Unlock Server
Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 09-30-2002, 20:33   #1 (permalink)
Member: 3714
J5 no AUDIO - no buzzer, no vibra, no mic, no earphone...
Hello,
i have changed blue leds in many J5/J6 phones, but after
changing LEDs in this phone it stopped ringing,vibrating
and earphone and mic is dead too
anyone can help?
Platy
Old 10-01-2002, 10:53   #2 (permalink)
Member: 7767
*#superfactoryreset#
Old 10-02-2002, 13:18   #3 (permalink)
themobileking's Avatar
Member: 5072
no thats wont work.
you have probably damaged or some component has got removed from the pcb.Also possible is shorting of any part when you are working with the soldering iron.check carefully near all the led's that you have replaced for shorting or missing parts,
rgds
Old 10-02-2002, 18:14   #4 (permalink)
Member: 12724
Good time.
check the place wich the flat connects to the PCB.
theses all you have mentioned are on the flat and when you have used sth hot on it have damaged the flat.
LIGHT
Old 10-04-2002, 14:27   #5 (permalink)
Member: 3714
Hello, i am not lamer, i know that i could shorted something. PCB
is really CLEAN and flat cable with connector is OK too! There is
not only ringer problem, but speaker and mic too!
plaese help!
Platy
Old 10-05-2002, 06:29   #6 (permalink)
mobilemafia's Avatar
Member: 7889
your strip is faulty
change and post result
Old 10-05-2002, 21:18   #7 (permalink)
Member: 3714
STRIP? what do you mean? strip=flat cable?
i tryed flat cable from another phone and it is not faulty
Platy
plz halp mé e250v after flashe no buzzer no audio rrouny Samsung Flashers, Software, Firmware. 6 09-18-2008 21:57
plz halp mé e250v after flashe no buzzer no audio rrouny Samsung Flashers, Software, Firmware. 1 09-18-2008 15:25
X150 no buzzer n vibra GGet007 Trident/AGERE Platform 0 08-08-2008 12:19
MOTORIZR Z8 - No Display, Audio-no MIC, No turn on, Camera -image view SmartFlasher™ Motorola Hardware Repair Section 0 03-30-2008 23:57
1600 no ringing tone but works speaker and mic no vibrator oranz Nokia Hardware & Hardware-Repair Area 5 01-27-2008 15:51
Page generated in 2.50887 seconds with 11 queries
