Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Martech products > Martech Analyzer / Laptops / Batteries
Old 07-29-2009, 12:06   #1 (permalink)
MARTECH's Avatar
Member: 78421
Martech Analyzer update on 29/07/2009
- ability of battery regenerating added
- chineese Manual
It looks as following:
1. you connect the battery
2. you select proper settings from menu
3. you start the process..........
and it's ready
a detailed description is to be found in the manual
- In English: http://martech.pl/download/ANALYZER/..._manual_en.pdf
- In Polish: http://martech.pl/download/ANALYZER/..._manual_pl.pdf
- IN China: http://martech.pl/download/ANALYZER/...al_chinese.pdf
Martech Shop: http://martech.pl/eshop/
Sales department contact:
alcatel@martech.pl Icq: 471764678 sonork 100.110305
http://martech.pl/download/ALC/ALC.zip
http://martech.pl/download/ALC/ALC2.zip
http://martech.pl/download/MDM/MDM.zip
http://martech.pl/download/SIEM/SIEM.zip
http://martech.pl/download/VSZ/VSZ.zip
http://martech.pl/download/RCD/rcd.zip
Martech Team
www.martech.pl
Old 07-31-2009, 15:37   #2 (permalink)
Holden's Avatar
Member: 11400
Sonork: 100.110305
Thumbs up Martech Analyzer Updates - in this topic
Martech Analyzer Update - 31.07.2009
New functions added:
- Analyzer Print Client (APC) released.
This is special PC application which allow to print test directly from PC.
APC works with PB232 Analyzer, supporting printing test raports and summaries.
Currently supported two modes for printing :
- printing test from the function which analyze link resistance (this consist from
electrical resistance of link and its ionic resistance)
- printing test from regenerate / forming process
Other options:
- printing tests is improved
- special functions to add company name on print test header
- APC is available in English and Polish (more will come, if you havel
questions then feel free to contact technical support at support@martech.pl).
APC is available in English and Polish language.
We will add special module to induce Li-Jon batteries soon.
Firwmare Updater new version:
- corrected bug connected to unstable measurement on external temperature driver
- the range of initial charge and discharge current is increased
- regenerate function is amplified to PreForming and PostForming
APC v1.0 EN:
http://martech.pl/download/ANALYZER/APC_v10_EN.exe
APC v1.0 PL:
http://martech.pl/download/ANALYZER/APC_v10_PL.exe
Firmware Updater :
http://martech.pl/download/ANALYZER/...43_0003_EN.exe
We are waiting for comments and replies.
Be READY ! For next BIG updates
Martech Team
The Following 3 Users Say Thank You to Holden For This Useful Post:
Old 08-06-2009, 12:57   #3 (permalink)
MARTECH's Avatar
Member: 78421
Adapter XC1 for Martech 06/08/2009
Adapter XC1 for Martech Analyzer it's battery adapter for new released power supply/battery tester from Martech that allows you easy and fast connect any battery for performing regneration procvess, charge, test or discharge batetry. Adapter was created with coolaboration with Martech Team and are fully supported with PB243 device - using dedicated temperature control unit for measure battery temperature while process running to not allow overload and burn battery.
Specification:
- build in temperature control unit for Martech Anaylzer
- cage for battery are easly adjusted to match yoru batteries
- max size of battery tested (cage dimmension): 85mm x 85mm
- max height of battery tested (cage dimmension): 28mm
NOTE: Height as lenght of battery can be bigger that adapter area - int this situation it will be over workign area of adapter. This can happend while testign big batteries as camera unit etc.
http://www.multi-com.pl/index.php/en...ategories.html
Old 08-07-2009, 15:32   #4 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer V00.04 07/08/2009
Firmware v 00.04 has been supplemented with:
- amendments in energy governing PowerDown mode_
- amendments within Discharge Mode
- functions of evoking Lit battery chemistry (Review) in the area of Charging Mode
- Batteries of Lit chemistry are fitted with supervising links work electronics
- Those systems, among others protect the lin ks against their discharging
It is stated that allowed discharging threshold is 3V per one link-
- after exceeding this threshold, the battery electronics disconects the battery exit, which results as a zero voltage of such a battery
Some batteries have got electronics which limits the link possibilities which results strongly lowered initial voltage.
Such batteries are able to stillbe used, they sould only be stimulated in a proper way.
