Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2004 Location: jamshedpur Age: 27
Member: 59185 Status: Online Sonork: 100.1593175 Thanks: 684
| How To Work With A1-Based Phones HOW TO WORK WITH A1-BASED PHONES basics: Quote:
| | #2 (permalink) |
| FLASHING OF DB2000,DB2010 PHONES common for all CID: 1. go to semc tab, select proper model 2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important. 3. select in misc. field needed CUSTPACK (.zip archive with customization files) 4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash" 5. please read notes below 6. set other settings according your needs. 7. back to semc tab, press flash. CID 17,24,41,42,54 unsigned mode 3. skip 4. skip 5. on settings, uncheck signed mode, alternative security bypass, preloader security bypass,customize phone after flash. for BROWN CID 41,42,73 you must disassemble phone and do testpoint operation. testpoint is simple GND wire attached to specific points on phone board. (upload testpoint pictures) in that case, step 5 will be: 5. on settings, check only "use tespoint (gnd method)" you can use special 'dual" usb+serial cable in order to significantly increase flashing speed for such phones. you can not use script for such phones. CID 16,29,36,37,49 signed mode 5. check signed mode unsigned mode 5. on settings, uncheck "signed mode", "alternative security bypass" you can only use USB as interface for phones with CID 49, some CID 36 phones can be upgraded to CID 49 via writing of corresponding EROM. restoration files required for phones with CID 49 CID 50,51,52,53 signed mode 5. check signed mode standalone altbypass mode 5. check "signed mode", "use alternative security bypass" restoration files required bypass package required please read FAQ post about alternative security bypass that is preferred mode if you want to do some additional operations during flashing process. please note, that if you put in misc. edit any file, which is NOT custpack archive, it will be treated as script command file. |
| | #3 (permalink) |
| UNLOCKING OF DB2000,DB2010 PHONES CID 17 1. select com/ufs as interface 2. go to lg tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on lg tab 6. press unlock button please note, than recent firmwares can't be unlocked with such method,use cid 41,42 path or downgrade firmware. CID 24 1. select com/ufs as interface 2. go to sharp tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on sharp tab 6. press unlock button in some cases you must flash special patched firmware from support area before unlock. CID 41,42 1. select com/ufs as interface 2. go to lg tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on lg tab 6. press unlock button if phone BROWN CID 41,42 then you must disassemble phone and do very easy testpoint. testpoint is simple GND wire , attached to needed point on phone board. step 4 should be like that: 4. on settings tab, check "use testpoint (gnd method): (upload testpoint pictures) CID 16,29,36,37 1. select com/ufs as interface 2. go to semc tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on semc tab 6. press unlock button that CID is obsolete and upgrade to CID 49 via writing corresponing EROM recommended. you can not use USB as interface for such phones with CID. recovery operation supported for such phones, damaged EROM can be restored without problems. no any special files required for such phones. CID 49 standalone method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on semc tab 6. press unlock button you can not use USB as interface, if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. that files could be downloaded from support area or created automatically : place main part of unsupported firmware in firmware area,press identify and attach phone with unsupported firmware. CSCA method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on semc tab 6. press unlock button that is not recommended method for unlocking such phones, slow and useless. you can not repair damaged SCRC via that method. recovery operation not supported for such phones, reset operation should be used in order to repair damaged EROM. you can repair damaged GDFS, damaged SCRC standalone for such phones. CID 50,51,52,53 standalone patch unlock method via alternative security bypass 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass" 5. back on semc tab 6. press unlock button you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. bypass packages required for that method. please read FAQ post about alternative security bypass. standalone RESET-based method 1. select com/ufs/usb as interface 2. go to emptyboard tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on emptyboard tab 6. press RECOVERY button 7. on settings tab, UNcheck "signed mode" 8. add to firmware area corresponding EROM from EROMS\ folder, EROM CID should be >= OTP CID 9. press flash that is recommended method to use with that phones you can fix SCRC using that method CSCA method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on semc tab 6. press unlock button please note,that phones with cid51,52,53 require credits and internet access in order to unlock using CSCA method. that is obsolete method, should not be used,because it long and credit-consuming recovery operation not supported for such phones, reset operation should be used in order to repair damaged EROM,damaged GDFS, damaged SCRC. CID 54 1. select com/ufs as interface 2. go to lg tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on lg tab. 6. add to firmware area special patched firmware from support area. 7. press flash if any trouble happens, you must reflash phone with original not patched firmware. CID 73 disassemble phone. 