How to install usb pinfinder and to solve "USB NOT RECGNIZED" PROBLEM HOW TO INSTALL PROPERLY: This is the gadget it comes with a red alligator clip...... http://i819.photobucket.com/albums/z...20101202-1.jpg So what is the use of this? I search for answer....I cant find one... http://i819.photobucket.com/albums/z...20101201-1.jpg It is use to modify the power cord of the spider box.....Install like this http://i819.photobucket.com/albums/z...1720101213.jpg Now lets install the chip to the spider box: 1. Disassemble the box.... http://i819.photobucket.com/albums/z...1520101203.jpg 2. Put the chip to pins provide in the board of the box http://i819.photobucket.com/albums/z...1520101204.jpg 3.Assemble and Connect the box in your PC....Now u can see this http://i819.photobucket.com/albums/z.../spiderbox.jpg NOW ITS NOW READY TO USE FOR SPREADTRUM CHIP CHINAPHONES.. |
NOW ITS NOW READY TO USE FOR SPREADTRUM CHIP CHINAPHONES.. BETA TEST FOR REMOVING A USERCODE OF 6300 W/ SPREADTRUM CHIPSET: 1.Click Connect....click spreadtrum in the tab.....choose hardware type according to the spreadtrum IC....(it is indicated at the ic)... In my case it is (SC6600L-USB)-(Manual). 3. then search the phone......(using the Inteligent port....and the usual cable....w/ modified the red alligator clip) http://i819.photobucket.com/albums/z...29/6300sp1.jpg http://i819.photobucket.com/albums/z...1720101210.jpg HERE COMES THE TRICK:...BECAUSE WHEN YOU CLICK BOOT IT WILL BE"USB NOT RECOGNIZED" AND IT WILL NOT CONTINUE TO BOOT....AND YOU CANNOT DO ANYTHING WHEN THE PHONE DOEST BOOT... 4. After you search the phone in the usaual way...using usual cable.... YOU WILL BE NEEDING.... a. 2 mini usb cables...where one usb is cut... http://i819.photobucket.com/albums/z...1720101212.jpg b. One is put in the usb port and the other one which is cut to the board.....find the pin out.....in our case...white wire is in the RX and Green wire is the TX and the black wire is the ground..... http://i819.photobucket.com/albums/z...1720101208.jpg c. Connect the 2 usb in your PC....and supply power using the modified alligator clip that comes in the package...and it will now detect by the computer.....it can now be recognized by the computer..... and you will be needing this Drivers: Driver.rar install drivers http://i819.photobucket.com/albums/z...atzy_929/1.jpg now the phone sucessfully boot http://i819.photobucket.com/albums/z...29/6300sp3.jpg now tick user code: http://i819.photobucket.com/albums/z...29/6300sp4.jpg try all codes.....in my case it is: 25800 now the phone is ok..... http://i819.photobucket.com/albums/z...1720101211.jpg Now let us try to format the phone.......(for testing only) Just Click format and uncheck user define format adress http://i819.photobucket.com/albums/z...29/6300sp6.jpg http://i819.photobucket.com/albums/z...29/6300sp7.jpg I HOPE IT WILL HELP ALL USERS HAVING PROBLEM WITH INSTALLATION AND "USB NOT RECOGNIZED WHEN BOOING THE PHONE...... |
It is not clear...... means..modify the power cable where???? the rad clip which is come with the box....I want to replace with the spiderman power cable or I want to connect it to USB... Also what about the cable which is come with spiderman... U also solder the rx and tx...So no need to connect the cable... Could You please take a full picture because some picture is cut..So have little problems to identify the cable. But any how thanks for your hard work which the supporter did not know what their product is.......failed to rectify the problem. you don't how much of money I loose because of this....... Regards, |
yes same problem here help me full picture |
helloo Guys i m having problem with my spiderman Box When i connect computer find the box software connect the box with PC but cannot Search Phone everythhing same like whn v connect the power with Phone it beeps but cannot search the Phone Solution i m having this problem since from last 1 week and i have tested many new and old ok running Phones but same problem. Any soloution ?? Cz Spiderman team wont Reply for this as they did with other Users.. |
hi sir i have buy a new spd card its instol buit i dot j have other read pin for power i buy also new pin but wher is cannet sir i pin inth box 5 volt or pc usb 5 volt sir ple help me :confused::confused::confused: |
HELOO BROTHER TOADY I BOUGHT USB PINFINDER CHIP BUT MY RELLER NOT PROVIDE ANY no anay modify the power cable how to work ? |
bro just use your old power cable which was used with mtk cpu's .i tested it with spreadtrum cpu's;) but use the latest version 2.70 full. |
Could you please give me a good picture.. Or please upload someare.. Because I can not understand the picture ... Thanks |
it is better to go to some other box which can solve this problem easily Quote:
goooooooooooooooood job brotherrrrrrrrrrrrrrrrrrrr |
what is the function of red cable which comes with usb pin finder. when i bought usb pin finder it was not here i took only chip not cable .. know i am facing strange problem "usb not recognize" my main question is why this problem is coming else without red cable or others .............. i see a mini part located in centre of cable. what is this. |
this is the cable which comes with usb pin finder. see a mini part coated in plastic i want the reveal what is this?? what is the function of this mini part |
@pat79 Sir can you tell us how to modifie the power cable or you called it RED ALLIGATOR CLIP? please show us the picture what inside the wire of red alligator clip,or what kind of resistor of that..:rolleyes::rolleyes: see the blue circle of the picture below... [IMG]http://i202.photobucket.com/albums/a...untitled-1.png[/IMG]:rolleyes: |
