 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:42:58 Initialisation en cours… ! 11:42:58 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:42:58 2. Choisir le model du telephone ! 11:42:58 3. Select the desired options ! 11:42:58 4. Please connect the phone either via USB while holding 2-5… ! 11:42:58 - or via a serial cable and double-click on it in the device list 11:43:09 Selected phone: W995 11:43:09 Se connecte via Generic EMP USB Flash Device (USB2)… 11:43:09 Device driver version: 2.2.0.5 11:43:09 Device driver date: 4-1-2009 11:43:10 Connexion a la Baseband CPU en cours… 11:43:10 Baseband CPU service mode entrant… 11:43:10 Chipset detecte: DB3210 P2A 11:43:10 Boot mode: ROM 11:43:11 IMEI: XXXXXXXXXXXX 11:43:11 OTP CID: 53 11:43:11 Type de produit: Detail 11:43:11 Couleur Effective: Bleu 11:43:11 Envoi du loader en cours… 11:43:14 Envoi du loader en cours… 11:43:16 Code NCK for relock: XXXXXXXXXXXX 11:43:16 Code NSCK for relock: XXXXXXXXXXXX 11:43:16 Code SPCK for relock: XXXXXXXXXXXX 11:43:16 Code CCK for relock: XXXXXXXXXXXX 11:43:16 Code PCK for relock: XXXXXXXXXXXX 11:43:16 Code ESLCK for relock: XXXXXXXXXXXX 11:43:16 Code NCK for unlock: XXXXXXXXXXXX 11:43:16 Code NSCK for unlock: XXXXXXXXXXXX 11:43:16 Code SPCK for unlock: XXXXXXXXXXXX 11:43:16 Code CCK for unlock: XXXXXXXXXXXX 11:43:16 Code PCK for unlock: XXXXXXXXXXXX 11:43:17 Code ESLCK for unlock: XXXXXXXXXXXX 11:43:17 To enter a code, type < * * <, on the phone with SIM-card inserted 11:43:17 Eteindre le telephone… 11:43:17 Effectue. |
| | #5 (permalink) |
| I did a flash to generic SE soft but it did not work too. Then i managed to get it start up with erom/semc boot repair but now it is locked with all sims :the one which comes with phone (my future network) and the one that i want to use now (my future former network). I will try to unlock with new version of d-unlocker |
| The Following User Says Thank You to luisfrrs For This Useful Post: |
| | #7 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2004 Location: jordan Age: 36
Member: 54916 Status: Offline Thanks: 50
| Quote:
| | #8 (permalink) |
| From a french site (i live in france). the direct link: http://www.4shared.com/file/11311966...028_CID53.html This is a SE flash with little custom. The only problem i got is that i don't have anymore the "media" shortcut on left down screen and joystick does not work in shortcut way (no contacts when i press it down or organizer i press it up). I will look for another flash later. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| update failed, n96 won't boot anymore | triple_h | Nokia Base Band 5 ( BB-5 ) | 15 | 12-08-2010 00:57 |
| csca server won't work anymore | sekingteam | Seking Server | 4 | 05-03-2009 03:27 |
| DKBB5 (JAF-TRK) Client V.1.1c ready. Old Client Won't Work Anymore. | :::GsmFather::: | GsmFatherOnline Unlock Terminal | 0 | 02-08-2009 14:08 |
| My cruiser cannot start anymore... | RHF | Cruiser Suite | 7 | 12-16-2006 08:20 |
| Help !!! Twister soft doesn't start anymore on my windows XP | bonanza | Twisterflasher | 6 | 01-08-2005 10:19 |
