Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
06-08-2001, 13:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Post here your Hardware Problems Try to post here Your All Hardware Problem for Any Mobile Phone. Here lots of people who r good in Repairing. Not only for Nokia, post topics for all type of Mobile hardware fault. We will Share our knowladge !!!!! |
The Following 2 Users Say Thank You to gsm_boy For This Useful Post: |
06-10-2001, 22:54 | #2 (permalink) |
Insane Poster Join Date: May 2001 Location: Europe
Member: 4747 Status: Offline Thanks Meter: 0 | Hi gsm_boy I have a small problem with my pana GD52... I cleaned it inside and after set it together,the volume of earphohe(not handsfree earph.) is so low. First time I thing,that it is in pins connecting the earphone to boadr.I used the CH-box to test it. When I turned the earphone vol up (in Ch-box) it looks that it's allright,but when I tested it with sim card,with standart calling,vol is so low At the end I was reflash GD52 with newest soft. and replace the pana. earphone with nokia earphone (the diameter of pana earph. and nokia earp. is the same) only I have had soldered two contacts there.. Now it's working good,but I feel,that it should be better... My question is: Is there anyway solution to volume up panas. earphone using some soft. that can change this information in flash (in Ch-box U can change the mic amp. too) OR Is there anybody who can sell me new original GD52 earphone??? Thanx for all replyes Looker |
06-11-2001, 05:51 | #3 (permalink) | |
Member: 4223 Status: Offline Thanks Meter: 4 | Quote:
U wrote that u've replaced it with Nokia Speacker and your problem was solved. I think u don't need to replace it with original one. Furthur if u need Original one I can provide it to u . And for Software I don't think that any software can Upgrade Speaker Volume if your Speaker is faulty(Only way is to replace the Speaker). | |
06-11-2001, 14:07 | #4 (permalink) |
Member: 4747 Status: Offline Thanks Meter: 0 | Hi gsm_boy thanx for reply. I was solved my problem by changing original sp. with Nokia sp. it's not best,but for me it's ok. I only wanted to know if the problem is in soft or in bad sp. About Ch-box: I think,that if U can to vol. up sp.phone much more than in standart mode (calling,pressing arrow up) U can to change some vol. information,but it's so hard (it's take long time with experimening) Now it's ok,but have second problem with soldered contact on Nok.sp.phone. Panas. feld down on the floor and sp.phone not work... It's bad soldered contact on this sp. phone... I will make batter job and it shold be oK. So end of pana sp phone problem... Today I had Alca 301 problem...I can't to pow.up,but when I repl. and get back battery,phone pow.up, but keyboard not work... Problem was in triple button in the midle of the phone. Man who used this phone,had plastic cover with a hole for this multifunktion button and it's all the problem. Problaby some watter come inside by this button and started oxided with board and some contacts. I mean the power but. (C) was always switched on and it's all problem.. Looker |
06-12-2001, 03:20 | #5 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | Hello Guys.... I have problem with my S25 Charging function. It cannot charging perfectly, always shut off at about 2 seconds and back normal about 2 seconds also. Can you help me?? And... where I can find hardware forum like this???? PLS Help |
06-12-2001, 06:11 | #6 (permalink) |
Member: 4747 Status: Offline Thanks Meter: 0 | Hi Bband, I have similar problem with C10, when I have empty batt. (phone switch off) I can't to switch it on (with charger too). I need to plug the batt on some pow.supply for a while (5min) and after then,I can to switch C10 on. And when I should have a full batt with charger plugged in(charging looks to be ok), I should see a flashing last quarter of the battery symbol,but it only show batt symbol (full) without any flashing). Thanx for all answers BeSt ReGaRdS Looker |
06-12-2001, 15:06 | #7 (permalink) | |
First of all clean the contacts at charging Connector...then check fuse and then Dialog IC dry solder...if not solved then replace it. Your problem must be Solved. Reply your Result here | |
06-18-2001, 07:44 | #8 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | One more problem PLS.... C 25 no buzzer (ringing), one transistor Short Circuit. When I pull out, on the PCB still short circuit. Where is voltage reference for buzzer anyway?? PLS Help Regards |
07-14-2001, 12:23 | #9 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | I have problem with 8810 no signal. I read somewhere about having three cases: No network found incomplete network list no access something like that. anyway the 8810 has no access. What component should i replace. I have another board that is contact service to get the parts from. Pls help. Thanks |
07-14-2001, 14:09 | #10 (permalink) | |
Hello Dear Hanukkah... U don't need to tempered your Any Phone... U can Repair your Both Phone(No network and Contact Service)... Mail me Pvtly... I'll Show u How to Come over this problem.. We'll try Our best. | |
07-15-2001, 12:21 | #11 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | gsm_boy check your mail pls and return to me. Thanks! <FONT COLOR="#ffff00" SIZE="1">[ 16 July 2001 04:03: Message edited 1 time, lastly by Hanukkah ]</font> |
07-20-2001, 03:16 | #13 (permalink) |
Freak Poster Join Date: Jul 2001
Member: 5364 Status: Offline Thanks Meter: 0 | Hi BBand Check the coil on k/pad side of MBU I think it is connected in circuit with the transistor that is why the board measures short.The coil is normally physically damaged by incorrectly opening the housing.It is the big coil on the right edge of the board & is part of your ringing circuit. |
07-20-2001, 08:37 | #15 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | Hi Cell r us, thanks for the reply. I 've found the problem on that coil, but It have been soldered very bad by someone. ( PCB broken ) I ' ve give it back to my friends, really give up....... BTW, do u have Siemens Service manual. I will buy if u give me offer. RGDS |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
Post all your hardware repair here | mersingcrew | Nokia Hardware & Hardware Repair | 0 | 02-17-2008 08:41 |