How do the stimulating links functions work?- Reviev in PB243: PB 243 Analyzer as a standard, after detecting too low amperage or lack
of battery, shows the following info:"Too Low Battery Voltage"
"Check Battery Connection"- in case of connecting battery with cramps in incorrect way
or " Discharging Error"Check Battery Settings"- in cas eof coonecting wrong battery type
In a lowe verse of alerts:
"Press Flash to Reviev..."
"Press Esc to exit mode..."
The same messages may appear if we have the battery demanding stimulation
At this point, if we are not sure of correct battery connection as well as correct settings, we press the upper button with a
charging icon (Flash)- and the process of stimulation will start, which is going to be confirmed with a message ""Reviving Process".
The reviving proces take splace until the battery voltage reaches the value of at least 3V/ link with an amperage between the range of 50...250mA.
The reviving process has been qdeveloped due to links security.
After reaching the voltage threshold, the analyzer will conduct the usual charging cycle with the parameters declared in Settings window.
Empirical research show that the whole reviving process is different and it depends on links condition, although it has never lasted longer than 12 minutes.
We advise against the battery reviving using" short connection" method, uncontrolled electricity results in ofen damages of battery chemistry.
Because we owe a limited amount of damaged batteries, we ask for opinions regarding analyzer functioning.
All your remarks as well as suggestions ae welcomed at support@martech.pl or at a suitable section on our forum
Best Regards
Martech Team
The Following User Says Thank You to Tech mobil For This Useful Post:
Old 08-28-2009, 10:36   #5 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Update - 28.08.2009
New Firmware V 00.05 with following possibilites:
1. Added directly managing from PC (BatteryCharger mode) for application PB243_manager
2. Corrected service of cooling driver by using HOME functions (PowerSupply mode)
3. Added information about firmware veresion after first connecting
4. Fixed HOME functions - parameters reset
PB243 Analyzer Manager v1.0:
Battery Analyzer Manager – function description:
- Battery Analyzer Manager added easy database for individual details of batteries and cells
- Adding field works by typing into Battery Description field and choosing parameters
- Removing works by selecting desired field and clicking on „Remove Battery From Database” button
- Changing parameters and saving it is possible by clicking on „Approve Changes”
v1.0 is beta version, we are waiting for users feedbacks on support@martech.pl
Latest firmware:
http://martech.pl/download/ANALYZER/...43_0005_EN.rar
Latest version of PB243 Manager:
http://martech.pl/download/ANALYZER/...10_Beta_EN.rar
The Following 2 Users Say Thank You to Tech mobil For This Useful Post:
Old 09-03-2009, 10:05   #6 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer V00.06 03/09/2009
Martech Analyzer Update - 03.09.2009
New Firmware V 00.06 with following possibilites:
1. Discharge process is optimized
2. Added Polish language in Analyzer Menu
Latest PB243 firmware (English) :
http://martech.pl/download/ANALYZER/...43_0006_EN.rar
Latest PB243 firmware (Polish) :
http://martech.pl/download/ANALYZER/...43_0006_PL.rar
For end users and resellers:
We can add all possible languages for desired country (arabic alphabet only).
Best regards
Martech Team
Old 09-03-2009, 16:54   #7 (permalink)
Member: 307373
great update good team..............................
The Following User Says Thank You to div_859 For This Useful Post:
Old 09-18-2009, 17:07   #8 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Big Upadate 18.09.2009
Martech Analyzer Update - 18.09.2009
New Firmware V 00.07 with following possibilites:
1. From this firmware it's possible to transmit measurement data directly to PC.
You can receive and watch it via PB234 Manager.
2. PB243 Manager version v11 with additional modules :
- Ubatt = f(t), battery voltage in time function (Charging, Discharging, Regeneration modes)
- Ibatt = f(t), battery current in time function (Charging, Discharging, Regeneration modes)
- Tbatt = f(t), battery temperature in time function (Charging, Discharging, Regeneration modes)
You can do zoom in on graphic diagram to see more detailed part of characteristic.
We will add more function like printing diagrams, saving it and opening from files.
