Unlock Server
Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPG-Setool3
Old 12-24-2010, 10:33   #1 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
Post A2 EMPTY BOARD programming ok
Done - A2 EMPTY BOARD programming
Done - A2 EMPTY BOARD programming Hello all,
I've done managed an A2 empty fill. Here i'd like to share the steps. Hope this will be usefull.
This phone has power chip damaged. Quick drained battery caused by short power chip (VERA)
1. Here is the phone with new VERA chip installed.
2. Unlock, setting : Signed Mode + Alt. Security Bypass
ignore the final error message.
3. Make an identify just to check it.
seems all OK, semc boot is now written.
4.Go to empty fill tab. write down desired imei. setting: none.
press FLASH
the program will end up like this, i don't know why. just ignore this error message, because..
[IMG]http://www.****************/images/statusicon/wol_error.gif[/IMG]This image has been resized. Click this bar to view the full image. The original image is sized 771x404.
,,,,,, don't worry.
IMEI programming is DONE anyway!
5. Last Step : do unlock and set final domain.
[IMG]http://www.****************/images/statusicon/wol_error.gif[/IMG]This image has been resized. Click this bar to view the full image. The original image is sized 771x413.
ps.
just ignore those device key. confirmed by many friends, that is nothing to worry.
SETOOL ROCKS!!!!!
Best Regards.
gbluez
thank you the_laser.
The Following 7 Users Say Thank You to Parash+ For This Useful Post:
Old 01-31-2011, 06:10   #2 (permalink)
nikunj's Avatar
Member: 526644
after change power ic
1/29/2011 4:40:56 PM RUNNING v 1.10/UNI
1/29/2011 4:40:56 PM CARD SERIAL 000*****
1/29/2011 4:40:56 PM USBFLASH DRIVER VERSION 02.02.00.05
1/29/2011 4:42:31 PM CFG:000000000000
1/29/2011 4:42:35 PM PROCEDURE WAS STOPPED BY USER
1/29/2011 4:42:35 PM Can't load ID loader !
1/29/2011 4:42:35 PM Elapsed: 4 secs.
1/29/2011 4:42:41 PM SIGNED MODE (USING SERVER)
1/29/2011 4:42:41 PM CFG:100000000000
1/29/2011 4:42:54 PM ChipID:E900,EMP protocol:0401
1/29/2011 4:42:54 PM BOOTROM MODE DETECTED
1/29/2011 4:42:54 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 4:42:54 PM unexpected PDU:[06] [020302160217022C0102]
1/29/2011 4:42:56 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000
1/29/2011 4:42:57 PM [loader_on_loader] hdr err:1022
1/29/2011 4:42:57 PM loader_on_loader:bad result [01/11]
1/29/2011 4:42:57 PM Elapsed: 15 secs.
now select sign mode and altbypass and do unlock
1/29/2011 4:43:28 PM SIGNED MODE (USING SERVER)
1/29/2011 4:43:28 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 4:43:28 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 4:43:28 PM CFG:110000000000
1/29/2011 4:49:43 PM ChipID:E900,EMP protocol:0401
1/29/2011 4:49:44 PM BOOTROM MODE DETECTED
1/29/2011 4:49:44 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 4:49:44 PM unexpected PDU:[06] [020302160217022C0102]
1/29/2011 4:50:44 PM loader_on_loader:bad result [01/FF]
1/29/2011 4:50:44 PM can't load APPLICATION CPU preloader
1/29/2011 4:50:44 PM FAILED TO SETUP PHONE
1/29/2011 4:50:44 PM Unlock FAILED
1/29/2011 4:50:44 PM Elapsed: 436 secs.
