04-21-2011, 13:23 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 276432 Status: Offline Thanks Meter: 65 | please need an help in overclock my card ati 6990 dual 4 giga to 950 mh i made that in my settings in catlayst control and make it 20 % more power and after that i got this message ( driver display not responding and recoverd sucsessful but the caculating is stop so how to do that i have pro cor i7 3.7 cash 8 mb 8 giga ram king stone power supply 1200 w case thermaltalk ati 6990 dual 4 giga windows 7 32 bit also i tried on 64 bit KK BOX very good van for my cpu also i put it i need an help please |
04-21-2011, 13:28 | #2 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | high MHz OC need voltage gain too for GPU cores, it will produce more heat, so first what U need for high OC is waterblock on UR card. Do U have waterblock or stock cooler? ps. max what I get was 900MHz on standard cooling and without touch voltage. will find any article about OC 6990 for U Aha, one thing, U do not need to OC memory in UR card, just memory must be a bit more clocked than GPU. So for 950MHz GPU , memory can be 1000MHz. Some users successfully OC their cards(5970) to 950Mhz and 400Mhz memory and works, but this need test first, before run final bruteforce. Lowering memory OC helps to decrease temps drastically b.r. EDIT: here is article : http://www.tweaktown.com/articles/39.../> /index.html http://www.overclockersclub.com/revi...e_hd6990/4.htm Quote:
04-21-2011, 14:33 | #3 (permalink) | |
Member: 276432 Status: Offline Thanks Meter: 65 | Quote:
i have a stock cooler is that oky for 950 or not | |
04-22-2011, 04:23 | #5 (permalink) | |
Thermaltake CPU cooler fan supports 200w heat pips x 5 16 dBA noise 12 cm vr fan x 2 and case thermaltake and powers supply 1200 w what i need can you post an link for this cooler also my temperature using catalyst control center is 70 c is this good or bad | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
