Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan > USB Pinfinder
Old 03-13-2009, 20:50   #1 (permalink)
Member: 202306
spidermane usb pindfinder probleme
hello i have a big probleme vith my usb pindfinder ihave buy my box last week i have install it correctly it work fine but the probleme is it detect only mtk phones it not dectect any spreadtrum phone i open it refix correctly usb pindfinder but same probleme connect to computeur it says usb pinfinder online but not detect any spreadtrum probleme is my usb pinfinder any one as schema to repaire it to give me please help
Old 03-14-2009, 00:46   #2 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
make sure you use the latest version of spiderman
if still not working... i think you need to replace usbpinfinder
goog luck
BR,
............shehab...........
Old 03-14-2009, 11:15   #3 (permalink)
Member: 202306
Yes i use the last version 2.52 the proble i already open the box to see if usbpinfinder is in the box so garanty is off
Old 03-15-2009, 03:52   #4 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
well.... replace the usb pinfinder and try again..
waiting for result
BR,
.............shehab...........
Old 03-15-2009, 11:13   #5 (permalink)
Member: 982906
Sonork: 999999
i just buy a spiderman box...already install.but when search pin out...it's cannot ..please help me to solve this problem...
Old 03-15-2009, 15:28   #6 (permalink)
Member: 202306
SAME PROBLEME MR gsm2start ANY OTHER SOLUTION LIKE SCHEMAS
Old 03-16-2009, 01:16   #7 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
did you replace usb pinfinder and still same problem ???
Old 03-16-2009, 11:32   #8 (permalink)
Member: 202306
yes i replace it three times but same probleme
Old 03-17-2009, 16:04   #9 (permalink)
papsnew's Avatar
Member: 390521
hi have replaced two boxes ,but i get error when i connect spd phone.some one help me please am loosing a lot of money.
Old 03-28-2009, 05:21   #10 (permalink)
Member: 982906
Sonork: 999999
Already can search the pin, now the problem is cannot boot, read and flash.when write press on / off phone...the spider cannpt detech.please help ...
Old 03-28-2009, 16:44   #11 (permalink)
SE-THAILAND's Avatar
Member: 10084
this problem with "Spiderman Main PCB" not "Pin Finder Unit".change to new box then try
good luck
Spiderman Box (Packaged with 21 pcs cables) + Spiderman USB Pin Finder IPMART ipmart WebShop 0 07-13-2009 12:50
spidermane usb pindfinder probleme nacino USB Pinfinder 5 03-15-2009 22:58
urgent,spiderman, usb not recognized hany elsaghir f Chinese Models & Cloned Phones 1 12-19-2008 03:13
-=ztc china phone done by spiderman usb pinfinder=- aiyon_861 USB Pinfinder 1 08-30-2008 10:10
SpiderMan lot of Problem can i use this box ? kabirhossain SpiderMan 0 07-26-2008 13:28
Page generated in 0.49134 seconds with 11 queries
