Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPG-Setool3
Old 12-20-2010, 07:14   #1 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
Post >> Post Here Successfully Flash / Unlock / Gdfs By Se-tools3 Bo <<
Post here successfully
Flash,
Unlock
Gdfs
Repair by Se-tools3 Box
Br,
Parash
The Following 2 Users Say Thank You to Parash+ For This Useful Post:
Old 12-20-2010, 07:19   #2 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
J132 successeful unlocked
SIGNED MODE (USING SERVER).
PLEASE ATTACH TURNED OFF PHONE NOW
IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES...
bootROM version: 0502
Locosto HS detected, booting...
FLASH ID: 0020/88C0 (00010000)
SECURITY AREA BACKUP CREATED.
PHONE IMEI:35710702077710
USERLOCK RESET TO "0000"
TOTAL CALL TIME RESET
Firmware lock check determined.
SIMLOCK PATCH EXECUTED
Updating TA...
Elapsed: 30 secs.
Old 12-20-2010, 07:23   #3 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
w995 unlock done
w995 unlock done
Old 12-20-2010, 07:25   #4 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
w595 unlock done
w595 unlock done ....
no cradeit
Old 12-20-2010, 07:26   #5 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
J105_NAITE Unlock Done .
J105_NAITE Unlock Done ........
v0.915057/UNI
CARD SERIAL: 00134356
Loaded 51 flash descriptors
ALTERNATIVE SECURITY BYPASS ENABLED
PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
CFG:110000000000
ChipID900,EMP protocol:0401
BOOTROM MODE DETECTED
OTP DBG: [1,53,1,35681303255608]
OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303255608 CERT:RED
LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084
LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084
GOT CHALLENGE
GOT SEED:2614A1EA3580CD713580673E
GOT RESPONSE
signoff response ok
P96 AUTH PASSED
DEVICE KEYF6987409CC743470980039B2F886DB3 (0)
RESTARTING...
LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081
LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081
GOT CHALLENGE
GOT SEED:8B7D5C693580CD713580673E
GOT RESPONSE
signoff response ok
P96 AUTH PASSED
RESETTING SECURITY TO FACTORY STATE...
RESTARTING...
OTP LOCKED:1 CID:53 PAF:1 IMEI:35681303255608 CERT:BROWN
LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084
LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084
WRITING SEMCBOOT...
PREPARING SECURITY...
WRITING CLEAR SIMLOCK UNITS...
ALL UNLOCK/LOCK CODES SET TO "53603740"
CHANGING DOMAIN TO "CURRENT"
SIGNING...
DEVICE KEY RESTORED
Unlock FINISHED
Elapsed: 44 secs.
Old 12-20-2010, 07:27   #6 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
T303 unlock done ...........
Elapsed: 19 secs.
CFG:110000000000
PRESS "POWER ON" BUTTON SHORTLY...
EROM "R5A038" AID: 0001
SOFTWARE AID: 0001
SIMLOCK STATE: "NOT_TAMPERED"
LOADER AID: 0002
FLASH ID: "0089/8904"
LOADER VERSION: "R3A011"
PHONE IMEI:35984302340801
GOT SEED:FE10FEED8B01E040C2007772
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Old 12-20-2010, 07:29   #7 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
W302 unlock done ......
v0.915057/UNI
CFG:100000000000
SERVER CREDITS LEFT/USED: 11/19
CARD COUNTERS: FLASH 59, UNLOCK 15
Elapsed: 3 secs.
CFG:110000000000
EROM "R7A021" AID: 0001
SOFTWARE AID: 0001
LOADER AID: 0002
FLASH ID: "00EC/220C"
PHONE IMEI:35653502640038
GOT SEED:FD529967830100132F0326F2
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 54 secs.
Old 12-20-2010, 07:29   #8 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
S312 Unlock Done ...............
CFG:110000000000
EROM "R7A024" AID: 0001
SOFTWARE AID: 0001
LOADER AID: 0002
FLASH ID: "0001/307E"
PHONE IMEI:35427003478785
GOT SEED:3E21FD7883010007268C08E6
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 47 secs.
Old 12-20-2010, 07:32   #9 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
W395 unlock done
w395 unlock done..........
signed mode (using server)
alternative security bypass enabled
cfg:110000000000
please attach turned off phone now
press "power on" button shortly...
Erom "r7a024" aid: 0001
software aid: 0001
simlock state: "not_tampered"
loader aid: 0002
flash id: "00ec/220c"
loader version: "r3a011"
phone imei:35790603783693
got seed:ea0094a18201d023268c2c5e
p96 auth passed
searching...
Simlock check found
writing...
Unlock done
elapsed: 44 secs.
Old 12-20-2010, 07:33   #10 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
C510 Unlock done.....
C510 Unlock done..........
C510
v0.915057/UNI
CFG:110000000000
ChipID:C802,EMP protocol:0401
OTP DBG: [1,52,1,35893601546061]
OTP LOCKED:1 CID:52 PAF:1 IMEI:35893601546061 CERT:RED
LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82
DEVICE KEY:517C6AC541005E12D9EC0EA4FED96E8E (0)
LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081
LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081
GOT SEED:792C1CD83480187A15D05085
P96 AUTH PASSED
RESTARTING...
OTP LOCKED:1 CID:52 PAF:1 IMEI:35893601546061 CERT:BROWN
LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82
WRITING SEMCBOOT...
ALL UNLOCK/LOCK CODES SET TO "37744363"
SIGNING...
DEVICE KEY RESTORED
Unlock FINISHED
Elapsed: 30 secs.
Old 12-20-2010, 07:34   #11 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
C902 Unlock done ......
v0.915057/UNI
CFG:110000000000
ChipID:C900,EMP protocol:0401
OTP DBG: [1,52,1,35362603776810]
OTP LOCKED:1 CID:52 PAF:1 IMEI:35362603776810 CERT:RED
DEVICE KEY:23A764B9FCE7F84080D7D0AEBCD1E165 (0)
GOT SEED:C5E0622534805A6535A0A6BD
P96 AUTH PASSED
RESTARTING...
OTP LOCKED:1 CID:52 PAF:1 IMEI:35362603776810 CERT:BROWN
WRITING SEMCBOOT...
ALL UNLOCK/LOCK CODES SET TO "23368865"
SIGNING...
DEVICE KEY RESTORED
Unlock FINISHED
Elapsed: 31 secs.
Old 12-20-2010, 07:36   #12 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
W205 Unlock Done ........
CFG:110000000000
SOFTWARE AID: 0001
LOADER AID: 0002
PHONE IMEI:35783803480869
GOT SEED:F74FE5AF88016034C2008620
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 40 secs.
Old 12-20-2010, 07:38   #13 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
T280 Unlock Done .....
T280 Unlock Done ......
v0.915057/UNI
CFG:000000000000
ROM version: 0502
FLASH ID: 0089/8904 (00040000)
PHONE IMEI:35342202428266
Updating TA...
Elapsed: 76 secs.
Old 12-20-2010, 07:39   #14 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
W395 Unlock Done .......
CFG:110000000000
SOFTWARE AID: 0001
LOADER AID: 0002
PHONE IMEI:35236203690915
GOT SEED:F68553B88001E01B267F5FC1
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 47 secs.
Old 12-20-2010, 07:41   #15 (permalink)
Moderator
Parash+'s Avatar
Member: 1435864
Sonork: 100.1596506
T280 Unlock Done ...........
v0.915057/UNI
CFG:000000000000
ROM version: 0502
PHONE IMEI:35341102592609
Updating TA...
Elapsed: 69 secs.
Page generated in 0.45534 seconds with 10 queries
