07-15-2016, 01:31 | #1 (permalink) |
Crazy Poster Join Date: May 2007
Member: 509340 Status: Offline Thanks Meter: 2 | problem unlocking lg h815p Connecting with H815P Please Flash Firmware with Android 5.x in order to enable unlock features. Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Please select MTP in USB Connection Dialog on phone. Connected Receiving phone info Getting phone info Model: H815P Platform: LG Qualcomm Software Platform: Android SDRAM Size: 3 GB NAND Flash Size: 32 GB CPU: MSM8992 Firmware Released: Apr 29 2015 09:50:56 Firmware Compiled: Apr 15 2015 21:00:00 Firmware Version: LGH815PAd/MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1 IMEI: 359 Connect mode: Normal Info received Receiving phone info Getting phone info Model: H815P Platform: LG Qualcomm Software Platform: Android SDRAM Size: 3 GB NAND Flash Size: 32 GB CPU: MSM8992 Firmware Released: Apr 29 2015 09:50:56 Firmware Compiled: Apr 15 2015 21:00:00 Firmware Version: LGH815PAd/MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1 IMEI: 359 Connect mode: Normal Info received Unlocking phone Unlock: Start Backuping NVM to file: Backups\H815P_nvm_359_2016-7-14_18-16-26.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\H815P_efs_359_2016-7-14_18-22-1.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_common.conf 56 bytes Downloading file /nv/item_files/conf/cgps_me.conf 3.53 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 478 bytes Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 5.40 Kb Downloading file /nv/item_files/conf/data_profile.conf 154 bytes Downloading file /nv/item_files/conf/dpm_config_info.conf 62 bytes Downloading file /nv/item_files/conf/geran.conf 1.85 Kb Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 3.08 Kb Downloading file /nv/item_files/conf/ipa.conf 424 bytes Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes Downloading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes Downloading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes Downloading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Downloading file /nv/item_files/conf/mc.conf 988 bytes Downloading file /nv/item_files/conf/mcfg.conf 216 bytes Downloading file /nv/item_files/conf/mcpm.conf 246 bytes Downloading file /nv/item_files/conf/mcs_as_div.conf 43 bytes Downloading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb Downloading file /nv/item_files/conf/mmode.conf 2.74 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.59 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 303 bytes Downloading file /nv/item_files/conf/pbm.conf 278 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 664 bytes Downloading file /nv/item_files/conf/qmi_data.conf 135 bytes Downloading file /nv/item_files/conf/reg.conf 1.68 Kb Downloading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb Downloading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 407 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wms.conf 558 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes Downloading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/rfnv/00022982 484 bytes Downloading file /nv/item_files/rfnv/00024226 777 bytes Downloading file /nv/item_files/rfnv/00024227 782 bytes Downloading file /nv/item_files/rfnv/00024228 768 bytes Downloading file /nv/item_files/rfnv/00024229 759 bytes Downloading file /nv/item_files/rfnv/00024230 737 bytes Downloading file /nv/item_files/rfnv/00024232 765 bytes Downloading file /nv/item_files/rfnv/00024233 763 bytes Downloading file /nv/item_files/rfnv/00024240 781 bytes Downloading file /nv/item_files/rfnv/00024243 727 bytes Downloading file /nv/item_files/rfnv/00024250 789 bytes Downloading file /nv/item_files/rfnv/00024252 766 bytes Downloading file /nv/item_files/rfnv/00024253 779 bytes