1/29/2011 4:51:28 PM SIGNED MODE (USING SERVER)
1/29/2011 4:51:28 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 4:51:28 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 4:51:28 PM CFG:110000000000
1/29/2011 4:51:35 PM ChipID:E900,EMP protocol:0401
1/29/2011 4:51:35 PM BOOTROM MODE DETECTED
1/29/2011 4:51:35 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 4:51:35 PM unexpected PDU:[06] [020302160217022C0102]
1/29/2011 4:51:37 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000
1/29/2011 4:51:41 PM DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (4)
1/29/2011 4:51:41 PM LDR:2010-03-02 18:04 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A096
1/29/2011 4:51:42 PM LDR:2010-03-02 18:05 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A096
1/29/2011 4:51:42 PM RESETTING SECURITY TO FACTORY STATE...
1/29/2011 4:51:42 PM RESTARTING...
1/29/2011 4:51:46 PM ChipID:E900,EMP protocol:0401
1/29/2011 4:51:46 PM BOOTROM MODE DETECTED
1/29/2011 4:51:46 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 4:51:46 PM unexpected PDU:[06] [0115]
1/29/2011 4:51:48 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 4:51:48 PM LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096
1/29/2011 4:51:49 PM LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096
1/29/2011 4:51:49 PM WRITING SEMCBOOT...
1/29/2011 4:51:51 PM PREPARING SECURITY...
1/29/2011 4:51:51 PM PHONE DOMAIN: "BLUE"
1/29/2011 4:51:51 PM WRITING CLEAR SIMLOCK UNITS...
1/29/2011 4:51:51 PM SIMLOCK CODES SET TO "30227558"
1/29/2011 4:51:51 PM SIGNING...
1/29/2011 4:51:52 PM DEVICE KEY RESTORED
1/29/2011 4:51:53 PM Unlock DONE
1/29/2011 4:51:53 PM Elapsed: 25 secs.
Now Identify the phone
1/29/2011 4:52:08 PM SIGNED MODE (USING SERVER)
1/29/2011 4:52:08 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 4:52:08 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 4:52:08 PM CFG:110000000000
1/29/2011 4:52:27 PM ChipID:E900,EMP protocol:0401
1/29/2011 4:52:27 PM BOOTROM MODE DETECTED
1/29/2011 4:52:27 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 4:52:29 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 4:52:29 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/29/2011 4:52:30 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/29/2011 4:52:30 PM Model (from GDFS):W995
1/29/2011 4:52:30 PM MAPP CXC article: R1HA035 prg1215-7995_GENERIC_HI
1/29/2011 4:52:30 PM MAPP CXC version: R1HA035
1/29/2011 4:52:30 PM Language Package: M-EAST-N-AFR
1/29/2011 4:52:30 PM CDA article: 1223-7387
1/29/2011 4:52:30 PM CDA version: R11A
1/29/2011 4:52:30 PM Default article: 1215-7993
1/29/2011 4:52:30 PM Default version: R1HA035
1/29/2011 4:52:30 PM PROVIDER: 000-00
1/29/2011 4:52:30 PM SIMLOCKS NOT DETECTED
1/29/2011 4:52:31 PM Elapsed: 22 secs.
now go to emty fill tab and fill imei select write otp select CID and in setting none then press flash
1/29/2011 5:03:04 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 5:03:04 PM CFG:000000000000
1/29/2011 5:03:21 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:03:21 PM BOOTROM MODE DETECTED
1/29/2011 5:03:21 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:03:23 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 5:03:26 PM LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:03:26 PM LDR CAPS:SYSTEM FLASH SIGNATURE
1/29/2011 5:03:27 PM LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096
1/29/2011 5:03:27 PM LDR CAPS:SYSTEM FLASH TA
1/29/2011 5:03:27 PM Writing IMEI "35947303979128"...
1/29/2011 5:03:28 PM OTP DATA WRITTEN
1/29/2011 5:03:28 PM WRITING CLEAR SIMLOCK UNITS...
1/29/2011 5:03:28 PM SIMLOCK CODES SET TO "07238653"
1/29/2011 5:03:30 PM Elapsed: 25 secs.
after otp data written when i check imei is still 00000..
also i do unlock many times but still same .
