10-07-2015, 10:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | LG GPad V411 Unlocked with lgetool Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8926 Firmware Released: Feb 13 2015 18:53:00 Firmware Compiled: Jun 19 2014 10:00:00 Firmware Version: V41109A/MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 3..............................6 Connect mode: Normal Info received Receiving phone info Getting phone info Model: V411 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8926 Firmware Released: Feb 13 2015 18:53:00 Firmware Compiled: Jun 19 2014 10:00:00 Firmware Version: V41109A/MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 35......................06-005..........-6 Connect mode: Normal Info received Unlocking phone Unlock: Start Backuping NVM to file: Backups\V411_nvm_359399060056986_2015-10-7_13-8-11.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\V411_efs_359399060056986_2015-10-7_13-14-16.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_me.conf 1.34 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 214 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1020 bytes Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 710 bytes Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 3.62 Kb Downloading file /nv/item_files/conf/geran.conf 641 bytes Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 2.91 Kb Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.69 Kb Downloading file /nv/item_files/conf/mc.conf 644 bytes Downloading file /nv/item_files/conf/mcfg.conf 176 bytes Downloading file /nv/item_files/conf/mcpm.conf 101 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.41 Kb Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 502 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 1.40 Kb Downloading file /nv/item_files/conf/mmode.conf 1.47 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.21 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 227 bytes Downloading file /nv/item_files/conf/pbm.conf 238 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 316 bytes Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes Downloading file /nv/item_files/conf/reg.conf 1.13 Kb Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes Downloading file /nv/item_files/conf/tdscdma_l1.conf 1.42 Kb Downloading file /nv/item_files/conf/tdscdma_rrc.conf 2.00 Kb Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 542 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 700 bytes Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Downloading file /nv/item_files/conf/wl1_cme.conf 171 bytes Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wl1ul.conf 43 bytes Downloading file /nv/item_files/conf/wms.conf 410 bytes Downloading file /nv/item_files/gps/cgps/me/gnss_config 4 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 2.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/1x_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/default_tech_ddr_freq_plan 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gps_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm1_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm2_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm3_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/hdr_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_sec_ca_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/tdscdma_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/wcdma_victim_ddr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table 768 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/lte/rrc/rohc_supported 1 bytes Downloading file /nv/item_files/modem/mmode/sd/sdssscr_timers 204 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/uim/gstk/rat_priority_config 26 bytes Downloading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/rfnv/00022958 691 bytes Downloading file /nv/item_files/rfnv/00022960 698 bytes Downloading file /nv/item_files/rfnv/00022961 726 bytes Downloading file /nv/item_files/rfnv/00022967 676 bytes Downloading file /nv/item_files/rfnv/00022975 696 bytes Downloading file /nv/item_files/rfnv/00022976 704 bytes Downloading file /nv/item_files/rfnv/00022978 752 bytes Downloading file /nv/item_files/rfnv/00022982 529 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking connect in LAF-Emergency Mode: OK Imei: ............05....... Pid: CB45S150211003142 ModelName: LG-V411 BatteryLevel: 59% DeviceSwVersion: V41110c DeviceFactoryVersion: LGV411AT-01-V10c-302-720-FEB-13-2015+0 ChipsetPlatform: msm8226 HardwareRevision: rev_10 LafSwVersion: 1.0 DeviceFactoryOutVersion: LGV411AT-00-V10c-RGS-CA-FEB-13-2015+0 Dumping Security Backup... Reading modemst1 [28000, 1800] Reading modemst1: OK Reading modemst2 [29800, 1800] Reading modemst2: OK Backuping Security to file: Backups\V411_security_359399060056986_2015-10-7_13-15-15.sbf Writing security to file... Writing security to file: OK Dumping Security Backup: OK Flashing Patched Security... Writing modemst1 [28000, 1800] Writing modemst1: OK Writing modemst2 [29800, 1800] Writing modemst2: OK Flashing Patched Security: OK Switching to normal mode... Switching to normal mode: OK Writing NVM-Backup from file: Backups\V411_nvm_359399060056986_2015-10-7_13-8-11.sbf Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Writing EFS-Backup from file: Backups\V411_efs_359399060056986_2015-10-7_13-14-16.sbf Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Uploading file /nv/item_files/conf/cgps_me.conf 1.34 Kb Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Uploading file /nv/item_files/conf/cgps_pe.conf 214 bytes Uploading file /nv/item_files/conf/cgps_sm.conf 1020 bytes Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 710 bytes Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Uploading file /nv/item_files/conf/data_config_info.conf 3.62 Kb Uploading file /nv/item_files/conf/geran.conf 641 bytes Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Uploading file /nv/item_files/conf/ims.conf 2.91 Kb Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Uploading file /nv/item_files/conf/lte_rrc.conf 3.69 Kb Uploading file /nv/item_files/conf/mc.conf 644 bytes Uploading file /nv/item_files/conf/mcfg.conf 176 bytes Uploading file /nv/item_files/conf/mcpm.conf 101 bytes Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.41 Kb Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 502 bytes Uploading file /nv/item_files/conf/mmgsdi.conf 1.40 Kb Uploading file /nv/item_files/conf/mmode.conf 1.47 Kb Uploading file /nv/item_files/conf/nas_mm.conf 1.21 Kb Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes Uploading file /nv/item_files/conf/onex_srch.conf 227 bytes Uploading file /nv/item_files/conf/pbm.conf 238 bytes Uploading file /nv/item_files/conf/ps_config_info.conf 316 bytes Uploading file /nv/item_files/conf/qmi_data.conf 88 bytes Uploading file /nv/item_files/conf/reg.conf 1.13 Kb Uploading file /nv/item_files/conf/rrc_feature.conf 43 bytes Uploading file /nv/item_files/conf/tdscdma_l1.conf 1.42 Kb Uploading file /nv/item_files/conf/tdscdma_rrc.conf 2.00 Kb Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Uploading file /nv/item_files/conf/uimdrv.conf 542 bytes Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 700 bytes Uploading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Uploading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Uploading file /nv/item_files/conf/wl1_cme.conf 171 bytes Uploading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Uploading file /nv/item_files/conf/wl1_fet.conf 41 bytes Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Uploading file /nv/item_files/conf/wl1ul.conf 43 bytes Uploading file /nv/item_files/conf/wms.conf 410 bytes Uploading file /nv/item_files/gps/cgps/me/gnss_config 4 bytes Uploading file /nv/item_files/mcs/cxm/coex_config_data 2.09 Kb Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/1x_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/default_tech_ddr_freq_plan 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gps_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm1_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm2_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm3_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/hdr_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_sec_ca_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/tdscdma_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/wcdma_victim_ddr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table 768 bytes Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Uploading file /nv/item_files/modem/lte/rrc/rohc_supported 1 bytes Uploading file /nv/item_files/modem/mmode/sd/sdssscr_timers 204 bytes Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes Uploading file /nv/item_files/modem/uim/gstk/rat_priority_config 26 bytes Uploading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Uploading file /nv/item_files/rfnv/00022958 691 bytes Uploading file /nv/item_files/rfnv/00022960 698 bytes Uploading file /nv/item_files/rfnv/00022961 726 bytes Uploading file /nv/item_files/rfnv/00022967 676 bytes Uploading file /nv/item_files/rfnv/00022975 696 bytes Uploading file /nv/item_files/rfnv/00022976 704 bytes Uploading file /nv/item_files/rfnv/00022978 752 bytes Uploading file /nv/item_files/rfnv/00022982 529 bytes Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes Uploading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything). Unlock: Finish Phone successfully unlocked |
11-01-2015, 15:34 | #3 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2472406 Status: Offline Thanks Meter: 0 | If possible someone who has dumped their lg gpad v411 as stated in the above post. Could you please provide me with the boot loader or entire virgin dump so i can fix my dead tablet. I flashed TWRP to the tablet and cannot force a factory reset. via the holding the buttons during boot process. Any help / virgin dumps / bootloader world be an asset. Thank you very much in advance. Last edited by nastypc; 11-01-2015 at 15:44. |
