Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > PRODUCTS SUPPORT
Old 01-07-2011, 07:34   #1 (permalink)
Member: 502531
ku9100 dead boot..please help procedure need guide.
hi,
i have ORT-JTAG box software, i need to know step by step procedure how to repair KU9100 LG cyon phone
1: cable difinition = only pinout on support
2: what version or what tool?
3: procedure from connecting to reparing etc,etc,
hope electroboys give time on this
thanks in advance.
Old 01-07-2011, 07:37   #2 (permalink)
Crazy Poster
Member: 1300904
fafa waiting mode din po ako..... )
Old 01-07-2011, 07:46   #3 (permalink)
Member: 1414229
Sonork: jhony1986
Ouch guard I've also what they comment
I just up the thread of fafa eric
The Following 2 Users Say Thank You to jhony1986 For This Useful Post:
Old 01-07-2011, 09:23   #4 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
I have the messages quoted from other thread
Just to keep clean Updates Thread
Originally Posted by eric_mce View Post
please support ku9100 cyon phones
Originally Posted by Electroboys View Post
Hi ,
SU910 / KU9100 Repair Dead Boot is already supported for a long time
Releated Pinouts / Dump / Repair Files are available in support area
Best Regards
Oz.
hi,
please send me via pm about procedure, tools version , cable difinition , etc,etc, on my ku9100 dead boot..
im new in this tool and i want you to assist me.
thanks
LG SU910 / KU9100 Repair Guide
After Making Succesfull Connections accordingly to : JTAG Pinouts
1- Power on phone (it may not power on due to dead boot)
2- Start Software ( ORT Plus Latest Version )
3- Click Scan & After having the phone detected !
4- Select File "LG-SU910_KU9100_0x00000000_8M.bin"
5- Click Write & Wait for process to finish !
if not get detected @ Step 3:
#You may need to use PS_HOLD "Look for PS_HOLD point on the pcb and learn how to use PS_HOLD in Master Manual in support area
Find out you really need PS_HOLD ?
#Powering on the phone VREF Pin should give 2.6V !
#if 2.6V not exist even you powered on , you need PS_HOLD !
What else you can do without PS_HOLD ?
#You can hold power button pressed during the operation time
#But PS_HOLD is recommended
PS_HOLD Usage Summary :
#Connect PS_HOLD 4.7K resistor and connect to battery !
After having succesfully written please disconnect !
You may need to flash your phone with original firmware and flasher !
Smiliar Manual and new Pinout pictures uploaded to support area
Best Regards
ORT-JTAG
cable connection is very important before doing that procedue, please explain what color what name on cable.
only pinout on pcb in your support
please
Do you have Rainbow cable in hand that comes in package ?
Actually on the picture there is front view of the cable !
I will post a picture very soon .
But Accordingly to last cables we shipped !
1-VREF(Black)
3-TRST (Grey)
5-TDI (Blue)
7-TMS (Yellow)
9-TCK (Red)
11-RTCK (Black)
13-TDO (Grey)
15-RST (Blue)
16-GND (Green)
Best Regards
Oz.
Old 01-07-2011, 09:47   #5 (permalink)
Member: 6594
Sonork: 100.27285
Here is the cable view !
Colors are not important but order is important 1 is always 1 !
In this Cable view Pin 1 is Black but it may change if it is connected as twisted in that case Pin 1 would be brown
but the main point is the Order Of Connector ( HEADER ) always the same !
Most our old customers only received grey color cables with no color at all in that cables Red Marked pins were Pin1
Best Regards
Oz.
The Following User Says Thank You to Electroboys For This Useful Post:
Old 01-07-2011, 10:34   #6 (permalink)
Member: 6594
Sonork: 100.27285
Hi
If you are first time user and keep getting Unknown CPU ID immediately !
  • Start ORT Plus V1.00
  • Disconnect ORT from USB & Connect Again
  • Start ORT Plus ( Latest Version )
Best Regards
Oz
The Following 3 Users Say Thank You to Electroboys For This Useful Post:
Old 01-07-2011, 11:30   #7 (permalink)
Member: 1110882
edit
thanks
electroboys
Old 01-08-2011, 02:33   #8 (permalink)
Member: 502531
Hi
Best Regards
Oz
error sir!
Old 01-08-2011, 02:46   #9 (permalink)
Member: 502531
hi,
please upload pinout image on pcb.
Old 01-08-2011, 04:27   #10 (permalink)
Member: 502531
update!!
electro boys need your help.
Old 01-08-2011, 11:22   #11 (permalink)
Member: 6594
Sonork: 100.27285
  • You should know the some basics !
  • You have to solder pins to correct places !
  • We are dealing with MSM 6280 usually requires PS_HOLD
  • You should supply battery / Power supply phone as if it is working
  • Power On Phone before starting any operation and then only Start Software
  • Flash ID 0x0000 is not valid , Flash ID 0x1442 is not valid , Flash ID 0xFFFE is not valid
If you see any of those flash ID's above reset connection and start software again !
After it is connected Write the file ,
Check the picture first if you have any questions we have to clear them !
Best Regards
Oz.
Old 01-08-2011, 11:30   #12 (permalink)
Member: 502531
@Electroboys
thanks for the very clear procedure and image
i just post here tomorow for the result!!
wish me luck.
Old 01-08-2011, 11:32   #13 (permalink)
Member: 6594
Sonork: 100.27285
You have ORT instead of luck
Something much better
Best Regards
Oz
Old 01-08-2011, 11:43   #14 (permalink)
Member: 502531
followup question sir..
the redline on image says that need 4.2 supply? is it safe to direct with power supply with 4.2 voltage?
how about 4.7khom? where i can find that?
Old 01-08-2011, 15:58   #15 (permalink)
Member: 6594
Sonork: 100.27285
When actually battery fully charged is about 4.2 ~ 4.3 V
So you can use fully charged original battery or 4.2V power supply !
Finding 4.7K ohm
Do you have any Mobile phone Chargers made in china because less cost !
Break one of them inside a lot of resistor
4.7Kohm color order would be ;
Yellow+Violet+Red + gold or silver at the end .
Here is your Guide
Best Regards
Oz.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.40784 seconds with 11 queries