1/29/2011 5:05:06 PM SIGNED MODE (USING SERVER)
1/29/2011 5:05:06 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 5:05:06 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 5:05:06 PM CFG:110000000000
1/29/2011 5:05:22 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:05:22 PM BOOTROM MODE DETECTED
1/29/2011 5:05:22 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:05:22 PM unexpected PDU:[06] [020302160217022C0102]
1/29/2011 5:05:24 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000
1/29/2011 5:05:25 PM DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (4)
1/29/2011 5:05:26 PM LDR:2010-03-02 18:04 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:05:27 PM LDR:2010-03-02 18:05 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A096
1/29/2011 5:05:27 PM RESETTING SECURITY TO FACTORY STATE...
1/29/2011 5:05:27 PM RESTARTING...
1/29/2011 5:05:31 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:05:31 PM BOOTROM MODE DETECTED
1/29/2011 5:05:31 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:05:31 PM unexpected PDU:[06] [0115]
1/29/2011 5:05:33 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 5:05:33 PM LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:05:34 PM LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096
1/29/2011 5:05:34 PM WRITING SEMCBOOT...
1/29/2011 5:05:36 PM PREPARING SECURITY...
1/29/2011 5:05:36 PM PHONE DOMAIN: "RED"
1/29/2011 5:05:36 PM WRITING CLEAR SIMLOCK UNITS...
1/29/2011 5:05:36 PM SIMLOCK CODES SET TO "85737050"
1/29/2011 5:05:36 PM SIGNING...
1/29/2011 5:05:37 PM DEVICE KEY RESTORED
1/29/2011 5:05:38 PM Unlock DONE
1/29/2011 5:05:38 PM Elapsed: 32 secs.
1/29/2011 5:14:20 PM SIGNED MODE (USING SERVER)
1/29/2011 5:14:20 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 5:14:20 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 5:14:20 PM CFG:110000000000
1/29/2011 5:14:29 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:14:29 PM BOOTROM MODE DETECTED
1/29/2011 5:14:29 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:14:31 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:14:33 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/29/2011 5:14:34 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/29/2011 5:14:40 PM GOT SEED:8D152EAC0000000000000000
1/29/2011 5:14:40 PM P96 AUTH PASSED
1/29/2011 5:14:40 PM RESTARTING...
1/29/2011 5:14:44 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:14:44 PM BOOTROM MODE DETECTED
1/29/2011 5:14:44 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:14:46 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:14:46 PM DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (1)
1/29/2011 5:14:47 PM LDR:2010-03-02 18:04 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:14:47 PM LDR:2010-03-02 18:05 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A096
1/29/2011 5:14:47 PM RESETTING SECURITY TO FACTORY STATE...
1/29/2011 5:14:48 PM RESTARTING...
1/29/2011 5:14:51 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:14:51 PM BOOTROM MODE DETECTED
1/29/2011 5:14:51 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:14:52 PM unexpected PDU:[06] [0115]
1/29/2011 5:14:54 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 5:14:54 PM LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:14:55 PM LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096
1/29/2011 5:14:55 PM WRITING SEMCBOOT...
1/29/2011 5:14:57 PM PREPARING SECURITY...
1/29/2011 5:14:57 PM PHONE DOMAIN: "RED"
1/29/2011 5:14:57 PM WRITING CLEAR SIMLOCK UNITS...
1/29/2011 5:14:57 PM SIMLOCK CODES SET TO "30236636"
1/29/2011 5:14:57 PM SIGNING...
1/29/2011 5:14:58 PM DEVICE KEY RESTORED
1/29/2011 5:15:00 PM Unlock DONE
1/29/2011 5:15:00 PM Elapsed: 39 secs.
1/29/2011 5:15:11 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 5:15:11 PM CFG:000000000000
1/29/2011 5:15:19 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:15:19 PM BOOTROM MODE DETECTED
1/29/2011 5:15:19 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:15:22 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:15:24 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/29/2011 5:15:24 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
1/29/2011 5:15:25 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/29/2011 5:15:25 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
1/29/2011 5:15:26 PM [loader_on_loader] hdr err:1022
1/29/2011 5:15:26 PM loader_on_loader:bad result [01/11]
1/29/2011 5:15:26 PM Elapsed: 14 secs.
