Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2008 Location: Kathmandu, Nepal
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks: 135
| GPGUFC Pro 2012 F&Q and Detailed Tutorial VCC, BSI, GND and RX, TX, RX2 site Confused??? ================================================== If you put the GPG UFC PRO in front of you facing its head Towards you then you find RX, TX, RX2 side is Right Hand side (of you, and left hand side of this Creature) and VCC, BSI, GND side is in your left side (of you and Right hand side of this creature). ![]() Uploaded with ImageShack.us BR Last edited by GPGIndustries; 06-10-2012 at 04:30. |
| | #2 (permalink) |
| Use Stand of UFC Pro after using it Although GPG UFC Pin are high quality pins but If you don't use GPG UFC Pro Stand there might be damage of pin and the lead light too. So, Always use Stand after using it. Wrong Way ![]() Uploaded with ImageShack.us Right Way ![]() Uploaded with ImageShack.us BR |
| | #3 (permalink) |
| Battery Cable Problem I have a Problem of Battery cable in X3, 5310 type. Any Solution ================================================= Yes, Of Course. We understand your problem. So, we have an idea to grasp to the battery socket with the UFC PRO VCC, BSI and GND cable of these type of mobile so that the cable can't run away at the time of operation. You can buy small Battery Pin or Cable and you can join or solder it to Normal Battery Cable ( has VCC, BSI and GND). This pin might different from one company to another but the work of this pin is to supply power to the mobile from GPG UFC PRO. ![]() Uploaded with ImageShack.us BR |
| | #4 (permalink) |
| UFC Pro gives error Double CUP Phone N70, N72, N73 gives errors ===================================== Although, you know, all the function is set properly still GPG UFC Pro gives error or can't read full information or can't back of RPL of that types of phones. This happens due to lack of or not enough power to UFC PRO from your computer. Now, you must use Nokia Original Charger at the time of GPG UFC PRO using :- ![]() Uploaded with ImageShack.us BR |
| | #5 (permalink) |
| Difficulty to find Jig or pin / Jig Compatibility Not find Jig compatibility Manual ====================== Here is the jig compatibility manual UFCPRO 2012 JIG Compatibility List BR |
| | #6 (permalink) |
| I did not see Resistance pins How to change Resistance? ====================== The Old ABC UFCs you are using that has resistance pins manually adjustable but GPG UFC PRO is difference than those UFCs. You just need to press a button to do so. Since GPG UFC Pro has Digital Resistance Changer using a button (Pin) on the top of the product; it changes resistance values when you press it each time that indicates with white light. If resistance position is in 3.3k, then press the RESISTANCE CHANGING BUTTON it goes to 5.1k. If you again press the BUTTON it goes to 7.5K and so on. ![]() Uploaded with ImageShack.us |
| | #7 (permalink) |
| Not seen ATF in the list and How to use it with different boxes Not seen in ATF in the list =================== The Ols ABC UFS that you are using has many cables for different boxes and each time you must change the cable for different boxes. But with this GPG UFC PRO you do not have such a problem. You can do it with a button or pin and save your time. Since it has digital button or pin for different boxes, you can change it according to your will. Suppose the light is on UFS position and you want to use MT then Press 2 times to SWITCHING PIN TO BOX, If you want to use CYCLONE then, just Press 1 time. To use ATF just leave it in UFS Position. ![]() Uploaded with ImageShack.us |
| The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
| | #8 (permalink) |
| Mobile not adjust inside and Pins are Inverse Not adjust in UFC Pro and Pin is inverse Position ======================================= Not Adjust inside Of UFC PRo Like This ===================================== ![]() Uploaded with ImageShack.us PIns are inverse like this ======================== ![]() Uploaded with ImageShack.us No Worry. Check the video first. GPGUFC 2k12 - How to reverse Jig from main adaptor - YouTube Now, Change the Jig Position A - B to B - A Like this. A - B (Previous Position) ![]() Uploaded with ImageShack.us B - A (New Positon) ![]() Uploaded with ImageShack.us |
| | #9 (permalink) |
| Could I use another software? Could I use another software for proper resistance Value and Nokia RX, TX, GND Pinout etc. Any Kind of Software you use, Pinout of Nokia Phones are same. So, Of course, You can. |
| | #10 (permalink) |
| Others Problem Misprint of Jig Name ==================== Some Jigs are like same so sometimes there might be mistake for Printing Jig's Name. If you find so, nothing to do, just take out the sticker of jig that has misprint (Jig Name) and stick it to the correct jig. That's all. |
| | #11 (permalink) |
| Where do I find Pinout and Resistance of Mobiles? ==================================== This section is here :- GPGUFC 2k12 - All you need to know!! BR |
| | #12 (permalink) |
| [COLOR=*****Brown]Where do we find Test Report ?[/COLOR] ======================== This section is here : GPGUFC PRO 2k12 Test Report BR |
| | #13 (permalink) |
| Accessories that includes in GPG UFC PRO ================================ 1. Main Body (Looks like a Creature) 1 pcs 2. Main Cable (Box to UFC PRO) 1 pcs 3. Pin or Jigs 20 pcs 4. VCC, BSI, GND cable 1 pcs 5. Rx, Tx, Rx2 cable 1 pcs |
| | #14 (permalink) |
| We want to see Demo Videos ====================== This section is here :- UFC PRO 2012 Demo Videos. and GPGUFC PRO 2k12 Test Report and also here MOST ADVANCED UFC EVER BUILT! WHY? Check inside? BR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-31-2012 20:09 |
| IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 11-15-2011 12:08 |
| FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! | FREECELLUK | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-26-1999 22:48 |
| wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-13-1999 19:18 |
