Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Kulankendi / Nano Support Section > Kulankendi Box / Dongle
Old 04-02-2011, 01:26   #31 (permalink)
Member: 1543428
Thanks Meter: 3
realy good update
Old 04-02-2011, 02:27   #32 (permalink)
Member: 13419
Thanks Meter: 13
not working on me...
showing cl_error: getting device attribs (calDeviceGetAttribs)
Anyone can make it run?
Old 04-02-2011, 05:17   #33 (permalink)
Oxegen's Avatar
Member: 1439406
Thanks Meter: 88
Originally Posted by turan alom View Post
realy good update.
if it is for free? 1month?
unlock creadit or without creadit?
read carefully .
Old 04-02-2011, 07:38   #34 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Originally Posted by strangerboy View Post
Many questions here:
1º- Wich box should we buy ??? Can we just buy lite edition box ?? Can we buy lite dongle ???
2º- Does it support pause/resume ???
3º- Does it have some kind of queue ???
4º- Is it fully tested in salts range?? I mean code found 100% if system stable ??
5º- How much % does your sw improves BTF ???
6º- I hope u guys protect well the sw or it will be in all other boxes in few days
Ps: Check your pm
Aka BrAiNdEaD
1. Any version like you prefere all support SL3 brutforce
2.&3. Now not in next update for sure will be added pause and queue
4. Fully tested this is they software all write by they no other code inside.
5. On my system I got 25% speed up with sl3 kk software.
6. This software is from EU programer then for sure this is protected by EU law and if anyone from EU crack it this can be in court.
Next is that software is for dongle then for sure is good protected.
The Following 4 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 04-02-2011, 07:40   #35 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Yes very fast on my pc 1xHD5970 and 1xHD5870 in crossfire I got max time 52hours about 25% faster then with other box great work !! !!
No need any instruction
this software is simple in use just press button LOG select file what you want calc and press button EXECUTE that all.
The Following 2 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 04-02-2011, 08:37   #36 (permalink)
Member: 13419
Thanks Meter: 13
@wgmmmx1
i'm using win 7 64bit.
Do you know the problem?
Thx
br,
gsmbotol
Old 04-02-2011, 08:55   #37 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
i cannot see log button i only execute can u post screen shots
Old 04-02-2011, 08:58   #38 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
Connect dongle first and you see SL3 brutforcer
B R
Old 04-02-2011, 08:59   #39 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
hehehe okey thanks thats is why i cant see its because i have dongle
is there pause and resume lbf?
Old 04-02-2011, 09:01   #40 (permalink)
taoujdate's Avatar
Member: 510826
Thanks Meter: 183
How to do ? :
* BETA SL3 Bruteforcer AMD HD5870/5970 Windows 7 ONLY *
1. Install latest drivers with OpenCL support
2. Enter IMEI number to IMEI field
3. Enter first HASH (from log readed with other tools) to HASH field
4. Click EXECUTE
IMPORTANT:
When more than 1 card is used in system, then GPUs clocks speeds differences will impact to overall bruteforce performance. Lowest GPU clock speed will be used(say "thanks" to AMD driver programmers)
For best performance use the same manufacturer Graphic Cards (with the same GPU clock speeds).
For dual GPU cards, if overclocked then set the same GPU clock speed for every core.
Again, because of AMD lazy coders and their buggy drivers, Windows 7 is required!
Crossfired cards should works on XP, but dual-GPUs cards not(1 core will be used)
WARNING:
SL3 algo is highly optimized and GPU will generate a lot ot heat.
Take care of the good cooling!
Old 04-02-2011, 09:06   #41 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
after post no any responce or reply from product suporter
yesterday was ist april....
hmmmmmmm need to think about foooooooooooooool
Old 04-02-2011, 09:15   #42 (permalink)
taoujdate's Avatar
Member: 510826
Thanks Meter: 183
http://www.freeimagehosting.net/image.php?9db536c066.jpg
Old 04-02-2011, 09:17   #43 (permalink)
gsminfo's Avatar
Member: 23714
How answer you need ?
What no clear ?
All info in first post.
B R
Old 04-02-2011, 09:57   #44 (permalink)
gsminfo's Avatar
Member: 23714
Originally Posted by bilalzaink View Post
core i7 950 3.06ghz assus
250 GB hard drive.
4 GB ddr3 ram..
ATI Radeon HD 5970 dual-GPU video card XFX(2 Cards)
cooler master cassing
850 power supply
This is my PC...
So How much time get code with KulanKendi dongel.....??????
The maximum time :
2 x HD5970
725MHz = Max calc.time: Days: 1 | hours: 21 | min: 5 [in hours: ~46]
750MHz = Max calc.time: Days: 1 | hours: 20 | min: 0 [in hours: ~44]
775MHz = Max calc.time: Days: 1 | hours: 18 | min: 5 [in hours: ~43]
1 x HD5970
725MHz = Max calc.time: Days: 3 | hours: 19 | min: 12 [in hours: ~91]
750MHz = Max calc.time: Days: 3 | hours: 16 | min: 14 [in hours: ~88]
775MHz = Max calc.time: Days: 3 | hours: 13 | min: 21 [in hours: ~85]
800MHz = Max calc.time: Days: 3 | hours: 11 | min: 45 [in hours: ~82]
B R
The Following User Says Thank You to gsminfo For This Useful Post:
Old 04-02-2011, 12:25   #45 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
yesterday = 1-4 @_@
sure or joke lol lol
Page generated in 0.19511 seconds with 10 queries
