Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Kulankendi / Nano Support Section > Kulankendi Box / Dongle
Old 04-20-2010, 16:18   #1 (permalink)
Member: 105625
Thanks Meter: 44
S8000 Jet phone freeze unlock doesn't work...
I bought Kulankendi credit to unlock phone freeze, but it's not possible to enter the code...
I insert other SIM, phone freeze is shown, with options SOS and Phone. Instructions says to press SOS, but that just calls emergency number directly, it does not show keypad.
If I press Phone, it shows keypad, but when i enter the code and hit the middle button, nothing happens. If i hit the send/call button, it says only emergency calls.
What do I do!?
Old 04-20-2010, 16:42   #2 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
 ******** Samsung S8000,S8003 Unlocking Instructions ********
>> Read Unlock Codes by USB Cable <<
1. Be sure that battery is at least half charged!!!
1. Power ON phone without simcard
2. Connect USB cable, install drivers from support: Samsung_USBDrivers.exe
3. Select "Read Unlock Codes" option and click EXECUTE
4. Do not try disconnect phone or other stupid things!!!
5. Wait few seconds for codes
TIP: for read unlock codes phone can be in Samsung or Qualcomm mode
>> Read PhoneLock or SimcardLock by USB Cable <<
If phone ask for PhoneLock code after power on use [method 1]
If phone ask for SimCard code after power on with simcard inside use method 2
[Method 1]
2. Connect cable, install drivers from support: Samsung_USBDrivers.exe (or from CD with phone)
3. Select "Read PhoneLock" option and click EXECUTE and wait for codes
4. If phone have SimCard lock set(check with simcard) do now Method 2
[Method 2]
2. Enter code: *#782872# it will switch mode to Qualcomm
3. Connect cable, install drivers from support: QUALCOMM_USB_Driver.rar
4. Go to SETTINGS and click DETECT,select COM port with "Qualcomm Diagnostic" name and click ACCEPT
5. Select "Read PhoneLock" or "Read Simcard Lock"(or both) option(s) and click EXECUTE and wait for codes
6. Switch back communication to Samsung mode by enter *#726872# code
TIP: PhoneLock code can be readed in both Samsung & Qualcomm mode
SimCard Lock code can be readed ONLY in Qualcomm mode
The Following User Says Thank You to gsminfo For This Useful Post:
Old 04-20-2010, 17:08   #3 (permalink)
Member: 105625
Thanks Meter: 44
I already have got the phone freeze codes, but can't enter them to the phone. Please read first post again. Thanks.
Old 04-20-2010, 17:23   #4 (permalink)
Member: 105625
Thanks Meter: 44
Originally Posted by everton10 View Post
Option 2 (usually used with touch screen Samsungs - F480 etc)
With Original SIM card in handset
Enter #7465625*638*UNFREEZE CODE
Phone Unfrozen
Input unaccepted SIM card into handset
Enter #7465625*638*UNLOCK CODE#
Your Phone should now unlock
Result: The phone is phone freeze! Deactivate fail (for both unfreeze and NCK code)
Old 05-04-2010, 14:20   #5 (permalink)
Member: 384655
Thanks Meter: 517
these codes are wrong ,they are for unlock NCK not unfreeze:
Phone Unfrozen
Phone need to be unfeezed first to accept any lock level code.
I saw 2 times situation what U have and solution is only one: U must flash phone to other sw version because something is broken in firmware, U can try factory resets by codes but as I remember I checked it already with my friend who had same situation. Most funny is that I flash my phone with same firmware as my friend had (maybe same as U have) and for me all works perfect, so explanation is simple: something is broken(like file system errors) and need to be repaired first. I never test put 20 or more time bad unfreeze code, maybe this is reason why phone do not want to call unfreeze function in phone after. After flash phone all codes what U got will works for UR phone of course, so U can put unfreeze code.
If U do not have any experience about flashing S8000, tell me what language U want and will try to find firmware for U + sw and instructions
Believe me is only one way, I have S8000 here and I tested it
b.r.
Old 05-04-2010, 14:27   #6 (permalink)
Member: 384655
Thanks Meter: 517
oka I tested phone again here and maybe is some missunderstanding in instructon. For S8000 when is freezed phone show frame with: message and SOS and CALL Button. select CALL button and U will see keypad, put unfreeze code (8 digits only) and do not push any other key, acceptation is not needed, phone should selft accept it and ask for any lock level like Network lock. Tell me what phone says when U try this way?
b.r.
What do I do!?
Old 05-06-2010, 16:51   #7 (permalink)
Member: 384655
Thanks Meter: 517
oka here is:
first flash file
http://www.kulankendi.com/_ftp_guar/SW/S8000XEIG2.rar
sw to flash
http://www.kulankendi.com/_ftp_guar/...ader_V5.56.rar
1. run multiloader
2. select LSI6410
3. mark: Full Download
4. decompress S8000 firmware
5. click BOOT and locate BOOT directory in S8000 uncompressed dir(U can select only directory for BOOT)
6. click AMSS and locate amss.bin file (do not mistake with other file)
7. click APSS and locate apps_compressed.bin file (do not mistake with other file)
8. click RSC1 and locate file with extension "rc1" probably will be only one
9. click RSC2 and locate file with extension "rc2" and with "(low)" in file name. Do not load other file like, is important coz UR phone can go crazy
10. click Factory FS and load any .ffs file(if more than 1)
11. do not load other files
12. connect powered on phone
13. click Port search, phone should go to download mode (U will see on LCD)
14. click Download and wait till all finish
Please keep in mind, that flashing drain battery fast so better charge phone to full. Also keep in mind that any power interruption can kill phone(most sensitive is boot area only).
Tell me if U got language what U wish in this file, Im uploading second file
b.r.
Old 05-11-2010, 18:16   #8 (permalink)
Member: 322130
Thanks Meter: 57
s8000 unlock unfreez code notworking
hi
i got unlock gode unfrezee try to put code still wont take then i flash phone and try agian still same problem
any help plz
thx
Old 05-11-2010, 18:32   #9 (permalink)
Member: 1299137
The Following User Says Thank You to EgyptIO For This Useful Post:
Old 05-11-2010, 18:38   #10 (permalink)
Member: 322130
Thanks Meter: 57
hi
i put unfrezze code after while nothing happen iam not touch any botton like you said i done but no luck
thx
Old 05-11-2010, 19:58   #11 (permalink)
Member: 384655
Thanks Meter: 517
did U select BOOT files while flashing phone??
try also reset phone(without simcard) by codes(some may not works):
*2767*3855# - Full SVC Reset
*2767*2878# - custom reset
*2767*782# - SVC Reset
*2767*8451# - Reset
b.r
Originally Posted by webzone136 View Post
hi
thx
Old 04-18-2013, 10:52   #12 (permalink)
Member: 1919641
Problem with drivers
Hi, I got a problem with the drivers, I install the Samsun_USBDrivers.exe on my computer and connect the phone but nothing happens, can u tell me what I have to do? ty, i need the unfreeze code.
[Method 1]
[Method 2]
Old 12-22-2014, 10:08   #13 (permalink)
Member: 1971574
Thanks Meter: 8
hi guys i have samsung s8003. it have code when i turn on my phone with out sim its shows enter code but its
isn't connect with z3x by usb cable and URT cable i tried so much but its doesn't any result
so any body can help me urgent PLEZ PLEZ PLEZ !!!!!!!!!!
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.30844 seconds with 10 queries