Downloading file /nv/item_files/rfnv/00024255 784 bytes Downloading file /nv/item_files/rfnv/00024256 797 bytes Downloading file /nv/item_files/rfnv/00024964 193 bytes Downloading file /nv/item_files/rfnv/00024965 193 bytes Downloading file /nv/item_files/rfnv/00024966 193 bytes Downloading file /nv/item_files/rfnv/00024967 193 bytes Downloading file /nv/item_files/rfnv/00024972 2.97 Kb Downloading file /nv/item_files/rfnv/00024973 2.97 Kb Downloading file /nv/item_files/rfnv/00024974 2.49 Kb Downloading file /nv/item_files/rfnv/00024975 2.49 Kb Downloading file /nv/item_files/rfnv/00025004 192 bytes Downloading file /nv/item_files/rfnv/00025005 192 bytes Downloading file /nv/item_files/rfnv/00025006 192 bytes Downloading file /nv/item_files/rfnv/00025007 192 bytes Downloading file /nv/item_files/rfnv/00025044 160 bytes Downloading file /nv/item_files/rfnv/00025045 160 bytes Downloading file /nv/item_files/rfnv/00025046 160 bytes Downloading file /nv/item_files/rfnv/00025047 160 bytes Downloading file /nv/item_files/rfnv/00025179 384 bytes Downloading file /nv/item_files/rfnv/00025288 384 bytes Downloading file /nv/item_files/rfnv/00025394 384 bytes Downloading file /nv/item_files/rfnv/00025479 1.69 Kb Downloading file /nv/item_files/rfnv/00025481 737 bytes Downloading file /nv/item_files/rfnv/00025760 1.67 Kb Downloading file /nv/item_files/rfnv/00025761 745 bytes Downloading file /nv/item_files/rfnv/00026584 289 bytes Downloading file /nv/item_files/rfnv/00026599 289 bytes Downloading file /nv/item_files/rfnv/00026600 289 bytes Downloading file /nv/item_files/rfnv/00026603 289 bytes Downloading file /nv/item_files/rfnv/00026650 1.54 Kb Downloading file /nv/item_files/rfnv/00026652 1.54 Kb Downloading file /nv/item_files/rfnv/00026654 1.54 Kb Downloading file /nv/item_files/rfnv/00026656 1.54 Kb Downloading file /nv/item_files/rfnv/00026658 805 bytes Downloading file /nv/item_files/rfnv/00026660 1.54 Kb Downloading file /nv/item_files/rfnv/00026662 805 bytes Downloading file /nv/item_files/rfnv/00026666 805 bytes Downloading file /nv/item_files/rfnv/00026672 805 bytes Downloading file /nv/item_files/rfnv/00026678 1.54 Kb Downloading file /nv/item_files/rfnv/00026686 1.54 Kb Downloading file /nv/item_files/rfnv/00026865 805 bytes Downloading file /nv/item_files/rfnv/00026867 805 bytes Downloading file /nv/item_files/rfnv/00026873 805 bytes Downloading file /nv/item_files/rfnv/00026875 805 bytes Downloading file /nv/item_files/rfnv/00027157 131 bytes Downloading file /nv/item_files/rfnv/00027158 131 bytes Downloading file /nv/item_files/rfnv/00027159 131 bytes Downloading file /nv/item_files/rfnv/00027193 1.54 Kb Downloading file /nv/item_files/rfnv/00027293 1.00 Kb Downloading file /nv/item_files/rfnv/00027294 1.00 Kb Downloading file /nv/item_files/rfnv/00027345 129 bytes Downloading file /nv/item_files/rfnv/00027346 129 bytes Downloading file /nv/item_files/rfnv/00027349 129 bytes Downloading file /nv/item_files/rfnv/00027350 129 bytes Downloading file /nv/item_files/rfnv/00027391 129 bytes Downloading file /nv/item_files/rfnv/00027392 129 bytes Downloading file /nv/item_files/rfnv/00027393 129 bytes Downloading file /nv/item_files/rfnv/00027394 129 bytes Downloading file /nv/item_files/rfnv/00027395 129 bytes Downloading file /nv/item_files/rfnv/00027397 129 bytes Downloading file /nv/item_files/rfnv/00027398 129 bytes Downloading file /nv/item_files/rfnv/00027405 129 bytes Downloading file /nv/item_files/rfnv/00027408 129 bytes Downloading file /nv/item_files/rfnv/00027414 129 bytes Downloading file /nv/item_files/rfnv/00027421 129 bytes Downloading file /nv/item_files/rfnv/00027426 129 bytes Downloading file /nv/item_files/rfnv/00027473 131 bytes Downloading file /nv/item_files/rfnv/00027474 131 bytes Downloading file /nv/item_files/rfnv/00027475 131 bytes Downloading file /nv/item_files/rfnv/00027476 131 bytes Downloading file /nv/item_files/rfnv/00027477 131 bytes Downloading file /nv/item_files/rfnv/00027478 131 bytes Downloading file /nv/item_files/rfnv/00027479 131 bytes Downloading file /nv/item_files/rfnv/00027480 131 bytes Downloading file /nv/item_files/rfnv/00027481 131 bytes Downloading file /nv/item_files/rfnv/00027482 131 bytes Downloading file /nv/item_files/rfnv/00027656 464 bytes Downloading file /nv/item_files/rfnv/00027657 464 bytes Downloading file /nv/item_files/rfnv/00027658 464 bytes Downloading file /nv/item_files/rfnv/00027659 464 bytes Downloading file /nv/item_files/rfnv/00027675 464 bytes Downloading file /nv/item_files/rfnv/00027683 464 bytes Downloading file /nv/item_files/rfnv/00027699 464 bytes Downloading file /nv/item_files/rfnv/00028049 416 bytes Downloading file /nv/item_files/rfnv/00028050 384 bytes Downloading file /nv/item_files/rfnv/00028051 375 bytes Downloading file /nv/item_files/rfnv/00028052 345 bytes Downloading file /nv/item_files/rfnv/00028053 393 bytes Downloading file /nv/item_files/rfnv/00028055 315 bytes Downloading file /nv/item_files/rfnv/00028056 402 bytes Downloading file /nv/item_files/rfnv/00028065 273 bytes Downloading file /nv/item_files/rfnv/00028068 363 bytes Downloading file /nv/item_files/rfnv/00028076 454 bytes Downloading file /nv/item_files/rfnv/00028077 454 bytes Downloading file /nv/item_files/rfnv/00028089 403 bytes Downloading file /nv/item_files/rfnv/00028148 328 bytes Downloading file /nv/item_files/rfnv/00028150 354 bytes Downloading file /nv/item_files/rfnv/00028156 358 bytes Downloading file /nv/item_files/rfnv/00028158 258 bytes Downloading file /nv/item_files/rfnv/00028170 348 bytes Downloading file /nv/item_files/rfnv/00028171 374 bytes Downloading file /nv/item_files/rfnv/00028172 353 bytes Downloading file /nv/item_files/rfnv/00028173 355 bytes Downloading file /nv/item_files/rfnv/00028174 281 bytes Downloading file /nv/item_files/rfnv/00028176 323 bytes Downloading file /nv/item_files/rfnv/00028177 305 bytes Downloading file /nv/item_files/rfnv/00028184 320 bytes Downloading file /nv/item_files/rfnv/00028187 264 bytes Downloading file /nv/item_files/rfnv/00028193 329 bytes Downloading file /nv/item_files/rfnv/00028194 329 bytes Downloading file /nv/item_files/rfnv/00028202 436 bytes Downloading file /nv/item_files/rfnv/00028216 201 bytes Downloading file /nv/item_files/rfnv/00028217 210 bytes Downloading file /nv/item_files/rfnv/00028220 150 bytes Downloading file /nv/item_files/rfnv/00028221 175 bytes Downloading file /nv/item_files/rfnv/00028493 204 bytes Downloading file /nv/item_files/rfnv/00028494 208 bytes Downloading file /nv/item_files/rfnv/00028495 211 bytes Downloading file /nv/item_files/rfnv/00028496 211 bytes Downloading file /nv/item_files/rfnv/00028499 205 bytes Downloading file /nv/item_files/rfnv/00028525 204 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/conf/policyman.conf 197 bytes Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Backuping SNV [1] to file: Backups\H815P_snv1_359_2016-7-14_18-27-19.sbf Dump SNV [1]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Dumping SNV [1]... Dumping SNV [1]: OK Switching to normal mode... Switching to normal mode: OK Dump SNV [1]: Finish Backuping SNV [2] to file: Backups\H815P_snv2_359_2016-7-14_18-30-57.sbf Dump SNV [2]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Dumping SNV [2]... Dumping SNV [2]: OK Switching to normal mode... Switching to normal mode: OK Dump SNV [2]: Finish Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking connect in LAF-Emergency Mode: OK Imei: 359 Pid: YE07S150601001597 ModelName: LG-H815P BatteryLevel: 44% DeviceSwVersion: H81510a DeviceFactoryVersion: