01-07-2010, 04:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | box problem could not connect to server [SOLVED] i have registered my box on my other pc..then it is working fine..later on my pc have a problem so i have use my bb-box to other pc the try to unlock bb unit but i get error.here is the error ERROR...Check Account on sat tools i get also this one Account STORED Successfully on your Hard Drive Return to 'Box Data' tab and check if you can connect 11:21:17 PM Connecting with Main Server... A07 ERROR Login and passwd not found (or box not registered) 1.- Execute SAT tool 2.- Press 'Setup Account' button 3.- Verify that you have user/pass correct 4.- Press 'Save Login Data' button Connecting with Support Server . . . YOU DON'T NEED TO CREATE ACCOUNT This box was registered previously. If you don't remember password use Recover button. If you can't remember login then contact support. i know my user name & pass.but problem is cannot use my bb-box.any help is highly appreciated.thanks br |
01-07-2010, 04:29 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hello: Maybe you have in BB Sat one option for recover password. If this don't solve your problem contact Mr The_Gorr and send your Box serial Number The_Gorr e-Mail: [email protected] or contact by PM Best Regards Christian |
01-07-2010, 05:28 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | send mail with ur box sn to [email protected] will check and answer u tomorrow, i'm away now br <= The_Gorr => |
Could not connect to server...; (Solved - Server fixed and back online) | newchief | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 26 | 02-28-2010 09:51 |
HELP.. Could not connect to server, please check connection or firewall ! | n2roy | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-21-2009 16:36 |
could not connect to server??? | ZIYAAD STRYKER | Ultima Box Light | 10 | 11-18-2007 14:00 |
UID BOX ....Error, could not connect provided server! | Bao Tran | UID - Box | 2 | 09-19-2007 22:43 |
