Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Martech products > Martech Analyzer / Laptops / Batteries
Old 06-08-2010, 00:23   #31 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Z60 you treat as EEPROM Type LSI
Locating the Z60 connection points
Switch the Z60 OFF.
You should have downloaded the hardware Maintenance Manual already, if you have not done so,
Click on the hyperlink below to download the PDF file containing the Z60 Hardware Maintenance Manual, you will need to install Adobe Acrobat Reader to view the manual, Adobe Acrobat is FREE and can be obtained here -> Adobe Downloads once you have downloaded the files, close the browser window to return to this page.
<b> Hardware Maintenance Manual - ThinkPad Z60t
Hardware Maintenance Manual - ThinkPad Z60m
It is best to Right Click on the link above then Save "Target as" that way you will have a copy of the PDF file on your PC.
</b>
Once you have your HMM search the manual for "Removing and replacing a FRU" then scroll down to 1200 System Board, it's on Page 97 of the manual, follow the instructions in the manual to remove all the other FRUs to gain access to and remove the System Board.
You need to access the pads underneath the Intel 82801GBM as illustrated below.
This is not easy, you will need to have the Keyboard and LCD plugged into the system board in such a way that none touch any contacts on the system board, use paper as an insulator to keep things from electrically shorting out, later you will need to plug in the AC adaptor and switch on the TP while holding 3 probes to the GND SCL and SDA points under the system board. Do NOT switch ON the Z60 now, that will be done LATER.
Assembling your TP
You need to re-assemble your TP as you will have to have it switched ON and running to read the eeprom.
Follow the Hardware Maintenance Manual [FRU System Board], very carefully, double check screw type and size for each individual module. Assemble the TP in the reverse order used to dismantle it.
ABOUSHADY
The Following 5 Users Say Thank You to ABOUSHADY For This Useful Post:
Old 06-08-2010, 00:26   #32 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
I hope that my hard work does not go for nothing
ABOUSHADY
The Following 4 Users Say Thank You to ABOUSHADY For This Useful Post:
Old 06-08-2010, 02:05   #33 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
here VIDEO exemple from MARTECH-SBS SUPPORT
REMOVE PASSWORD BIOS FROM IBM thinkpad X61
RapidShare: 1-CLICK Web hosting - Easy Filehosting
ABOUSHADY
Old 12-08-2010, 00:07   #34 (permalink)
Member: 1030375
Sonork: aziiiz
please Z61t pinout
thnx
Old 12-19-2010, 16:01   #35 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Send your pcb photos.
Old 01-08-2011, 14:29   #36 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
here auther model good eeprom location
SL410 & SL510 - Looks like the new SL series switched from AMI to Phoenix FirstBIOS so our old friend (24RF08 - PS08) is back in business once again. R24RF08/W24RF08 is the right software, as usual.
*The older SL400/SL500 still need the SPEG programmer to be unlocked
ABOUSHADY
The Following User Says Thank You to ABOUSHADY For This Useful Post:
Old 01-08-2011, 14:33   #37 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
T410, T510
T410 and T510 eeprom here:
ABOUSHADY
Old 01-08-2011, 14:35   #38 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
here good pic pcb ibm L412/ L512
ABOUSHADY
Old 02-06-2011, 23:08   #39 (permalink)
Member: 1460887
I have unlocked T42 and R40 with the interface for 24RF08 and the R24C01 reader. How can I read PC8394T ? Can I read this eeprom with the interface for 24RF08? What reader I need and from where? I`m begginer in this domain. Please help me!
Old 02-11-2011, 19:08   #40 (permalink)
Brka's Avatar
Member: 163
ABOUSHADY
i can understand many crap,
but copy/paste from Joe from australia page should be somehow too lame
and probably illegal, without contacting author of that site, right ?
we should contact admins anout this crap,
and original author too, since this kind of actions
i see more and more everyday here ...
no b.r. for lamers.
Old 07-03-2012, 13:40   #41 (permalink)
Member: 142281
Help
Please can you help me IBM T42
I have connect the pins to the eeprom but when i try to read it I become: eeprom not found
I have make the cable from this site
http://sodoityourself.com/hacking-ib...bios-password/
Old 07-03-2012, 14:45   #42 (permalink)
Member: 142281
I make it
cable pins where worng
Old 11-24-2012, 00:24   #43 (permalink)
Member: 656666
Found PC8394T.1.0d.rar reader writer but password protected.
maybe someone will crack rar pass
link:
PC8394T.1.0d.rar
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 1.43483 seconds with 12 queries