LGH815PAT-01-V10a-334-050-APR-29-2015+0 ChipsetPlatform: msm8992 HardwareRevision: rev_10 LafSwVersion: 1.1 DeviceFactoryOutVersion: LGH815PAT-00-V10a-OPT5-SP-APR-29-2015+0 Dumping Security Backup... Reading modemst1 [58000, c00] Reading modemst1: OK Reading modemst2 [58c00, c00] Reading modemst2: OK Backuping Security to file: Backups\H815P_security_359_2016-7-14_18-35-21.sbf Writing security to file... Writing security to file: OK Dumping Security Backup: OK Flashing Patched Security... Writing modemst1 [58000, c00] Writing modemst1: OK Writing modemst2 [58c00, c00] Writing modemst2: OK Flashing Patched Security: OK Switching to normal mode... Switching to normal mode: OK Writing NVM-Backup from file: Backups\H815P_nvm_359_2016-7-14_18-16-26.sbf Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Writing EFS-Backup from file: Backups\H815P_efs_359_2016-7-14_18-22-1.sbf Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Uploading file /nv/item_files/conf/cgps_common.conf 56 bytes Uploading file /nv/item_files/conf/cgps_me.conf 3.53 Kb Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Uploading file /nv/item_files/conf/cgps_pe.conf 478 bytes Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Uploading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Uploading file /nv/item_files/conf/data_config_info.conf 5.40 Kb Uploading file /nv/item_files/conf/data_profile.conf 154 bytes Uploading file /nv/item_files/conf/dpm_config_info.conf 62 bytes Uploading file /nv/item_files/conf/geran.conf 1.85 Kb Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Uploading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Uploading file /nv/item_files/conf/ims.conf 3.08 Kb Uploading file /nv/item_files/conf/ipa.conf 424 bytes Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes Uploading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes Uploading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes Uploading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Uploading file /nv/item_files/conf/mc.conf 988 bytes Uploading file /nv/item_files/conf/mcfg.conf 216 bytes Uploading file /nv/item_files/conf/mcpm.conf 246 bytes Uploading file /nv/item_files/conf/mcs_as_div.conf 43 bytes Uploading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Uploading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb Uploading file /nv/item_files/conf/mmode.conf 2.74 Kb Uploading file /nv/item_files/conf/nas_mm.conf 1.59 Kb Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes Uploading file /nv/item_files/conf/onex_srch.conf 303 bytes Uploading file /nv/item_files/conf/pbm.conf 278 bytes Uploading file /nv/item_files/conf/ps_config_info.conf 664 bytes Uploading file /nv/item_files/conf/qmi_data.conf 135 bytes Uploading file /nv/item_files/conf/reg.conf 1.68 Kb Uploading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb Uploading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Uploading file /nv/item_files/conf/uimdrv.conf 407 bytes Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Uploading file /nv/item_files/conf/wms.conf 558 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes Uploading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes Uploading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Uploading file /nv/item_files/rfnv/00022982 484 bytes Uploading file /nv/item_files/rfnv/00024226 777 bytes Uploading file /nv/item_files/rfnv/00024227 782 bytes Uploading file /nv/item_files/rfnv/00024228 768 bytes Uploading file /nv/item_files/rfnv/00024229 759 bytes Uploading file /nv/item_files/rfnv/00024230 737 bytes Uploading file /nv/item_files/rfnv/00024232 765 bytes Uploading file /nv/item_files/rfnv/00024233 763 bytes Uploading file /nv/item_files/rfnv/00024240 781 bytes Uploading file /nv/item_files/rfnv/00024243 