Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
04-07-2002, 06:12 | #1 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | Interesting GD90 Network Problem ??? I encountered a new problem in GD90.Phone finds the network but never call.I entered Checkbox program and tested TX Power Levels , a radio near the phone gives a lot of loudly noises like normal working phones.I saw that No product number in Checkbox program and i entered them using Ghost program.Now in Checkbow there is a "ST IN" section and it is blank.Normal working phones gives "00000000" there.Phone doesn't make call. I changed Filters and PA but nothing has changed.Changed also IMEI.nothing... How can i solve this problem ? Best Regards... |
04-07-2002, 22:32 | #2 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | If you think PA is OK, check the baseband. Hi! If you've checked the PA (I also use a radio to make some checks on PAs ) , I think the fault could be in the baseband, expecially in the CPU of FLASH ic. I've repaired a lot of PANASONIC GD 90 with this fault resoldering FLASH first, and CPU if the fault remain. Try it and let me know if it works... |
04-08-2002, 12:53 | #3 (permalink) |
Member: 1623 Status: Offline Thanks Meter: 1 | nothing has changed. :-( Hi, I tried resolder FLASH and CPU but nothing.Phone receiving Bar is full but finds network about 20 seconds later after power on the phone. What is "ST IN" in checkbox program ? Best Regards... |
network problem for AT&T network | sachinvij1 | Chinese Models & Cloned Phones | 0 | 03-16-2008 16:45 |
LG 8138 network problems with 3G networks | dead_dogy | LG | 1 | 03-14-2006 14:20 |
gd90 flash problem | dimon | Panasonic | 1 | 01-12-2004 23:36 |
3310 interesting network problem | hs_ | Nokia Hardware & Hardware Repair | 9 | 11-06-2002 08:35 |
Gd90 b16 problem | Bigbrothers2000 | Panasonic | 0 | 09-14-2000 20:51 |
