Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > PRODUCTS SUPPORT
Old 05-25-2012, 19:24   #1 (permalink)
.:iTRi:.'s Avatar
Member: 240068
ditsufc4 PROBLEME
CAN U ADVICE TO USE DITS UFC4 WITH CYCLONEBOX
ITRY BB5 P JIG WITH 6303 WITHOUT SUCCESS
ITRY WITH AND WITHOUT TX2 ADAPTER
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600000001020C192102054100
CMT_EM_ASIC_ID: 00001051
CMT_EM_ASIC_ID: 00001060
CMT_PUBLIC_ID: 2B4001026A1D5F40609138112DACD12DAD2E81D3
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT_BOOT_ROM_CRC: 67E82268
CMT_SECURE_ROM_CRC: F29CEA60
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
Booting CMT...
CMT Ready!
CBUS Request Error -> CBUS Response wrong header
Prepare phone failed with message -> Failed to get CMT Configuration
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Old 05-30-2012, 10:28   #2 (permalink)
Member: 1697230
try to fix the jig good and clean the phone contacts becuse the type of carbon(black) contacts not very good like copper type easy to damage
B.R
D.D
Old 06-01-2012, 05:53   #3 (permalink)
arabie's Avatar
Member: 699870
B.R
D.D
same here always error!!
Old 06-01-2012, 10:49   #4 (permalink)
.:iTRi:.'s Avatar
Member: 240068
phone is new one cleaned not connect
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.39493 seconds with 11 queries
