06-12-2012, 20:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: spain
Member: 980172 Status: Offline Thanks Meter: 85 | cannot unlock E15i ...help [SOLVED] current updater version: 0.95 current setool2 version: 1.1287 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 17, UNLOCK 94 Elapsed: 4 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 6A1DF7DB8298D31CED9EB04C670921D0A72EFC28 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 012448005xxxx Checking for signature ... REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... failed, err: [error: protocol fault (no status) ] Unlock FAILED Elapsed: 113 secs. |
06-12-2012, 20:41 | #2 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Quote:
Did u root the Phone ? | |
06-13-2012, 07:39 | #6 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | @ zatman Flash Ur Phone to 2.1 Version & Then Unlock ur Phone again If Still same Problem then Disable ur antivirus & then try again |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
06-15-2012, 19:44 | #7 (permalink) |
Member: 980172 Status: Offline Thanks Meter: 85 | yes sure i dont remember onlly v2.x is supported... thanks solved after flashed online by pc companion .unlocked by setool3 gpg SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 6A1DF7DB8298D31CED9EB04C670921D0A72EFC28 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 0124480056xxxx Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 122 secs. |
