Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan > USB Pinfinder
Old 05-23-2009, 11:41   #1 (permalink)
Member: 291400
Thanks Meter: 61
Connect any USB supported phone through USB PINFINDER whose cable is not available...
NOW USE SPIDERMAN USB PINFINDER TO CONNECT ANY PHONE WHOSE USB CABLE YOU DO NOT HAVE OR IS NOT AVAILABLE IN THE MARKET....
Things you need to connect the phone :-
1. SPIDERMAN with USB PINFINDER connected..
2. SPIDERMAN cable Which matches with your phone port..
3. Phone with battery connected and switched on (no need to pwr phone
with spiderman's pwr pins + & -)
4. USB pinouts of your phone..
Below is an example for connecting your nokia DKU5 cable supported phone..
STEP 1...
Find and get USB pinout of the phone u want to connect through USB..
STEP 2...
Connect SPIDERMAN box and click on CUSTOM CABLE..
STEP 3...
The DEFINE CABLE window opens..
Then click on NEW..
STEP 4...
The CREATE NEW CABLE DEFINE window opens..
Write JET-NAME & CABLE-NAME as u want to..
Then click on DEFINE CABLE AND SAVE IT..
STEP 5...
A new custom cable is set, then by the dropdown menu select the pins as your phone's USB pinouts... ( GND, USB-, USB+, PWR)..
STEP 6...
Then click on SEND, your pinouts will be set as defined..
Now ur phone will be detected...
Then install correct drivers of your phone..
The Following 47 Users Say Thank You to joy4u For This Useful Post:
Old 05-23-2009, 17:41   #2 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
thank you brother
really good thread ....
added to the sticky section
The Following 9 Users Say Thank You to gsm2start For This Useful Post:
Old 05-23-2009, 17:53   #3 (permalink)
hassan1975's Avatar
Member: 28819
Thanks Meter: 222
good work
thx bro
B.R.
The Following User Says Thank You to hassan1975 For This Useful Post:
Old 05-26-2009, 14:56   #4 (permalink)
lovingazmee's Avatar
Member: 246670
Thanks Meter: 161
Good Work Clarified with images will help members
WBR
AZEEM
The Following User Says Thank You to lovingazmee For This Useful Post:
Old 05-29-2009, 00:08   #5 (permalink)
hima010's Avatar
Member: 820946
Sonork: ...........
Thanks Meter: 186
good work
thanks my brother
Old 06-05-2009, 22:30   #6 (permalink)
Member: 714552
Thanks Meter: 15
good job
thank brodher
Old 06-05-2009, 23:21   #7 (permalink)
dawah telecom's Avatar
Member: 868940
Thanks Meter: 90
useful info...............
Image proof...................keep it up
Old 06-08-2009, 12:17   #8 (permalink)
MR.SONY's Avatar
Member: 1040384
Sonork: 100.1583996
Thanks Meter: 202
very good
thanks for you
Old 06-16-2009, 13:27   #9 (permalink)
Member: 714552
Thanks Meter: 15
thank you brother
really good thread
Old 06-21-2009, 08:28   #10 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
please sir explain more the few images not popping there is a cross x
Old 06-21-2009, 23:38   #11 (permalink)
Member: 963269
Thanks Meter: 10
AMy friends bought spiderman and now has difficulties with p what cable to use on phones has many PORQ conctou that are similar to the other, the friend wanted ajunda p Encinar me as I choose the cable serti po serti phone since iPhone?
The Following User Says Thank You to ronysat For This Useful Post:
Old 06-23-2009, 03:20   #12 (permalink)
Member: 291400
Thanks Meter: 61
If u set wrong pinouts and SEND... Then it will show " USB Device NOt Recognized "
Some counts pins from left and some from right...
so check that...
The Following 2 Users Say Thank You to joy4u For This Useful Post:
Old 06-23-2009, 03:21   #13 (permalink)
Member: 291400
Thanks Meter: 61
Can u explain ur problem a little in brief plz....
I cannot understand u...
Old 06-23-2009, 04:41   #14 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Will try and put test report here, i need to connect ZTE F285...
Old 06-23-2009, 08:02   #15 (permalink)
Member: 588930
Thanks Meter: 16
vert good thanks brother
DCT4Plus service is not available at the moment ... Any Update?? airos_8 Universalbox 1 06-23-2008 11:44
another dead phone through usb smart boxman SonyEricsson (USB-Smart) 19 08-21-2006 09:45
@@ v545 flash file is not available in support area@@ rajabrotherscom Smart-Clip 2 04-25-2006 12:36
IMEI Change option is not available FOr Sony Ericsson T39m with DIV USB 4.0 PLz HElp. cellexpress Old Ericsson Phones & Sony Phones 1 09-04-2004 16:19
Page generated in 0.22899 seconds with 9 queries
