Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 01-15-2006, 17:51   #1 (permalink)
Crazy Poster
Member: 59553
problem with sunkko 850 smd repair
please I need their help
I have a problem with sunkko 850 two in one
she has burnt 2 components
a transistor and a resistance.
please look at the picture
already send message to sunkko but they don't respond
if somebody has a same one he could look that components are or to take a picture to see them
Old 01-15-2006, 23:36   #2 (permalink)
naughtycell's Avatar
Member: 214350
Thanks Meter: 17
If you have an over temperature , it is a feature better than not enough temp.
well , no problem try on a scrap board , clean it well becuse dust and oxides insulates heat in and out .
adjust the air flow level according to the nozell diameter .
adjust the heat to just below propper degree , and let the machein works for 2 min to gain the desired temp level.
apply heat to sellected component , after the heat accumulates onboard the tin will melt ( if you see a change in color of components use lower temp level untill you reach the desired calibrage level ) , also increase it if it doesnt melt after some good time .
Notice that : old solder need's more time to melt , and heat sinking is different from point to point on the board , finally use flux .
Old 01-16-2006, 12:15   #3 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Nice bit of advice, but on this occassion not really relevent. He has a Sunko 850 which he has burnt out and he wants to know what the value is of those two components. One is a transistor and he believes the other is a resistor.
@daos I have a Sunko 850c but the board is different to yours so I cannot see what you are referring to in relation to mine, maybe the the "c" as 850c makes a difference. Maybe if you can tell me board component number ie R2 or TR1 they might be similar I can then tell you what mine are.
Old 01-16-2006, 20:26   #4 (permalink)
Member: 214350
Thanks Meter: 17
Oooups , and I gave a big lecture !!!
NB : may be it is a thyristor too ( T09 type ) but really he need's help
Old 01-16-2006, 22:09   #5 (permalink)
Bay
Member: 2920
Thanks Meter: 21
I used this , to repair and modify my Gordak, maybe it can help you
Old 07-31-2016, 16:55   #6 (permalink)
FSC
Member: 2949
I've just open my own SUNKKO 850, and maybe I can help you.
The transistor is label as: MAC97A6
MAC97A6 pdf, MAC97A6 description, MAC97A6 datasheets, MAC97A6 view ::: ALLDATASHEET :::
The resistor is 1k Ohms 1%.
probleme with my 850 corat inser sim softel2004 SETool2 0 12-04-2009 00:39
SUNKKO 850 2 in 1 Soldering and Rework Station (220v) IPMART ipmart WebShop 0 05-14-2009 11:50
problem witn sunkko 850 smd repair daos Hardware Equipments for GSM 0 01-15-2006 17:47
A problem with N620 ,N620E after repairing System Failur GSM SNIPER Samsung Hardware Repair 5 09-13-2005 02:16
Page generated in 0.28658 seconds with 11 queries
