Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 10-29-2014, 10:21   #1 (permalink)
Member: 310822
Sonork: ALIAS: POLITEHNICA_1921
Thanks Meter: 9
Allview hardware repair
I have allview p5 quad (water damage) and it power on only if 5v from external power source ... but if voltage lower .. 3.7-4 ...from power suply or battery .. it doesn't boot. any suggestions ? tnx in advance
Old 10-29-2014, 11:17   #2 (permalink)
Member: 310822
Thanks Meter: 9
photos of board
Old 10-30-2014, 23:44   #3 (permalink)
bighiner's Avatar
Member: 679176
Sonork: 1585224
Thanks Meter: 119
consum, some capacitorslook dameged
br,
Pr3dict3r
Old 11-18-2014, 16:53   #4 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 38
possible fix
Try clean up each capacitor with glass fiber pencil and check again voltaje with multimeter on each ceramic capacitor. Ask on provider the schematic of your pcb, people form Brasov are very polite and helpfull. If have possibility of a capacitometer aim you of patientcy and mesure each one of ic power surrounding área.
Good luck.
The Following User Says Thank You to dcosmin22 For This Useful Post:
Old 04-15-2015, 15:42   #5 (permalink)
Member: 1789225
Sonork: talecomnecation
Thanks Meter: 31
br flow instraction dcosmin22 & hot with 100w blob 30min after that not ok then flash with same file then not booting short kcolo & gnd.i hope it will help you?
Old 05-30-2015, 06:21   #6 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Battery Problem Use Orignal Battery No More ISsSU Replace Btry
Page generated in 0.12935 seconds with 8 queries
