Unlock Server
Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 05-06-2003, 11:10   #1 (permalink)
florinmar's Avatar
Member: 8660
ultrasonic pcb cleaner
what substance i must use for ultrasonic pcb cleaner?
Old 05-06-2003, 12:51   #2 (permalink)
themobileking's Avatar
Member: 5072
HI Florinmar
You can use the mixture of Water and Thinner (in 50% ratio).
Old 05-06-2003, 13:11   #3 (permalink)
Porter's Avatar
Member: 19633
try use nitroglicerin! :-)
Old 05-07-2003, 11:24   #4 (permalink)
Member: 461
and Geksogen! :-)
Old 05-29-2004, 20:33   #5 (permalink)
Member: 50240
I use Isoprophyl (alcohol) and it works ok
the mixture is 50:50 to water
Old 05-30-2004, 01:10   #6 (permalink)
iwk
Member: 23953
I use Trielin 30% with water it works
Old 06-01-2004, 16:31   #7 (permalink)
megone's Avatar
Member: 31594
regards
Old 06-03-2004, 21:46   #8 (permalink)
Member: 42709
For how long do you keep the board in the ultrasonic cleaner?
Tks
Old 06-05-2004, 13:54   #9 (permalink)
laval's Avatar
Member: 5585
Use alcohol 3 to 5 minutes
Old 06-06-2004, 07:00   #10 (permalink)
Multi-COM's Avatar
Member: 43823
@florinmar: For best results I suggest to visit nearest elecotrnic shop and look for fluid for cleaning PCB's. They are mostly available in each electronic shop but it must be fluid and tno spray of course (in our country there are 0,5L or 2 L with cost 0,5L about 10-15 USD). Please note that it will be best choice since you must got subtance that don't left substance when you pick up PCB from Ultrasonic Cleaner (self water it's not recommended since it will be OK for process but after 2 month or less client may come back with his phone that i'ts not powering ON anymore.... sad but true). Use then special fluid or if you cannot get it then Isoprophyl or Trielin
Old 08-15-2004, 21:57   #11 (permalink)
Member: 64313
Hi All, I need info on ultrasonic cleaner, im looking to buy one. I have seen so many different ones I don’t know what to go for. I don’t want a real professional one because I only repair phones on a hobby basis, can you guys tell us what make and model your using
Thanks
Steve
Old 12-19-2004, 06:10   #12 (permalink)
Member: 58466
Dont go 4 costly stuffs.Try carbon tetra chloride.cheap&best
Old 04-28-2006, 10:04   #13 (permalink)
Member: 17187
Hi george!
You say Thinner but in french it means "diluant". Do you have a name or a type of thinner?
Old 04-29-2006, 10:38   #14 (permalink)
Member: 10168
I use IPA (Isopropyl Alcahol) 100% as it's one of the few chemicals that will not destroy any plastics on the PCB.
ESEN DS200 Profesional Ultrasonic PCB Cleaner hasmidzul_jojo Hardware Equipments for GSM 2 10-21-2007 05:02
Ultrasonic GSM Cleaner megastream Main Sales Section 0 04-19-2003 19:33
hey mates! stupid question about ultrasonic pcb cleaner DREAMGSM Hardware Repair by brands 2 11-16-2002 18:47
** PCB Cleaners / Sim Cards / 7210's Sim Free ** CompleteFone Main Sales Section 0 11-12-2002 17:54
Ultrasonic PCB Cleaners for repairing water damaged boards just £75 logosunlimited Main Sales Section 13 01-14-2002 10:19
Page generated in 0.38053 seconds with 11 queries