We look forward for comments and feedbacks on support@martech.pl
Public Support http://martech.pl/support/
Forum English http://martech.pl/forum/viewforum.ph...0814100c00c2a8
Forum Polisch http://martech.pl/forum/viewforum.ph...0814100c00c2a8
Forum Rusian http://martech.pl/forum/viewforum.ph...0814100c00c2a8
Forum French http://martech.pl/forum/viewforum.ph...0814100c00c2a8
Forum Spanisch http://martech.pl/forum/viewforum.ph...0814100c00c2a8
Forum Arabic http://martech.pl/forum/viewforum.ph...0814100c00c2a8
http://martech.pl/download/ANALYZER/...43_0007_EN.zip
http://martech.pl/download/ANALYZER/...43_0007_PL.zip
Latest PB234 Manager:
http://martech.pl/download/ANALYZER/...r_v11_Beta.zip
Best regards
Martech Team
Old 09-23-2009, 18:36   #9 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Update - 23.09.2009
Martech Analyzer Manager V1.2 - new option for printing characteristics.
Graphic diagrams are placed on one common sheet. Scaling on sheet is prepared in
special way, it's optimized independently of size and direction.
The area of characetistic presentation is optimized also.
Next update will allow to save and read measurement data.
http://martech.pl/support/Martech%20...r_v12_Beta.exe
Best regards
Martech Team
Old 10-02-2009, 11:04   #10 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Update - 02.10.2009
New functions:
Analyzer Manager v13 is udpated for new possibilites:
- Reading registration data via AM
WIth this function you get check registration, serial number, hardware version and analyzer firmware
- Cleaning function for diagram windows
- Turning on/off measurement data in process of graphic analysis
- Saving data to file from charging, discharging, regenerate process
- Reading data from file
- Animated process of : charging, discharging, regenerate by using data from file
Since now you can analyse whole process in time function !
Animation function are selected in special way, you will see whole process saved before.
PB243_Manager_v13_Beta
Best regards
Martech Team
Old 10-02-2009, 11:09   #11 (permalink)
pathfinder333's Avatar
Member: 954575
New functions:
Best regards
Martech Team
great update...
go martech team....
Old 10-07-2009, 16:33   #12 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Analyzer Update: 07/10/2009
- PB243 Manager v14
Corrected saving function and user registration.
SBS Tools is free for all Analyzer owners (tool for resetting
charging cycles and production date).
English Forum http://martech.pl/forum/viewforum.php?f=2
Polish Forum http://martech.pl/forum/viewforum.php?f=9
Russian Forum http://martech.pl/forum/viewforum.php?f=6
Frenh Forum http://martech.pl/forum/viewforum.php?f=26
Spanish Forum http://martech.pl/forum/viewforum.php?f=25
Arabic Forum http://martech.pl/forum/viewforum.php?f=27
Turkish Forum http://martech.pl/forum/viewforum.php?f=29
Martech Team
www.martech.pl
www.martech.pl/shop/
www.martech.pl/forum/
www.martech.pl/server/
Old 11-03-2009, 06:13   #13 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Update 03/11/2009
Martech Analyzer Update 02/11/2009
Firmware v00.08:
- the correction of electricity measurement presentation mistake in Powe Supply mode
-possibility of firmware changing within the sae firmware version
(earlier versions have blocked that possibility)
Manager database- Nokia, Samsung batteries added
- special thanks to Wojtek Góralczyk (wgmmmx)
Old 11-10-2009, 18:35   #14 (permalink)
Registered User
Member: 811992
Sonork: 100.1584257
Thanks for the infromationen!
Old 12-15-2009, 19:23   #15 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Martech Analyzer Update - 15.12.2009
Firmware v00.09
Major changes in update:
- Exit/Cancel charging mode is improved
- Stabilization of charger mode
- Charging function is increased
Marginal changes:
- Code optimisation regarding call out procedures
- Braeaks process optimisation
http://martech.pl/download/ANALYZER/...43_0009_EN.zip
http://martech.pl/download/ANALYZER/...43_0009_PL.exe
Best regards
Martech Team
RCD / DST / SQM Tools - updates in this topic MARTECH MARTECH CARS Category 234 04-24-2013 11:01
VSZ Service Tools - updates in this topic Holden VSZ Service Tools 101 09-20-2010 11:31
Martech Analyzer Update 31.07.2009 Holden GSM News & Updates 0 07-31-2009 14:57
Martech Analyzer Update - printing tests Tech mobil GSM News & Updates 0 07-25-2009 09:46
Page generated in 0.58880 seconds with 11 queries
