Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2004 Location: jamshedpur Age: 27
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks: 684
| WARNING !!! As there is too much "blocked" setool2 GEMALTO TOP cards,we investigated issue and found problem. due to errors in controller firmware ( or due to incompatibility between smartcard/controller firmware/motherboard usb controller ) all smartcard readers i know, which are based on CY7C63001 are failed to send long data packet to/from smartcard. it happens on some systems only, it can happen not immediately, but on "affected" system it happens always, earlier or later. due to that, smartcard will receive WRONG command and SETOOL2 WILL BE "BLOCKED". THAT IS NOT RELATED TO "BLOCKED CARDMANAGER" ISSUE ( ERROR #6982 ) i can not find ANY solution to that problem, other than NOT using Cypress CY7C63001-based readers with setool2 cards. here is few pictures of AFFECTED readers: you can also identify such reader by smartcard reader name and driver name: if you will use that readers, your setool2 smartcard WILL BE BLOCKED - and i will unblock such card ONLY ONCE. IMPORTANT ! I WILL ONLY UNBLOCK GEMALTO-TOP SMARTCARDS - WITH SERIAL 177500 and above my strong recommendation is use om****y-based readers, like that: they are working 100% on any system. of course, usage of latest setool2 version is ABSOLUTE requirement. QUESTIONS AND ANSWERS q: What is card update? which card need to be updated? a: SmartCard update required to use 1.107 and following setool2 versions. All SEtool cards with serial numbers till 177500 must be updated. q: how to update setool2 card ? what do i need ? a: to update setool2 card, you need valid setool2 account, normal internet connection ( NOT proxy ), open TCP ports 443,1934 put updater ( updater.zip ) in setool2 directory, it will auto read settings from setool2.ini. Or extract it to any desired directory and fill username,password,server manually. server address is: Code: srv01.dontexist.com current updater version is 0.95 !!! any lower versions will NOT work !!! if you do not have valid setool2 account, use special updater account: Code: username=updater password=updater ( remove all smartcards from pc except setool2 one in order to avoid misunderstanding ) you will get "Ready to work" text. press "update card" button only after you get that. if your setool2 card not activated ( you can NOT use setool2 version > 1.01 ) you need 20 credits for initial card update. Credits will be discounted AUTOMATICALLY WITHOUT CONFIRMATION. if your card eligible for update, you will see following text: Code: setool2 SmartCard updater [x.xx] server read: "srv01.dontexist.com" username read: "update_test" Please click on reader with setool2 SmartCard. Ready to work SmartCard update started..... CARD SERIAL: 12345678 Checking with server... setool2 card not activated, credits will be used...... Uploading............................................................................ Update completed in time after time, we will update setool2 smartcard, corresponding notice will be posted in news. for normal update you do not need any credits, but valid setool2 account required. if your card eligible for normal update, you will see following text: Code: setool2 SmartCard updater [x.xx] server read: "srv01.dontexist.com" username read: "update_test" Please click on reader with setool2 SmartCard. Ready to work SmartCard update started... CARD SERIAL: 12345678 Checking with server......... Uploading............................................................................ Update completed Code: SmartCard update started... CARD SERIAL: 12345678 Checking with server. cmd err: [request denied] if you will get next error message : Code: Please click on reader with setool2 SmartCard. Ready to work SmartCard update started.. CARD IS BLOCKED. RECOVERY SERIAL: xxxxxxxxxxxxxxxx Checking with server.. auth #0 err: [request denied] - your account username - setool2 card original serial - reported recovery serial admin will check issue and write resolution. most bad thing that can happen: if you will get next results Code: SmartCard update started..... CARD SERIAL: 00xxxxxxx Checking with server...... auth #1 err: 6982 that means your card was permanently tampered by some tools and you stuck to v1.106 nothing can be done at all. please note, that after initial update you can only use setool2 version >= v1.107 q: how to activate LGTool ? what do i need ? a: to activate LGTool, you need valid setool2 account, normal internet connection ( NOT proxy ), open TCP ports 443,1934 you do not need to have setool2 credits on account. put attached updater in setool2 directory ( it will auto read settings from setool2.ini ) or extract it to any desired directory and fill username,password,server manually. server address is: Code: srv01.dontexist.com ( remove all smartcards from pc except setool2 one in order to avoid misunderstanding ) you will get "Ready to work" text. Then press "Activate LGTool" button if your card eligible for activation, you will get next text: Code: setool2 SmartCard updater [x.xx] server read: "srv01.dontexist.com" username read: "update_test" Please click on reader with setool2 SmartCard. Ready to work Checking with server.. LG application activated Code: NOTE : always use latest updater for card update and activation Last edited by Danish Shafiq; 04-17-2012 at 05:50. Reason: Updated |
| The Following 3 Users Say Thank You to xxxman For This Useful Post: |
| | #2 (permalink) |
| even server is down . everyone is unlocking most of sony ericsson phones with setool . although you can also unlock most of new android phones . |
| | #4 (permalink) |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: paris Age: 33
Member: 24284 Status: Offline Thanks: 64
| SmartCard update started... CARD SERIAL: 00033483 Checking with server. cmd err: [request denied] second time i get SmartCard update started... CARD SERIAL: 00033483 Checking with server. recv err: [Connection reset by peer] user name: simo11 |
| | #6 (permalink) | |
| Quote:
any questions about smartcard problems should be posted in corresponding sticky thread,here if you can not run recent setool2 version, please follow instructions here | |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003
Member: 37015 Status: Offline Thanks: 634
| Ready to work SmartCard update started.. CARD IS BLOCKED. RECOVERY SERIAL: 3541081F Checking with server.. recv err: [Connection reset by peer] it is new setool from gpg.we updated and used this but it showed blocked card while flashing. ple give me solution. |
| | #8 (permalink) | |
| Quote:
read first post . the only thing i can say is try this way and post as described . any questions about smartcard problems should be posted in corresponding sticky thread,here if you can not run recent setool2 version, please follow instructions here | |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ghana Age: 32
Member: 171776 Status: Offline Thanks: 4
| plz help to update my card Ready to work SmartCard update started... CARD SERIAL: 00186283 Checking with server. cmd err: [request denied] |
| | #10 (permalink) | |
| Quote:
anyway . just tick on signed mode and customize phone after flash and press flash . | |
| | #13 (permalink) |
| Junior Member Join Date: Jun 2011
Member: 1599026 Status: Offline Thanks: 0
| Ready to work SmartCard update started..... CARD SERIAL: 00126253 Checking with server... setool2 card not activated, credits will be used.. auth #0 err: [No credits left] cant update my setool Please help me |
| | #14 (permalink) | |
| Quote:
hard to read and understand . auth #0 err: [No credits left] you need 20 credits to activate your setool card fully to use new version . | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 09-22-2011 15:55 |
| NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
| FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! | FREECELLUK | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-26-1999 22:48 |
