Old 08-09-2014, 04:28   #1 (permalink)
Member: 1529198
Arrow nokia c1 dead problem solution
please give me nokia c1 dead not charging problem solution.....
The Following User Says Thank You to lokeshkumar112 For This Useful Post:
Old 08-09-2014, 15:22   #2 (permalink)
Member: 1773939
Thanks Meter: 106
flash latest version then post result
The Following User Says Thank You to nokiaexpert.ns For This Useful Post:
Old 08-12-2014, 10:36   #3 (permalink)
Member: 2238922
Thanks Meter: 6
Resolder the mcu and to try
The Following User Says Thank You to Zouhayr For This Useful Post:
Old 08-12-2014, 11:09   #4 (permalink)
Member: 1991929
Thanks Meter: 102
try to flash first..................
The Following User Says Thank You to Yongitxt For This Useful Post:
Old 08-12-2014, 12:27   #5 (permalink)
Member: 1500010
Sonork: cybershot_23
if you are done in flashing but still no power,
check lcd connections..
Old 08-14-2014, 19:35   #6 (permalink)
Member: 2232011
1st wash it properly than give hit under 100 wat light 3 min than cheak charging section than flash
Old 08-15-2014, 08:12   #7 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
i would say clean the logic bord , then make reball of cpu
Old 08-17-2014, 08:19   #8 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
c1 dead
1 change lcd
2 check lcd print for main board
3 Check BSI link
4 flash the fone
5 resold main Ic and Flash drive
I think this is enough For Alive the fone
Old 08-17-2014, 09:19   #9 (permalink)
Member: 743997
make visual check up first, sometimes problems can easily be solved through visual check up...if no damage on lcd ribbon then try to make jumper but if problem still not solve by jumper then flash the phone...
Old 08-19-2014, 03:50   #10 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
check boot on usb and info if info coming then repalce lcd
The Following User Says Thank You to cheeni For This Useful Post:
Old 08-24-2014, 07:00   #11 (permalink)
kharimobiles's Avatar
Member: 1814389
Sonork: 100.1621147
Thanks Meter: 30
change lcd sloved ur problem ....................................
Old 08-30-2014, 17:04   #12 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
Simply connect to power supply wait few second
now press power bottom if phone taking 2/3 amh then its must lcd related problem
If it makes auto sens in power supply show 2/4 amh auto then its hardware problem
Still didn't find any sulotion for this tryed possible all changed all possible regisistor, diod, power comopnent,cpu,flash but this auto sens really a unknown fualt stll to me
1280,1616,c1,1800 all are same
The Following User Says Thank You to gsm mithun roy For This Useful Post:
Page generated in 0.54353 seconds with 8 queries
