04-20-2010, 16:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | S8000 Jet phone freeze unlock doesn't work... I insert other SIM, phone freeze is shown, with options SOS and Phone. Instructions says to press SOS, but that just calls emergency number directly, it does not show keypad. If I press Phone, it shows keypad, but when i enter the code and hit the middle button, nothing happens. If i hit the send/call button, it says only emergency calls. What do I do!? |
04-20-2010, 16:42 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | Code: ******** Samsung S8000,S8003 Unlocking Instructions ******** >> Read Unlock Codes by USB Cable << 1. Be sure that battery is at least half charged!!! 1. Power ON phone without simcard 2. Connect USB cable, install drivers from support: Samsung_USBDrivers.exe 3. Select "Read Unlock Codes" option and click EXECUTE 4. Do not try disconnect phone or other stupid things!!! 5. Wait few seconds for codes TIP: for read unlock codes phone can be in Samsung or Qualcomm mode >> Read PhoneLock or SimcardLock by USB Cable << If phone ask for PhoneLock code after power on use [method 1] If phone ask for SimCard code after power on with simcard inside use method 2 [Method 1] 1. Power ON phone without simcard 2. Connect cable, install drivers from support: Samsung_USBDrivers.exe (or from CD with phone) 3. Select "Read PhoneLock" option and click EXECUTE and wait for codes 4. If phone have SimCard lock set(check with simcard) do now Method 2 [Method 2] 1. Power ON phone without simcard 2. Enter code: *#782872# it will switch mode to Qualcomm 3. Connect cable, install drivers from support: QUALCOMM_USB_Driver.rar 4. Go to SETTINGS and click DETECT,select COM port with "Qualcomm Diagnostic" name and click ACCEPT 5. Select "Read PhoneLock" or "Read Simcard Lock"(or both) option(s) and click EXECUTE and wait for codes 6. Switch back communication to Samsung mode by enter *#726872# code TIP: PhoneLock code can be readed in both Samsung & Qualcomm mode SimCard Lock code can be readed ONLY in Qualcomm mode |
The Following User Says Thank You to gsminfo For This Useful Post: |
05-04-2010, 14:20 | #5 (permalink) |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | these codes are wrong ,they are for unlock NCK not unfreeze: With Original SIM card in handset Enter #7465625*638*UNFREEZE CODE Phone Unfrozen Input unaccepted SIM card into handset Enter #7465625*638*UNLOCK CODE# Your Phone should now unlock Phone need to be unfeezed first to accept any lock level code. I saw 2 times situation what U have and solution is only one: U must flash phone to other sw version because something is broken in firmware, U can try factory resets by codes but as I remember I checked it already with my friend who had same situation. Most funny is that I flash my phone with same firmware as my friend had (maybe same as U have) and for me all works perfect, so explanation is simple: something is broken(like file system errors) and need to be repaired first. I never test put 20 or more time bad unfreeze code, maybe this is reason why phone do not want to call unfreeze function in phone after. After flash phone all codes what U got will works for UR phone of course, so U can put unfreeze code. If U do not have any experience about flashing S8000, tell me what language U want and will try to find firmware for U + sw and instructions Believe me is only one way, I have S8000 here and I tested it b.r. Last edited by KulanKendi; 05-04-2010 at 14:28. |
05-04-2010, 14:27 | #6 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | oka I tested phone again here and maybe is some missunderstanding in instructon. For S8000 when is freezed phone show frame with: message and SOS and CALL Button. select CALL button and U will see keypad, put unfreeze code (8 digits only) and do not push any other key, acceptation is not needed, phone should selft accept it and ask for any lock level like Network lock. Tell me what phone says when U try this way? b.r. Quote:
05-06-2010, 16:51 | #7 (permalink) |
Member: 384655 Status: Offline Thanks Meter: 517 | oka here is: first flash file http://www.kulankendi.com/_ftp_guar/SW/S8000XEIG2.rar sw to flash http://www.kulankendi.com/_ftp_guar/...ader_V5.56.rar 1. run multiloader 2. select LSI6410 3. mark: Full Download 4. decompress S8000 firmware 5. click BOOT and locate BOOT directory in S8000 uncompressed dir(U can select only directory for BOOT) 6. click AMSS and locate amss.bin file (do not mistake with other file) 7. click APSS and locate apps_compressed.bin file (do not mistake with other file) 8. click RSC1 and locate file with extension "rc1" probably will be only one 9. click RSC2 and locate file with extension "rc2" and with "(low)" in file name. Do not load other file like, is important coz UR phone can go crazy 10. click Factory FS and load any .ffs file(if more than 1) 11. do not load other files 12. connect powered on phone 13. click Port search, phone should go to download mode (U will see on LCD) 14. click Download and wait till all finish Please keep in mind, that flashing drain battery fast so better charge phone to full. Also keep in mind that any power interruption can kill phone(most sensitive is boot area only). Tell me if U got language what U wish in this file, Im uploading second file b.r. |
05-11-2010, 18:16 | #8 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 322130 Status: Offline Thanks Meter: 57 | s8000 unlock unfreez code notworking hi i got unlock gode unfrezee try to put code still wont take then i flash phone and try agian still same problem any help plz thx |
05-11-2010, 18:32 | #9 (permalink) |
Junior Member Join Date: May 2010
Member: 1299137 Status: Offline Thanks Meter: 1 | For S8000 when is freezed phone show frame with: message and SOS and CALL Button. select CALL button and U will see keypad, put unfreeze code (8 digits only) and do not push any other key acceptation is not needed, phone should selft accept it and ask for any lock level like Network lock. |
The Following User Says Thank You to EgyptIO For This Useful Post: |
05-11-2010, 19:58 | #11 (permalink) |
Member: 384655 Status: Offline Thanks Meter: 517 | did U select BOOT files while flashing phone?? try also reset phone(without simcard) by codes(some may not works): *2767*3855# - Full SVC Reset *2767*2878# - custom reset *2767*782# - SVC Reset *2767*8451# - Reset b.r |
04-18-2013, 10:52 | #12 (permalink) | |
Junior Member Join Date: Apr 2013
Member: 1919641 Status: Offline Thanks Meter: 0 | Problem with drivers Hi, I got a problem with the drivers, I install the Samsun_USBDrivers.exe on my computer and connect the phone but nothing happens, can u tell me what I have to do? ty, i need the unfreeze code. Quote:
12-22-2014, 10:08 | #13 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Afghanistan
Member: 1971574 Status: Offline Thanks Meter: 8 | hi guys i have samsung s8003. it have code when i turn on my phone with out sim its shows enter code but its isn't connect with z3x by usb cable and URT cable i tried so much but its doesn't any result so any body can help me urgent PLEZ PLEZ PLEZ !!!!!!!!!! |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
