Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > PRODUCTS SUPPORT
Old 07-29-2012, 11:48   #1 (permalink)
Gsm-extreme's Avatar
Member: 659181
Thanks Meter: 7,652
iPhone Activation Card By DITS
Once you’ve got your new iPhone, you’ll need to connect to the latest version of iTunes to activate it. To do this you will need a sim card from original network, but when you do not have this sim you can use this iPhone activation card no matter what network the iPhone is locked to !!
The iPhone activation sim will allow you to use menu systems without problems. Ideal if you need to access wi-fi to jailbreak or unlock
Compatibility
* iPhone 2G, 3G, 3GS
* iPhone 4G
* All ios Firmware versions including all basebands.
Questions and Answers
Q. I don’t have original sim card for my iPhone and I need to activate it?
A. You can buy this Sim Card for activation and this way you don't need a sim from the original network the iphone is currently locked on to be able to activate and use. Use this Card to activate your iPhone and be able to use the functions and get past the screen on the iphone where its asking to be activated.
Q. I don’t know my Iphone network operator ?
A. Don’t worry , the activation card will auto detect your network for you.
Q. How does the iPhone activation sim work?
A. Simply insert the iPhone activation sim into your iPhone, launch iTunes and connect your iPhone ... easy !!
http://www.youtube.com/watch?v=foeRd9Mmhbs
http://www.youtube.com/watch?v=u2ZqwHIJVNI
Note: This Sim card not for unlock phone baseband etc. and is Activation By pass only. But will allow you to use menu systems without problems. Ideal if you need WI-fi to jailbreak or unlock
Usage instructions
This sim is for bypassing activation only
insert sim into iPhone, launch itunes, and connet iPhone to pc via cable
this will give your iPhone a "slide to unlock" screen instead of "slide for emergency"
The sim has now done its job
Some Help for After activation bypass: (Please use google too for this)
Remember to actually activate your iphone you obviously need a normal sim.
Once you have "slide to unlock" you can access to the menu on the phone and can use wifi and safari to jailbreak your phone.
once jailbroken you can then use cydia to add ultrasnow and unlock your iphone
once this is done you can use your desired sim in the phone and activation will then be made.
some handsets may need cydia push fix too.
all this is explained in great detail in this file Phonebook Card
Order Today
DITS | Phone Book Card 3 in 1 - buy phonebook card, phonebook card, phone book card, dits phonebook card, activate iPhone 3g, 3gs, 4g, ipad, test card, test sim card, iphone activation card
The Following 2 Users Say Thank You to Gsm-extreme For This Useful Post:
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.12350 seconds with 9 queries
