Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > PRODUCTS SUPPORT
Old 07-24-2010, 16:26   #1 (permalink)
SMDSAFE's Avatar
Member: 311990
ufc4 5330 flashing in atf
5330 log report 100% WORKING IN UFC4
FBUS_TX is High...
MCU: V 06.80 02-03-10 RM-615 (c) Nokia
IMEI: 358319030762498
Product code : 0597636
Model : Nokia 5330
******** Reading SimLock ********
Simlock Version : SIMLOCK SERVER
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
PM 120 Found...
PM 308 Found...
Certificate saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 06.80 02-03-10 RM-615 (c) Nokia_358319030762498_Not Locked_104503.pm
Changing MODE : FLASH
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02044100
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000C35
3 ROM_ID 15
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 1360010D
ID DWORD 1 : D4070049
ID DWORD 2 : 0AC5EDFC
ID DWORD 3 : 60F7684B
ID DWORD 4 : 3B188CFC
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 03
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 05
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0321
Checksum : 27
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0321
RAP3Gv40_XSR17_alg.fg
First Algo byte : 56
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 00800000 (8388608)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
START READING RPL DATA
Reading : NPC
OK
Reading : VARIANT
VARIANT : Empty
Reading : CCC
OK
Reading : HWC
OK
Reading : R&D
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\358319030762498\3583190307624 98_104514.rpl
FlashInfo.RestartMode : 2
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-615\rm615__06.80.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
CMT Supported Hardwares :
> 0203192102004100
> 020C192102004100
> 0203192102024100
> 020C192102024100
> 0203192102044100
> 020C192102044100
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 19500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 152
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 03
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok
Using Internal VPP
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 0004
Partition 1
Attribute : 00000002
Start Address : 000A0000
Partition 2
Partition 3
Partition 4
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A0000028A0000000000080000000102E40000049800 000000000A00000001077C0000003800000000000B00000001 07B4000000180000B1
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x00E1 (225)
ERASE Blocks : 0x0004 (4)
erase blocks : 4
CurrPos : 03
CurrEraseLen : 4B
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-0115FFFF
5 : 02040000-0205FFFF
6 : 02940000-02E3FFFF
7 : 077C0000-07B3FFFF
8 : 01160000-0203FFFF
CurrPos : 50
CurrEraseLen : 2F
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID :0x02000000
Format Info :0000000000000008000000000000000200000064000000020 000000200000001000000000000
CurrPos : 81
CurrEraseLen : 2F
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000A000000010000000200000064000000020 000000200000001000000000000
CurrPos : B2
CurrEraseLen : 2F
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000B000000000000000200000064000000020 000000200000001000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E00000115FFFF120B000300020400 000205FFFF120B0003000294000002E3FFFF120B000300077C 000007B3FFFF120B000300011600000203FFFFB2
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 0002000000640000000200000002000000010000000000003E
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Successfully erased..
Time Taken to Erase : 00:00:01
Is Flashing CLOCK AUTO : -1
Processing : rm615__06.80.mcusw
Total blocks to write : 152
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:18
Making delay between files for 5000ms
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-615\rm615__06.80.ppm_a
CMT Type : BB5
> 0203192102004100
> 020C192102004100
> 0203192102024100
> 020C192102024100
> 0203192102044100
> 020C192102044100
Number of Blocks : 29
Entry Point: 0x011D
Page Format : -1
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 03
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok
Using Internal VPP
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x000E (14)
ERASE Blocks : 0x0001 (1)
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
Block Length : 0x0B (11)
Device Index : 0x00
0 : 02060000-0293FFFF
ERASE_REQUEST_BB5 : 5001120B000300020600000293FFFF43
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Erase : 00:00:00
Processing : rm615__06.80.ppm_a
Total blocks to write : 29
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:05
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-615\rm615__06.80.image_a_0592278_003
CMT Type : BB5
> 0203192102004100
> 020C192102004100
> 0203192102024100
> 020C192102024100
> 0203192102044100
> 020C192102044100
Number of Blocks : 45
Entry Point: 0x0154
Page Format : -1
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 03
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok
Using Internal VPP
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x003F (63)
ERASE Blocks : 0x0002 (2)
erase blocks : 2
CurrPos : 03
CurrEraseLen : 0B
Device Index : 0x00
0 : 02E40000-077BFFFF
CurrPos : 10
CurrEraseLen : 2F
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002E40000077BFFFF78
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm615__06.80.image_a_0592278_003
Total blocks to write : 45
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:07
Total Flash Write Time (Flashing Only) : 00:00:31
Total Flashing Time (Booting + Erase + Flashing) : 00:00:45
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-31-1999 04:35
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.33183 seconds with 11 queries