727 bytes Uploading file /nv/item_files/rfnv/00024250 789 bytes Uploading file /nv/item_files/rfnv/00024252 766 bytes Uploading file /nv/item_files/rfnv/00024253 779 bytes Uploading file /nv/item_files/rfnv/00024255 784 bytes Uploading file /nv/item_files/rfnv/00024256 797 bytes Uploading file /nv/item_files/rfnv/00024964 193 bytes Uploading file /nv/item_files/rfnv/00024965 193 bytes Uploading file /nv/item_files/rfnv/00024966 193 bytes Uploading file /nv/item_files/rfnv/00024967 193 bytes Uploading file /nv/item_files/rfnv/00024972 2.97 Kb Uploading file /nv/item_files/rfnv/00024973 2.97 Kb Uploading file /nv/item_files/rfnv/00024974 2.49 Kb Uploading file /nv/item_files/rfnv/00024975 2.49 Kb Uploading file /nv/item_files/rfnv/00025004 192 bytes Uploading file /nv/item_files/rfnv/00025005 192 bytes Uploading file /nv/item_files/rfnv/00025006 192 bytes Uploading file /nv/item_files/rfnv/00025007 192 bytes Uploading file /nv/item_files/rfnv/00025044 160 bytes Uploading file /nv/item_files/rfnv/00025045 160 bytes Uploading file /nv/item_files/rfnv/00025046 160 bytes Uploading file /nv/item_files/rfnv/00025047 160 bytes Uploading file /nv/item_files/rfnv/00025179 384 bytes Uploading file /nv/item_files/rfnv/00025288 384 bytes Uploading file /nv/item_files/rfnv/00025394 384 bytes Uploading file /nv/item_files/rfnv/00025479 1.69 Kb Uploading file /nv/item_files/rfnv/00025481 737 bytes Uploading file /nv/item_files/rfnv/00025760 1.67 Kb Uploading file /nv/item_files/rfnv/00025761 745 bytes Uploading file /nv/item_files/rfnv/00026584 289 bytes Uploading file /nv/item_files/rfnv/00026599 289 bytes Uploading file /nv/item_files/rfnv/00026600 289 bytes Uploading file /nv/item_files/rfnv/00026603 289 bytes Uploading file /nv/item_files/rfnv/00026650 1.54 Kb Uploading file /nv/item_files/rfnv/00026652 1.54 Kb Uploading file /nv/item_files/rfnv/00026654 1.54 Kb Uploading file /nv/item_files/rfnv/00026656 1.54 Kb Uploading file /nv/item_files/rfnv/00026658 805 bytes Uploading file /nv/item_files/rfnv/00026660 1.54 Kb Uploading file /nv/item_files/rfnv/00026662 805 bytes Uploading file /nv/item_files/rfnv/00026666 805 bytes Uploading file /nv/item_files/rfnv/00026672 805 bytes Uploading file /nv/item_files/rfnv/00026678 1.54 Kb Uploading file /nv/item_files/rfnv/00026686 1.54 Kb Uploading file /nv/item_files/rfnv/00026865 805 bytes Uploading file /nv/item_files/rfnv/00026867 805 bytes Uploading file /nv/item_files/rfnv/00026873 805 bytes Uploading file /nv/item_files/rfnv/00026875 805 bytes Uploading file /nv/item_files/rfnv/00027157 131 bytes Uploading file /nv/item_files/rfnv/00027158 131 bytes Uploading file /nv/item_files/rfnv/00027159 131 bytes Uploading file /nv/item_files/rfnv/00027193 1.54 Kb Uploading file /nv/item_files/rfnv/00027293 1.00 Kb Uploading file /nv/item_files/rfnv/00027294 1.00 Kb Uploading file /nv/item_files/rfnv/00027345 129 bytes Uploading file /nv/item_files/rfnv/00027346 129 bytes Uploading file /nv/item_files/rfnv/00027349 129 bytes Uploading file /nv/item_files/rfnv/00027350 129 bytes Uploading file /nv/item_files/rfnv/00027391 129 bytes Uploading file /nv/item_files/rfnv/00027392 129 bytes Uploading file /nv/item_files/rfnv/00027393 129 bytes Uploading file /nv/item_files/rfnv/00027394 129 bytes Uploading file /nv/item_files/rfnv/00027395 129 bytes Uploading file /nv/item_files/rfnv/00027397 129 bytes Uploading file /nv/item_files/rfnv/00027398 129 bytes Uploading file /nv/item_files/rfnv/00027405 129 bytes Uploading file /nv/item_files/rfnv/00027408 129 bytes Uploading file /nv/item_files/rfnv/00027414 129 bytes Uploading file /nv/item_files/rfnv/00027421 129 bytes Uploading file /nv/item_files/rfnv/00027426 129 bytes Uploading file /nv/item_files/rfnv/00027473 131 bytes Uploading file /nv/item_files/rfnv/00027474 