1/29/2011 5:15:34 PM CFG:000000000000
1/29/2011 5:15:43 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:15:43 PM BOOTROM MODE DETECTED
1/29/2011 5:15:43 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:15:45 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:15:46 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/29/2011 5:15:47 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/29/2011 5:15:47 PM Model (from GDFS):W995
1/29/2011 5:15:47 PM MAPP CXC article: R1HA035 prg1215-7995_GENERIC_HI
1/29/2011 5:15:47 PM MAPP CXC version: R1HA035
1/29/2011 5:15:47 PM Language Package: M-EAST-N-AFR
1/29/2011 5:15:47 PM CDA article: 1223-7387
1/29/2011 5:15:47 PM CDA version: R11A
1/29/2011 5:15:47 PM Default article: 1215-7993
1/29/2011 5:15:47 PM Default version: R1HA035
1/29/2011 5:15:47 PM PROVIDER: 000-00
1/29/2011 5:15:47 PM SIMLOCKS NOT DETECTED
1/29/2011 5:15:47 PM Elapsed: 12 secs.
1/29/2011 5:17:08 PM SIGNED MODE (USING SERVER)
1/29/2011 5:17:08 PM ALTERNATIVE SECURITY BYPASS ENABLED
1/29/2011 5:17:08 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
1/29/2011 5:17:08 PM CFG:110000000000
1/29/2011 5:17:15 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:17:15 PM BOOTROM MODE DETECTED
1/29/2011 5:17:15 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:17:17 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:17:19 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/29/2011 5:17:20 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/29/2011 5:17:23 PM GOT SEED:B4F3C3C20000000000000000
1/29/2011 5:17:24 PM P96 AUTH PASSED
1/29/2011 5:17:24 PM RESTARTING...
1/29/2011 5:17:28 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:17:28 PM BOOTROM MODE DETECTED
1/29/2011 5:17:28 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:17:30 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:RED
1/29/2011 5:17:30 PM DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (1)
1/29/2011 5:17:31 PM LDR:2010-03-02 18:04 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:17:31 PM LDR:2010-03-02 18:05 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A096
1/29/2011 5:17:31 PM RESETTING SECURITY TO FACTORY STATE...
1/29/2011 5:17:31 PM RESTARTING...
1/29/2011 5:17:35 PM ChipID:E900,EMP protocol:0401
1/29/2011 5:17:35 PM BOOTROM MODE DETECTED
1/29/2011 5:17:35 PM OTP DBG: [0,00,0,00000000000000]
1/29/2011 5:17:36 PM unexpected PDU:[06] [0115]
1/29/2011 5:17:38 PM OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
1/29/2011 5:17:39 PM LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096
1/29/2011 5:17:40 PM LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096
1/29/2011 5:17:40 PM WRITING SEMCBOOT...
1/29/2011 5:17:41 PM PREPARING SECURITY...
1/29/2011 5:17:41 PM PHONE DOMAIN: "RED"
1/29/2011 5:17:41 PM WRITING CLEAR SIMLOCK UNITS...
1/29/2011 5:17:42 PM SIMLOCK CODES SET TO "25464671"
1/29/2011 5:17:42 PM SIGNING...
1/29/2011 5:17:42 PM DEVICE KEY RESTORED
1/29/2011 5:17:44 PM Unlock DONE
1/29/2011 5:17:44 PM Elapsed: 36 secs.
please help me to recover my phone i used Original GPG Otp Cable
The Following User Says Thank You to nikunj For This Useful Post:
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
Does any one know how to program the ESN number with nokia 6120? Bert Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-02-1999 09:45
I sell programs for nokia soft 5.20 , 5.22 , 5.24 Swiety Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:07
I need passwords for new bontiek sites programs Zahooo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 09-10-1999 22:42
Upload / Download eeprom program for 51xx/61xx Ryu Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-07-1999 14:03
Page generated in 0.34194 seconds with 11 queries