1. select com/ufs as interface 2. go to sharp tab 3. select correct model 4. on settings tab, check "use tespoint (gnd method)" 5. back on sharp tab 6. press unlock button, attach testpoint when asked (upload testpoint pictures) |
| | #4 (permalink) |
| FLASHING OF DB2020,PNX5230 PHONES common for all CID: 1. go to semc tab, select proper model 2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important. 3. select in misc. field needed CUSTPACK (.zip archive with customization files) 4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash" 5. please read notes below 6. set other settings according your needs. 7. back to semc tab, press flash. CID 36 such phones should be upgraded to CID 49 via writing of corresponding EROM. CID 49,51,52,53 signed mode 5. check signed mode that is preferred mode if you need just flash phone. standalone altbypass mode 5. check "signed mode", "use alternative security bypass" restoration files required bypass package required please read FAQ post about alternative security bypass that is preferred mode if you want to do some additional operations during flashing process. please note, that if you put in misc. edit any file, which is NOT custpack archive, it will be treated as script command file. |
| The Following User Says Thank You to xxxman For This Useful Post: |
| | #5 (permalink) |
| UNLOCKING OF DB2020,PNX5230 PHONES CID 36 that CID is obsolete and upgrade to CID 49 via recovery to CID 49, then writing corresponing EROM required. recovery operation supported for such phones, damaged EROM can be restored without problems. CID 49,51,52,53 CSCA method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","do full unlock instead usercode reset" 5. back on semc tab 6. press unlock button that is obsolete method for unlocking such phones. it should only be used if you want to full unlock PNX5230-based phones. you can not repair damaged SCRC via that method. standalone patch unlock method via alternative security bypass 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass" 5. back on semc tab 6. press unlock button you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. bypass packages required for that method. please read FAQ post about alternative security bypass. RESET-based method standalone RESET-based method 1. select com/ufs/usb as interface 2. go to emptyboard tab 3. select correct model 4. on settings tab, check "signed mode" 5. back on emptyboard tab 6. press RECOVERY button 7. on settings tab, UNcheck "signed mode" 8. add to firmware area corresponding EROM from EROMS\ folder, EROM CID should be >= OTP CID 9. press flash it is advised to read FAQ post about reset operation. that method is NOT supported on PNX5230-based phones. that is recommended method to unlock DB2020-based phones. recovery operation not supported for such phones, reset operation should be used in order to repair damaged EROM. you can repair damaged GDFS, damaged SCRC via reset operation for such phones. |
| | #6 (permalink) |
| POSSIBLE PROBLEMS after flash, phone said "configuration error,please contact provider write custpack or use "customize phone after flash" option. alternative security bypass failed because of missing rest file,phone dead get rest file, check only preloader security bypass and press unlock or reflash supported firmware with "signed mode" only checked damaged security units, damaged gdfs area,damaged EROM CID 16,17,24,29,36,37 1. select proper model 2. on settings, check "format gdfs when writing" 3. press recovery 4. add to firmware area proper EROM if applicable 5. press flash 6. add to misc. field [b]gdfs in .bin format/b] 7. press write gdfs 8. press unlock 9. reflash phone CID 41,42,54,73 disassemble phone. 1. select proper model 2. on settings, check "format gdfs when writing", "use testpoint (gnd method)" 3. add to misc. field [b]gdfs in .bin format/b] 4. press write gdfs 5. press unlock 6. reflash phone you must use testpoint for such phones (upload testpoint pictures) CID 49 1. select proper model 2. on settings, check "unlock during flash process" 3. add to firmware area proper gdfs in ssw format 4. if desired, add to firmware area proper main,fsimage 5. press flash please note, if EROM damaged on such phones, you must execute reset operation. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
