Go Back   GSM-Forum > Hardware Repair > Hardware Repair
Hardware Repair all about Hardware-Problems. For Nokia, Samsung, Siemens, SonyEricsson and Motorola, Alcatel & LG Hardware please visit our specific subforum:
Old 05-13-2009, 16:10   #1 (permalink)
Member: 539038
Question how to check capacitor?
how to check capacitor with digital multimeter?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 05-13-2009, 18:44   #2 (permalink)
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
You can use your multimeter as an ohmmeter to test the capacitor.
1) Discharge the capacitor by shortening its leads. That is - use a wire and connect the leads of the capacitor together. This will discharge it.
2) put your multimeter in the high ranges 10K-1M
3)CONNECT MULTIMETER TO CAPACITOR LEADS(OBSERVE THE POLARITY IF ELECTROLYTIC). AT SOON AS THE LEADS MAKE CONTACT, THE METER WILL SWING NEAR ZERO. IT WILL THEN MOVE SLOWLY TOWARD INFINITY. FINALLY THE METER WOULD COME TO BE INFINITE OHMS BECAUSE THE CAPACITOR IS BEING CHARGED BY THE BATTERY OF THE MULTIMETER.
4) IF THE CAPACITOR IS BAD, IT WILL GO TO ZERO OHMS AND REMAIN THERE. THIS IS CALLED A SHORTENED CAPACITOR
5) IN THE CASE OF AN OPEN CAPACITOR THERE WILL BE NO OHMMETER INDICATION.
6)SOME CAPACITORS HAVE A LOW DIELECTRIC LEAKAGE. YOU WILL KNOW THIS IF THE OHMMETER COMES TO REST AT A POINT LOWER THAN INFINITE. TEST A KNOWN GOOD CAPACITOR OF THE SAME TYPE TO BE SURE .
This method will work with sufficiently large capacitor values.
A simple way of determining the capacitance fairly accurately is to build an oscillator using a 555 timer. Substitute the cap in the circuit and then calculate the C value from the frequency. With a few resistor values, this will work over quite a wide range.
Alternatively, using a DC power supply and series resistor, capacitance can be calculated by measuring the rise time to 63% of the power supply voltage from T=RC or C=T/R.
Tiny capacitors can only be checked with a capacitance meter, or by using them in an AC circuit and checking for variation from calculated voltage drop.
The Following User Says Thank You to loca|host For This Useful Post:
Old 05-22-2009, 20:30   #3 (permalink)
Member: 539038
how to check capacitors in mobile?same way or different way
The Following User Says Thank You to srikanthreddy For This Useful Post:
Old 05-22-2009, 20:48   #4 (permalink)
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Old 05-23-2009, 13:52   #5 (permalink)
Member: 149135
Best way is to chek whit ESR-meter..and whit capacitor meter! Whit digital multimeter is difficult..best is analogic multimeter! First you need to see if is in shortcut!!
Old 05-26-2009, 22:52   #6 (permalink)
Member: 910598
Sonork: moon786
use analog meter then ushold be able to check
Old 01-07-2012, 02:44   #7 (permalink)
Member: 675260
check capacitor
How to use an LCR Meter - YouTube
I hope this helps you LCR Meter
Old 01-09-2012, 13:32   #8 (permalink)
Angello's Avatar
Member: 19927
The past is the past, the present is the present and future is the future.
I hope this picture can help you.
Old 01-16-2012, 00:43   #9 (permalink)
Member: 675260
Forum for all and not for you alone
This forum for all
Can benefit people in the future from this participation
You seem to not understand the usefulness of this Forum
Say something useful this topic. Or Hist .
Old 02-15-2012, 09:09   #10 (permalink)
Member: 1658162
Sonork: 1234567890
how to check multimeter
Old 02-16-2012, 17:21   #11 (permalink)
ucokmonalisa's Avatar
Member: 527741
A Simple Way to Test Capacitors.
http://ucokmonalisacom.blogspot.com/...citorhtml.html
How to check serial to know if i have to pay or not Millo_6 NSPRO 7 09-30-2009 01:26
how to install capacitors to pcb wangbungal Nokia Base Band 5 ( BB-5 ) 1 08-15-2009 17:58
how to check how much log/credit left on micro?? khem Basic Micro-Box Software Support 2 04-01-2009 00:15
how to check value capacitor [used in 5300 for mmc jumper] lease help me shivam4you Nokia Hardware & Hardware-Repair Area 0 01-21-2009 05:42
How to check if the 3310 is shorted? (how to use multimeter for checking the line) sapatos Nokia Hardware & Hardware-Repair Area 3 09-04-2005 10:33
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 2.09488 seconds with 11 queries
