Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Kulankendi / Nano Support Section > Kulankendi Box / Dongle
Old 09-19-2011, 19:26   #1 (permalink)
gsminfo's Avatar
Member: 23714
Kulankendi Ver 3.08 Final Released!
Kulankendi Ver 3.08 Final Released !
- NANOBox users fusion with KulanKendi. Now all NANO Boxes are part of KK team.
- Added: SL3 cloud computing(require main cloud server)
- Added: SL3 new *.sha and *.cod MxKey format
- Added: Huawei E173(wihthout customized FW)
KKMC Ver. 3.08 Final
Now Unlimited activation for 10 PC released !
Create your cloud and start make SL3 codes faster with KKDongle .
MAIN BUTTONS
START - run/stop server activity
LOAD DB/SAVE DB - load/save database from/to file
CLEAR DB - clear database in server
READ LOG - read log files with IMEI and HASH
DEBUG/DATABASE/SETTINGS TABs
# DEBUG #
in debug will be displayed remote connections to server etc
# Database #
!New record or edited record must be ALWAYS confirmed by ENTER key!
!Used record is marked as RED and cannot be modified
!Selected record is marked as CYAN (will mask RED used record when actually selected)
ID - unique ID of record
FINISHED - indicator of finished record(SL3 value found or not)
IN_USE - indicator of already used record
IMEI - IMEI number to store
HASH - HASH value to store
START_DT - First access record date/time.
STOP_DT - end record date/time(when SL3 Value is found or not)
MAIL - email address to send result and cod files(not finished yet)
NOTES - user notes
# SETTINGS #
- Copy license file to directory with server application
- Start server application
- If is first time when you run it, then server must be configured(notification will be displayed)
- Go to "SETTINGS" page and set:
1) Port - choice any port which do not collide with any port used in system and is in range 1024-65535
2) Access Password - set password to protect access to server(empty password = everyone can access). Password will be required for every calculating computer
Password is hidden, you can always unhide it by mark "unhide" checkbox. Select strong password or use build in generator - "generate random"
3) Click "Save settings"
Server is configured and ready to write data to database.
1. Used record is marked as RED and cannot be modified.
2. Selected record is marked as CYAN (will mask RED used record when actually selected) .
3. Every changes in record must be confirmed with ENTER key. New record will get unique ID.
4. New or modified record will be confirmed by information at bottom bar if all values are correct.
5. Record without all correct data will not be stored(no information at bottom bar).
6. By set used record as UNFINISHED, will clear all information about progress, however record will be marked as
FOUND if any of remote computers which still calculating will find SL3 Value.
7. If any of remote computer will disconnect accidentially, server will NOT cancel used part byself
For all who start in same PC KK Software and cloud server:
- start first kk sl3 cloud server and wait for license reading
- next start kk exe
Best Regards ! GSMinfo !
The Following 8 Users Say Thank You to gsminfo For This Useful Post:
Old 09-19-2011, 19:36   #2 (permalink)
GSM SKILS's Avatar
Member: 368697
thanx for good update
can u add this modem for unlock e153
Looking for phone...
Phone detected.
Phone Model: Unknown
Firmware serie: E153
Phone IMEI: 3523xxxxxxxxxxxxxx
Firmware Version: 11.609.18.00.846
All Done! - Time:00:00:01
Old 09-19-2011, 19:40   #3 (permalink)
GSM SKILS's Avatar
Member: 368697
sever activation is 50 euro
then each phone will cost money or free?
thanx
Old 09-19-2011, 19:45   #4 (permalink)
gsminfo's Avatar
Member: 23714
thanx
All KKDongle Users have unlock all gsm device for free without credits.
B R
Old 09-19-2011, 19:46   #5 (permalink)
gsminfo's Avatar
Member: 23714
Phone detected.
Try make unlock this and paste me info!
I think is supported version.
Old 09-19-2011, 20:12   #6 (permalink)
Member: 47384
Hi!
Can you more datail about license for cloud?
Now Unlimited activation for 10 PC released ! for 50 EURO?
Thanks
Old 09-19-2011, 20:14   #7 (permalink)
gsminfo's Avatar
Member: 23714
Originally Posted by baomobile View Post
Hi!
Thanks
For 50 euro possible connect to 10PC with cloud system.
Local or by internet.
Old 09-19-2011, 20:29   #8 (permalink)
dsd
Member: 307049
Nano box user can use KK soft ?
Old 09-19-2011, 20:29   #9 (permalink)
Member: 47384
if i have 50 PC i need to pay total 500 Euro to have cloud funtion right?####important questions ####
1- Does the speed will remain the same as Hashcat if we use Cloud?for example 3 x 5970 850MHz with Hashcat speed 11,5B/s
2-1 of 50 PC found the code,other PC will jump to next IMEI and how longer time for main server regiving job to other PC to do the next IMEI (instantly,60 seconds..)
I'm asking that because i want to compare with other software from differtent Team
Thanks
Old 09-19-2011, 20:32   #10 (permalink)
Member: 715596
Old 09-19-2011, 20:43   #11 (permalink)
gsminfo's Avatar
Member: 23714
Thanks
KK Sl3 Cloud Server work only with KKBox/Dongle.
If you need connect 50 pc to cloud you need buy 5 activation = 250 euro .
If KK software found code cloud system jump to new one and start calculation.
Old 09-19-2011, 20:44   #12 (permalink)
gsminfo's Avatar
Member: 23714
Yes. Now NanoBox Users can use KK Software.
B R
The Following User Says Thank You to gsminfo For This Useful Post:
Old 09-19-2011, 21:02   #13 (permalink)
mounir0020's Avatar
Member: 512970
Sonork: 100.1584185
one quoition pleazz this update u can cluster the computer (cpu+gpu) ;;;;
Old 09-19-2011, 21:25   #14 (permalink)
Member: 542009
Could you please answer question number 1 ,the speed very important i want to know before i decide to buy licenses?and whats timing to jump to next one( 5-10 second- 1 minutes) and can we remove PC on the fly incase some PC have problem and not effect the job from other PC
Thanks
Jumping time you write to software.
You need 1 minute ... no problem.
You need 5 minut ... no problem
If pc down all other imei start by working PC
B R
Old 09-19-2011, 21:29   #15 (permalink)
gsminfo's Avatar
Member: 23714
KK Software for SL3 calulation working by GPU.
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 08-09-2010 10:20
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.38917 seconds with 11 queries
