Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 01-16-2002, 12:46   #1 (permalink)
Member: 2830
What Fluid Do You Use In Ultrasonic Cleaner/Bath?
Hi,<br /> What is the best fluid to use in ultrasonic cleaner/bath to clean gsm pcb?
<br />Thanks<br />max
Old 01-17-2002, 20:12   #2 (permalink)
Hanukkah's Avatar
Member: 5246
Post
50% thinner and water solution, works best.
Old 01-17-2002, 22:38   #3 (permalink)
Member: 2415
Post
[quote]Originally posted by Hanukkah:<br /><strong>50% thinner and water solution, works best.</strong><hr></blockquote>
Hi Hanukkah,<br />what exactly do u mean by thinner?<br />br,<br />bone
Old 01-18-2002, 00:09   #4 (permalink)
Member: 2031
Post
or methalated spirits 100%
Old 01-18-2002, 05:29   #5 (permalink)
Member: 3503
Post
clean by thinner<br />wash with clear water<br />**** with vaccume cleaner<br />put in oven at 60 deg temp for few minutes<br />that what i do<br />it can repair 80% dead phones<br />and can solve network 40% no network
Old 01-19-2002, 13:13   #6 (permalink)
Member: 5750
Post
Extraction Gasoline ( very clear .used for clock cleaning ) or isopropil alcohol (head cleaning fluid)
Old 01-26-2002, 19:20   #7 (permalink)
mujie's Avatar
Member: 8304
The Best Flud to use is 90% alcohol,get it from your local drug store/chemist.fixes 99% water damaged pcb and dries in under 10 seconds,no heat.Just brush it on with clean toothbrush!!!
What themes do you use now... myplace Nokia Multimedia 1 05-29-2007 00:08
What cable do you use for most Pantech? hmotwr VygisToolbox 1 01-29-2007 05:29
What TP do you use with MyC2-3 freedomizer Redbox 8 12-15-2005 08:18
What Phone do you use with Sim-emu? CH@IN Sim Cloning and Scaning 16 10-08-2005 17:14
g 50 what cable do you use mtony969 Panasonic 0 10-26-2003 07:35
Page generated in 0.26262 seconds with 11 queries
