Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > PRODUCTS SUPPORT
Old 06-10-2012, 08:22   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
Dits Ufc4 Help Desk And VideoS
WHO IS FACED PROBLEMS WHILE CONNECT PHONE WITH UFC4 JUST CONATCT ME OR POST YOUR PROBLEM CLEARLY
Notes:
1) JIG NAME
2) PHONE MODEL
3) PHONE CONDITION
4) ERROR LOG WITH ANY SUPPORTING BOX
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-10-2012, 08:32   #2 (permalink)
Member: 351924
Sonork: 100.1581941
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-10-2012, 08:46   #3 (permalink)
Member: 351924
Sonork: 100.1581941
Old 06-10-2012, 08:56   #4 (permalink)
Member: 351924
Sonork: 100.1581941
NOKIA 7210C
USED JIG BB5-A
http://www.youtube.com/watch?v=O_KTgeB4dXI
Old 06-10-2012, 08:58   #5 (permalink)
Member: 351924
Sonork: 100.1581941
NOKIA C6-01
USED JIG BB5-S
http://www.youtube.com/watch?v=xLaHFSJbsbA
Old 06-10-2012, 13:11   #6 (permalink)
.:iTRi:.'s Avatar
Member: 240068
CAN U ADVICE TO USE DITS UFC4 WITH CYCLONEBOX
ITRY BB5 P JIG WITH 6303i WITHOUT SUCCESS
ITRY WITH AND WITHOUT TX2 ADAPTER
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600000001020C192102054100
CMT_EM_ASIC_ID: 00001051
CMT_EM_ASIC_ID: 00001060
CMT_PUBLIC_ID: 2B4001026A1D5F40609138112DACD12DAD2E81D3
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT_BOOT_ROM_CRC: 67E82268
CMT_SECURE_ROM_CRC: F29CEA60
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
Booting CMT...
CMT Ready!
CBUS Request Error -> CBUS Response wrong header
Prepare phone failed with message -> Failed to get CMT Configuration
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
The Following User Says Thank You to .:iTRi:. For This Useful Post:
Old 06-11-2012, 05:56   #7 (permalink)
Member: 351924
Sonork: 100.1581941
bro what is the phone condition?
box selector adaptor must be select cyclone also bsi set to 7.5
then try again
Old 06-11-2012, 07:58   #8 (permalink)
Member: 351924
Sonork: 100.1581941
While run atf show this error with ufc4?
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00000001
     ID DWORD    3 : 020C1921
     ID DWORD    4 : 02054100
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00001040
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00001030
  4  PUBLIC_ID 12
     ID DWORD    0 : 12A00213
     ID DWORD    1 : 062B0049
     ID DWORD    2 : 1FF38D58
     ID DWORD    3 : 41598344
     ID DWORD    4 : E4A8853E
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           49
SearchForBootstrap_DCT5..
D:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
Boot File - Version  011.048.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
DDR PROTOCOL ERROR: Phone did not Ack !!!
ERROR: Sending Loader Failed, CHECK PHONE RX2 PINOUT
ERROR: Sending Loader Failed...
ERROR: FBUS Boot FAILED
Box Selector Adaptor Must Be Select Correct Box Model Otherwise Software
Given This Error
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-12-2012, 05:23   #9 (permalink)
jamohaki's Avatar
Member: 83397
N95 and n95 8gb connect problem
I have several times i have problem connecting these phones with ufc not going to local mode or test mode with any box i have tried changing resistor size but in vain can u pls tell correct method of connecting these phones?
Old 06-12-2012, 11:45   #10 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Phone is new still not used just want to try jigs
Old 08-08-2012, 18:42   #11 (permalink)
Member: 1696555
hi i want to read hash from nokia 3710 rm509 and i have UFC4 dits .I used adapter BB5 M
and set power to 7.5k and 10k but i cannot even read phone info and hash with my cyclone and atf.
I would like to know if ufc4 dits works with 3710a and if yes how please provide testpoint picture as well and video if possible
Old 08-09-2012, 10:51   #12 (permalink)
Member: 351924
Sonork: 100.1581941
Old 10-13-2012, 06:55   #13 (permalink)
Member: 1747553
Sonork: camecana
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  EM_ASIC_ID 02
  3  EM_ASIC_ID 02
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           49
Given This Error
me too i'm using UFC4, i'm thinking that you have to give picture of position of all each box (no resistor because depend on phones)
thanks
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.48992 seconds with 11 queries