131 bytes Uploading file /nv/item_files/rfnv/00027475 131 bytes Uploading file /nv/item_files/rfnv/00027476 131 bytes Uploading file /nv/item_files/rfnv/00027477 131 bytes Uploading file /nv/item_files/rfnv/00027478 131 bytes Uploading file /nv/item_files/rfnv/00027479 131 bytes Uploading file /nv/item_files/rfnv/00027480 131 bytes Uploading file /nv/item_files/rfnv/00027481 131 bytes Uploading file /nv/item_files/rfnv/00027482 131 bytes Uploading file /nv/item_files/rfnv/00027656 464 bytes Uploading file /nv/item_files/rfnv/00027657 464 bytes Uploading file /nv/item_files/rfnv/00027658 464 bytes Uploading file /nv/item_files/rfnv/00027659 464 bytes Uploading file /nv/item_files/rfnv/00027675 464 bytes Uploading file /nv/item_files/rfnv/00027683 464 bytes Uploading file /nv/item_files/rfnv/00027699 464 bytes Uploading file /nv/item_files/rfnv/00028049 416 bytes Uploading file /nv/item_files/rfnv/00028050 384 bytes Uploading file /nv/item_files/rfnv/00028051 375 bytes Uploading file /nv/item_files/rfnv/00028052 345 bytes Uploading file /nv/item_files/rfnv/00028053 393 bytes Uploading file /nv/item_files/rfnv/00028055 315 bytes Uploading file /nv/item_files/rfnv/00028056 402 bytes Uploading file /nv/item_files/rfnv/00028065 273 bytes Uploading file /nv/item_files/rfnv/00028068 363 bytes Uploading file /nv/item_files/rfnv/00028076 454 bytes Uploading file /nv/item_files/rfnv/00028077 454 bytes Uploading file /nv/item_files/rfnv/00028089 403 bytes Uploading file /nv/item_files/rfnv/00028148 328 bytes Uploading file /nv/item_files/rfnv/00028150 354 bytes Uploading file /nv/item_files/rfnv/00028156 358 bytes Uploading file /nv/item_files/rfnv/00028158 258 bytes Uploading file /nv/item_files/rfnv/00028170 348 bytes Uploading file /nv/item_files/rfnv/00028171 374 bytes Uploading file /nv/item_files/rfnv/00028172 353 bytes Uploading file /nv/item_files/rfnv/00028173 355 bytes Uploading file /nv/item_files/rfnv/00028174 281 bytes Uploading file /nv/item_files/rfnv/00028176 323 bytes Uploading file /nv/item_files/rfnv/00028177 305 bytes Uploading file /nv/item_files/rfnv/00028184 320 bytes Uploading file /nv/item_files/rfnv/00028187 264 bytes Uploading file /nv/item_files/rfnv/00028193 329 bytes Uploading file /nv/item_files/rfnv/00028194 329 bytes Uploading file /nv/item_files/rfnv/00028202 436 bytes Uploading file /nv/item_files/rfnv/00028216 201 bytes Uploading file /nv/item_files/rfnv/00028217 210 bytes Uploading file /nv/item_files/rfnv/00028220 150 bytes Uploading file /nv/item_files/rfnv/00028221 175 bytes Uploading file /nv/item_files/rfnv/00028493 204 bytes Uploading file /nv/item_files/rfnv/00028494 208 bytes Uploading file /nv/item_files/rfnv/00028495 211 bytes Uploading file /nv/item_files/rfnv/00028496 211 bytes Uploading file /nv/item_files/rfnv/00028499 205 bytes Uploading file /nv/item_files/rfnv/00028525 204 bytes Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes Uploading file /nv/reg_files/conf/policyman.conf 197 bytes Uploading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Writing SNV-Backup [1] from file: Backups\H815P_snv1_3_2016-7-14_18-27-19.sbf Flash SNV [1]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Flashing SNV [1]... Flashing SNV [1]: OK Switching to normal mode... Switching to normal mode: OK Flash SNV [1]: Finish Writing SNV-Backup [2] from file: Backups\H815P_snv2_35-7-14_18-30-57.sbf Flash SNV [2]: Start Getting phone info... Getting phone info: OK Switching to SNV mode... Reading SPC... Reading SPC: OK Sending SPC... Sending SPC: OK Switching to SNV mode: OK Flashing SNV [2]... Flashing SNV [2]: OK Switching to normal mode... Switching to normal mode: OK Flash SNV [2]: Finish Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything). Unlock: Finish Phone successfully unlocked |
