Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
01-15-2006, 17:51 | #1 (permalink) |
Crazy Poster Join Date: Mar 2004 Location: colombian people Age: 41
Member: 59553 Status: Offline Thanks Meter: 1 | problem with sunkko 850 smd repair I have a problem with sunkko 850 two in one she has burnt 2 components a transistor and a resistance. please look at the picture already send message to sunkko but they don't respond if somebody has a same one he could look that components are or to take a picture to see them |
01-15-2006, 23:36 | #2 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | If you have an over temperature , it is a feature better than not enough temp. well , no problem try on a scrap board , clean it well becuse dust and oxides insulates heat in and out . adjust the air flow level according to the nozell diameter . adjust the heat to just below propper degree , and let the machein works for 2 min to gain the desired temp level. apply heat to sellected component , after the heat accumulates onboard the tin will melt ( if you see a change in color of components use lower temp level untill you reach the desired calibrage level ) , also increase it if it doesnt melt after some good time . Notice that : old solder need's more time to melt , and heat sinking is different from point to point on the board , finally use flux . |
01-16-2006, 12:15 | #3 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
@daos I have a Sunko 850c but the board is different to yours so I cannot see what you are referring to in relation to mine, maybe the the "c" as 850c makes a difference. Maybe if you can tell me board component number ie R2 or TR1 they might be similar I can then tell you what mine are. | |
07-31-2016, 16:55 | #6 (permalink) | |
Freak Poster Join Date: Jan 2001 Location: Portugal
Member: 2949 Status: Offline Thanks Meter: 0 | Quote:
The transistor is label as: MAC97A6 MAC97A6 pdf, MAC97A6 description, MAC97A6 datasheets, MAC97A6 view ::: ALLDATASHEET ::: The resistor is 1k Ohms 1%. | |
probleme with my 850 corat inser sim | softel2004 | SETool2 | 0 | 12-04-2009 00:39 |
SUNKKO 850 2 in 1 Soldering and Rework Station (220v) | IPMART | ipmart WebShop | 0 | 05-14-2009 11:50 |
problem witn sunkko 850 smd repair | daos | Hardware Equipments for GSM | 0 | 01-15-2006 17:47 |
A problem with N620 ,N620E after repairing System Failur | GSM SNIPER | Samsung Hardware Repair | 5 | 09-13-2005 02:16 |
