04-08-2011, 23:04 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Toronto, Canada
Member: 178829 Status: Offline Thanks Meter: 24 | Which ATI CCC version is best for KKDongle LBF? Windows 7 x64 + 2x 5970 (crossfired) |
04-09-2011, 03:51 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | It need to test, because many bugs come from AMD. latest beta drivers are 11.4, but of course they add new bug to CAL > "device busy" and is a bit slower(if compile new kernel). Please users to share their experience here to discover new driver. Another "new feature" is that HD6990 is still not fully supported, in OpenCL (future of GPGPU) still support only 1 GPU. In CAL (lower layer) fortunately is possible to use 2 GPUs but to have second GPU working, user need to plug dummy DVI adapter(probalby version with 2 DVI ports). about time, some user example 2xHD5970 850MHz + water colling blocks b.r. |
04-09-2011, 08:17 | #6 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Poland
Member: 15521 Status: Offline Thanks Meter: 57 | Quote:
Regards ****** | |
04-09-2011, 08:20 | #7 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Hi! Im using 10.4 version and cards is on 800MHz. I got 6400 hash! Now seem to be the system is stabile! Is it not dangerous using 800 Mhz or better only 725? |
04-09-2011, 09:17 | #12 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | Quote:
My pc temprature is 65-67 degree, on 725 mhz but when i switch it to 750 or any above. display drive stop responding error occur .. I tried with all drivers 11.3 11.2 11.1 10.12 etc. Any Special Requirement ? LITTLE MASTER | |
04-09-2011, 10:24 | #13 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
My card work on 840Mhz without problem on 800Mhz work even without higher voltage on core. I got PSU 1050W with 4 line 12V+ everyone with 30A power. | |
04-09-2011, 17:01 | #14 (permalink) |
Member: 23714 Status: Offline Thanks Meter: 18,769 | Really problems here can cause only temps and PSU efficiency and performance. If U will overclock card too much but temps will be bellow 100C(Absolute max - AMD specs) then U can only crash driver, nothing more, GPU will not burn. Of course GPU have own overclocking limit too If U do not changed GPU voltage, but only clocks, so U should keep tracking temps only to be in safe range(better do not go higher than 95C). If U get system reboot then probably PSU cannot handle it. Remember that PSU wattage cannot be compared 1:1 for power what U need, but U must get about 80% of PSU power. For example U have 1000Watt PSU and UR system(full, cpu+hdd+DVD+gpus etc) need 950Watt then U need at least 1200Watt PSU. Better is to not overload PSU and let it work at 100% of it potentian, because PSU is never calculated to work like this way. Buy one , strong and good quality PSU Also some differences maybe between different card manufacturers like MSI<>ATI, or just specific model. But for sure U can hit 800MHz even on stock cooler(like me). b.r. Last edited by gsminfo; 04-09-2011 at 19:53. |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
