08-09-2014, 04:28 | #1 (permalink) |
Junior Member Join Date: Mar 2011 Location: raipur Age: 31
Member: 1529198 Status: Offline Sonork: [email protected] Thanks Meter: 1 | nokia c1 dead problem solution |
The Following User Says Thank You to lokeshkumar112 For This Useful Post: |
08-17-2014, 08:19 | #8 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | c1 dead 1 change lcd 2 check lcd print for main board 3 Check BSI link 4 flash the fone 5 resold main Ic and Flash drive I think this is enough For Alive the fone |
08-17-2014, 09:19 | #9 (permalink) |
Junior Member Join Date: Apr 2008 Location: gen. mcarthur, e. samar
Member: 743997 Status: Offline Thanks Meter: 1 | make visual check up first, sometimes problems can easily be solved through visual check up...if no damage on lcd ribbon then try to make jumper but if problem still not solve by jumper then flash the phone... |
08-30-2014, 17:04 | #12 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Simply connect to power supply wait few second now press power bottom if phone taking 2/3 amh then its must lcd related problem If it makes auto sens in power supply show 2/4 amh auto then its hardware problem Still didn't find any sulotion for this tryed possible all changed all possible regisistor, diod, power comopnent,cpu,flash but this auto sens really a unknown fualt stll to me 1280,1616,c1,1800 all are same |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
